pagusas,
Yes, the LNR328W has a Brightness Sensor, Dynamic Contrast, and Digital Noise Reduction. The display model I was reviewing at Best Buy had all three "features" switched on. The display I actually purchased only had Dynamic Contrast and DNR switched on out of the box. You can switch all three features on and off using the user menu. You also have the standard Brightness and Contrast adjustments found on any television or monitor.
There is no specific backlight adjustment in the user menu. I'm not sure how to get into the service menu to check and see if one is hiding there. To be honest, though, the backlight glow is only just discernible on my LCD. I guess YMMV since different people are more sensitive than others. Personally, my eyes are a touch photosensitive, so I was concerned that the backlight glow would be too much, especially at night. I was glad to find that this wasn't the case in my experience.
pmvella,
I look forward to your report!
Cheers,
- David
[Edited: Forgot to mention Digital Noise Reduction in my original post.]
pmvella,
Cheers,
- David
and as a result was damaged in transit, so I'll be sending it back for an exchange. I decided to put the DVD into my DVD player anyway to see how far I could get before the scratched area became a problem. Luckily, I was able to get through quite a few of the calibration routines.
. But this type of fault is usually blamed on the display when in reality, it shouldn't be.
