maxleung- Glad you found it useful.
I have an updated version, attached. The release notes follow.
The purpose of this tool is to provide quick and easy calibration of the grayscale at Reference Black and Reference White. This is intended to be an adjunct to DVE t12/ch14 with several advantages for reference point calibration a) finer resolution around the reference levels, b) video loops so changes to your DVD player setup will show immediately without having to flip between chapters, c) bars in the Black 15-19 screen wiggle for better visibility.
For best results, set up each element of the video digital signal path in order as follows. Warning - this is a summary of several hundred AVS Forum posts and several spirited debates that you can and should read for yourself. Good references are ChrisWiggles
Source Settings Guide, and cyberbri's
Calibrating Display to Match HTPC Output.
Here's my highly compressed summary:
- Software DVD player: adjust its video levels so an alt-prt scrn pasted into MS Paint (for example) yields bar RGB values in the screen capture that are equal to the source bar label values. {edit: more detailed explanation of this step 6 posts further down}
- Video driver: leave flat.
- Display black: adjust brightness so bar 17 is barely visible and bar 16 (reference black) is not (blends with the blacker-than-black background). Do this first with the Black 1-24 screen, then fine tune with the Black 15-19 screen.
- Display white: adjust contrast so 235 (reference white) is clearly distinguishable from the background, and as many higher peak white values to the right as you feel are appropriate after reading the posts and judging your own source material. I find that adjusting so values up to 245 are visible yields the best results on my system.
- Recheck display black and white for interactions.
This is release 2.0, April 24, 2005. New with this release:
- Added a Reference Black fine tuning screen with only bars 15-19, plus the bars wiggle for better visibility.
- Crisper bar edges due to resized screens, custom-tuned rendering, and progressive encoding. Screens now display in 4:3 aspect for the same reason. The bar edges on the DVD files native 720x480 image are (essentially) pixel perfect, but the DVD players anamorphic image resizing and desktop scaling blur the edges somewhat.
refbwcal_mpg.zip 378.7626953125k . file
