Originally posted by MEYJR
Right now I seem to be getting everything except 4.1. I tried 35 but it said it was renamed 4.01. But I get nothing on it.
I have a Mitsubishi 65813.
I now have three tuners. One in a Mitsubishi 65513 (which recently replaced a 65511), a MyHD and a FusionHDTV. Only the latter two give signal strength. But based on these two, it seems KPXD (68.1 on 42), KFWD (51.2 on 51), and KXAS (5.1 on 41) are the weakest, from worst to best. The MyHD cannot get KPXD at all sometimes, and KFWD breaks up a lot. KXAS's signal dropped a couple of months ago. Some say it didn't for them, but for me it dropped from the mid 80%s to the mid 50%s on the MyHD (I didn't have the FusionHDTV until recently). This was enough to get occasional glitches that I wasn't seeing before. The TV's tuner is better, so I didn't see as big a problem.
But KDFW (4.1 on 35) seems to be very strong. In fact, when I set up the FusionHDTV, it found KDFW on 35 and 36. But when it tried to tune 4.1 via 36, it couldn't. I had to manually delete 36 so that it would use 35, and all was well, including 100% power. I suspect the signal was so strong it was bleeding over. I did not have the same problem with either the MyHD or Mitsubishi 65511/65513. But if you are closer than I am (east of Plano), maybe your TV is having a similar problem?
BTW, what does "SD" and "DT" after the channel stand for?
Originally posted by corinthbandit
Most television stations place their HD signal on the main channel, for example WFAA-DT main channel is 8-1. WFAA-DT places ABC News Now on channel 8-2. The sub channel is a SD or Standard Definition picture as is transmitted in the 4 x 3 format. Some stations have up to 4 sub-channels
I wonder if there are actually any regulations about this. A few months ago, KERA-DT did something (I'm assuming it was maintenance) and the channel 13.1 name became something generic (I'm sorry, I can't remember what it was). After a couple of weeks, I couldn't resist sending them feedback via their web page (which is why I don't have a local copy of what I sent to tell you what it said). But when they fixed it, they put up KERA-HD instead of KERA-DT. Also, UPN21 has "Radar" for their second channel, and KPXD has "PaxWest," "Worship," and "Faith" for channels 68.2-68.4.
I'm also curious why 51 doesn't remap to virtual 52, and why they use 51.2 and not 51.1. And my various tuners all do different things with KDAF (33.x on 32), so I suspect their stream isn't quite right either.
Xesdeeni
