Originally Posted by
GlenC
You are aware, that all of the grayscales revolve around the neutral cuts and drives?
Yes, I believe that should have been apparent from my last post? Sorry if I was not clear enough ... I did notice there was a typo when I typed "BDRV~BCUT" although I meant to refer to the entire RDRV~BCUT, I have edited my post to fix this error.
Update: oops, when editing that noticed I also incorrectly indicated in last post I am currently using "GCOF=30" for my current warm offset ... I've also corrected this, it is GCOF=32".
If you reduce blue in neutral, you will reduce blue in cool and warm. If you reduce the C/D offset in cool or warm, there is no affect on the other color temps.
Right. As another example, If I were to say, raise GCUT to "17" from its current "16", I would then change GCOF for "warm offset" to "31", to keep warm offset the same as the values which resulted from the factory for "warm offset" ..... (you may need to refer to my last post to hopefully understand what I'm talking about there .....)
If you reduce blue in neutral, then, yes, warm might look a little green. When you reduce blue, you effectively increase green and red a little.
Of course. Yes, I know this. If you look at the values I provided in my last post, you'll see my warm offset REMAINS exactly the same as it was when I received the set new - not the actual values, but the "actual" result is the same.
I adjust the values for warm offset ,accordingly so it allways remains the
"same as it was from the factory whenever I change the values for neutral .... Again -- so I have the same exact "result" on screen for "warm offset" as was the case with the factory adjusted values, I don't USE the exact same values for RDOF~BCOF, obviouosly since I've changed RDRV~BCUT ...
For example -- Factory setting for "BCUT"=17. Factory setting for "warm offset" BCOF=19 --- Which is exactly the SAME for "warm" as if I were using "BCUT=5" which of course would effect only "neutral" directly.
In other words, I could change RDRV~BCUT to 32-17-9-32-17-5 and I would get exactly the same thing for "neutral" as what results with the factory(or current) warm offset.
For the RDOF~BCOF values(for cool or warm offsets), "31" is "0" offset from the RDRV~BCUT values, Numbers less than 31 are (minus) offset, numbers greater than "31" are "plus" offset. Therefore, if I have BCUT=9 which effects "neutral(and neutral is what I use for actually watching the set), Warm offset BCOF=27 equates to a BCUT value of "5" ... In other words, when I switch to "warm offset" in the user menu, it would be the same thing as having BCUT=5 If I were using "neutral".
I hope what I tried to say in my last post is clearer now?
Also, Just to clarify, other than being curious if you were reffering to "warm offset" conerning your comment about 960s you've worked with being near 6500K, I don't believe I was asking any questions regarding this subject, nevertheless, as allways thanks for your comments and additional insight, as it may be useful to others whom are reading.
Don't get too caught up in any mathematical relationships to the cut drive and offset numbers. This is an analog device with three different phosphors.
I'm well aware of this, I am not getting caught up in "mathmatical relationships", and in no way shape or form has my adjustments of greyscale ever tried to "look for" a mathmatical "relationship" .....
The factory values for Warm offset(RDOF~BCOF) which equate to RDRV~BDRV = 32-17-9-32-17-5 aren't Mine, They were the values which "effectively" result for "warm offset" from the factory. I hope that makes sense, it is a little difficult to say what I'm trying to say in a completely "accurate, or precise way given the way the "offsets" work. Or, at least I can't seem to come up with a good way to say it so folks understand what I'm saying .....
I am not currently using RDRV~BCUT 32-17-9-32-16-9(to clarify that IS what I'm using, and "neutral" primarily for viewing) because of any Mathmatical relationship, I'm using it because of what I see, and because of how my black+white levels are set elsewhere ......... And no, I cannot say arriving at those "values" was "easy" without say, The use of an optical compartor such as Your Sony B&W pro monitor to, or the equipment used by a ISF calibrator .... Nor can I say, obviously with any certianity that it's 6500K/D65 ..... Of course, while it might be nice to be able to say that, I really have no need to say that either, all I really care about is how it "looks" ....
While I do have what I believe would be decent optical comparators to use to some extent = the best one weighs 150lbs(Toshiba 34HF84) and would need to be carried down a flight of stairs. I did have a pro B&W monitor in the garage, but I sold it several years ago, and can't vouch for weather or not it was 6500K .... And, note that no, for the 34HF84 I do not have any verfiable "scientific proof" that it's greyscale is D65/6500K(using it's warm offset) or very close to it, as was the case I believe with my RCAF38310 as well(the XBR960 is a warranty replacement for it), however, BOTH of those sets just had "perfect"(or close to it) looking greyscale from the factory to my eyes(the RCA may have been just a slight bit +red+a bit on the warm side with its warm offset).
And, I also believe my eyes are probably pretty good at knowing what ~6500K "white" looks like(just like the clouds at mid-day Ken has mentioned). Perhaps part of that comes from 30 years taking photographs(many of them in "outdoor enviornments), and 10 years of doing photo editing work on some of those photos on a PC(I even still use film and a 35mm film(negative) scanner, believe it or not, even though I use digital as well) .... I don't know ...
For lack of a better, "scientific" way to say it(and no, this really isn't "entirely accurate", either) --- The way I "see "white" on the screen from a set with a hopefully well calibrated greyscale(D65/6500K), is just the perfect "blend" of R/G/B ...... If white, and every step of grey, and "black" as well doesn't "look right" then I have a problem ..... If that is somehow "incorrect", well honestly, I really don't care ...
As long as I see nice, "perfect" whites(such as the white of mid-day clouds, as ken has mentioned) and "linear greyscale" without color contamination(too blue, too green, or too red) from IRE 0 (black, IRE 7.5 for NTSC of course) to IRE 100 (whilte), I really don't care what the actual "values" being used are, or what the Color temp is .... Of course, the R/B offsets CBOF/CROF come into play here as well when you "increase" the color slider above "0" ... The methods of adjustment to CBOF/CROF Ken has described previously has worked very well for me as well .... No change in "tint" with good B&W program material(the kind without all the added tint they ad in sometimes) throughout range of "brightness" and "color" slider ... Same thing as well -- Neutral grey throughout brightness/color slider range with video black up on the screen .....
Maybe that's not the way it is "supposed to be", but I surely certianly seem to like it ....
If you reduce R/G/B DRV all by 1, the color will most likely change. The luminance level of the three will react differently.
Absolutely. In fact, Currently On my set R/G/B DRV(32-17-9) remains the same for Neutral(what I use for viewing) as "equates" to the warm offset values from the factory(as I hopefully explained well enough before).
Greenish, can also result from watching +blue color temps. I have seen it before myself. Things just didn't look right, so I brought out my D65 B&W monitor to verify what i was seeing.
I believe I can say fairly confidently This wasn't/isn't a result of watching and becoming used to +Blue color temps, although I can live with a slight bit of +blue, or +red moreso than I can +green (for some reason +green "greyscale is especially annoying to me) ....
Clearly, there was +green going on with the "warm" offset(factory netural+cool were just WAY too cool/too blue), and it appeared to my eyes that perhaps the "warm offset" is/was(again, I've kept it allways so warm offset remains exactly as it was from the factory) perhaps just a tad on the "warm" side .... hard to say though, for all I know, it could be a bit on the "cool" side of 6500K ....
Of course, using what was the "factory" warm offset as a reference(or using experimental "cool" offset values that are very close to neutral), all it takes is +1 or -1 for any value of RDRV~BCUT from my prefereed "neutural" settings for things to look "not right" .... Too warm, too cool, +blue, +red, +green/etc ...
Since I can detect and have a "problem" with a difference as little as +1 or -1 for any value of RDRV~BCUT from my "preferred" values, it certianly seems to me I must have things awfully close to how I "want them" ..... Is it 6500K, and conform to D65? I dunno, but it certianly looks awfully good to me ... I've spent enough time with this to say I certianly can't seem to find another set of values that look "better", and I've tried quite a few of them for relatively extended periods of time ....
