I can't speak with authority on this, since I've never owned an SD Sony tube (only HD). But 480p would require a higher scanrate than 480i (31.5 kHz versus 15.75 kHz). So it seems unlikely to me that you'd be able to convert a 480i tube to 480p by simply throwing some switch in the SM. 480p also requires add'l processing to de-interlace the image.
I do not recommend using 480p on the Sony HD tubes btw. IMO, it's more fatiguing to the eyes than using 1080i, and the phosphor persistence is worse. (Note: both the Progressive and Cinemotion settings for 480i inputs will display as 480p on the HD tubes. So I recommend avoiding these as well, if you can.)
