Originally Posted by K5ING
I'm confused. If you're getting stations like 5, 8, 33, etc., you should be getting the subchannels as well. Are you sure you're scanning on the antenna and not just what Dish is giving you? I get over 50 OTA channels up here (between Denton and Decatur) including the LP Ch. 31's. With you at Cedar Hill, you should get everything with as little as a bent coat hanger for an antenna.
Okay, with the tuner that came with my PC (and NO antenna--just the coax plugged into it with no live Time Warner connection, no DISH connection)...I only get like 4.1, 5.1, 8.1, 11.1, 13.1, 21.1, 33.1...etc. (sorry I'm not at my home PC now to get all the exact channels).
I bought another TV tuner that comes with a small antenna, and now I get more sub channels (like 4.1, 5.1, 5.2, 5.3, 8.1, 8.2, plus Spanish channels).
My point was that while I had a LIVE Time Warner cable connection going, I was able to get all locals with subchannels, Spanish channels, AND cable channels with the coax plugged into my PC-tuner card. Well, I canceled cable and switched to D*TV, and now my PC with tuner card-coax gets only 14 basic local subchannels (no Spanish channels, no cable channels)
Hope this helps.
. You see, I thought getting a new tuner would help, but it's actually just the antenna that's helping. My PC tuner was fine.
