So here is my procedure:
1. Install fresh Windows XP SP1 (English)
2. Download and install WMP9 from
Microsoft
3. Make sure you are now able to play the T2_part1.wmv files from the Terminator 2 DVD. That requires running dvdrun.exe, individualizing WMP and finding the right proxy if you are not in US to get the license.
4. Get the DRM2WMV files from DOOM9
forum
5. Download Japanese version of WMP9 from Microsoft (same link as 2, but change the language)
6. Doubleclick the downloaded file, it will unpack all installation files to temp directory in your Documents and Settings directory. Get the drmv2clt.dll file and copy it to c:\\Program Files\\Windows Media Player directory. Cancel the Japanese WMP9 installation.
7. Edit lines 9-12 of the drmdbg.ini downloaded from step 4 as written bellow
drmv2clt=1;
drmclien=0;
blackbox=0;
indivbox=0;
8. Doubleclick drmdbg.exe. It should open WMP. Navigate to T2_part1.wmv. After acquiring the license the drmdbg DOS window should display something like this:
drmdbg Ver 0.31 by taku
CreateProcess: c:\\Program Files\\Windows Media Player\\wmplayer.exe
010010C5 âvââOâëâÇ âGâôâgâÕü[ â|âCâôâg
IsDebuggerPresent: memwriteret=1 callret=0
crc: 2850B98C c:\\Program Files\\windows media player\\drmv2clt.dll
setbp 09252BCC 50
eax 00D6E1C8
<DRM2WMV2>
<KID></KID>
<SID>LCqa6j9UTtiPj3FZKZ0pFnIYzaM=</SID>
<INFO></INFO>
</DRM2WMV2>
Copy the last 6 lines and paste them to T2_Part1.key text file to the drm2wmv1241\\drm2 directory. Do the same for parts 2-7.
9. Copy the seven T2_PartX.wmv files from the DVD to the drm2wmv1241 directory.
10. Change your date to 12/Feb/2005
11. Open DOS window, go to drm2wmv1241 directory. Type
md c:\\windows\\#dummy
drm2wmv T2_Part1.wmv
The file should be decrypted. Here is what I see:
J:\\drm2wmv1241>md c:\\windows\\#dummy
J:\\drm2wmv1241>drm2wmv T2_Part1.wmv
DRM(Ver1&2) Conversion tool Ver 1.241 by taku
DRMv1 KID (17fG9KorUkm83BmyUnPv3w==)
DRMv2 KID (17fG9KorUkm83BmyUnPv3w==)
ÅSâpâPâbâgÉö: 110189ü@1âpâPâbâgâTâCâY: 9418
|################# | 34%
Repeat for the other six parts.
12. Join the decrypted files with
WMV Direct. Here is where I encountered a problem. I cannot join all the files. Probably the WMV Direct is somehow limited in resulting file size. I was able to join only parts 1-5 to almost 5 GB file. If anybody knows any other WMV joining software, please let me know.
EDIT: I was able to join the files with
AVI/MPEG/RM/WMV Joiner.
Good luck
Tomas
