Originally Posted by
ADU
If I were in your shoes, I wouldn't bother trying to determine if the TV's using a different level of Clear Edge VM than the one shown in the User menu. That wouldn't make much sense. More than likely, it's gonna use whatever's listed.
Yeah, I agree, I'm not going to mess with that. Was just trying to think of all the possibilities that might explain what's going on, no matter how unlikely.
ADU
Perhaps the 2170P-3/VM only works when MODE MEMORY is OFF, and there's another parameter involved when MODE MEMORY is ON?
2170P-3/VM doesn't work for this on my set with "mode memory" off, either. I tried it earlier, and just doublechecked it.
Another useful thing I did find out when doing this however is that when I turn "mode memory" off, and then back on, I don't lose any "mode memory On" input specific(or pic mode specific) user menu settings.
ADU
Any idea how many different options the CVSB parameter contains (e.g. 0-3, or 0-4)?
I don't know, I didn't check it as I don't know what it does. CVSB is showing a "0" value for all pic modes+inputs that I checked, so wouldn't think that would be reflective of the different user menu clearedge "defaults" for the different pic modes when the reset button is used(High for Vivid, Low for Movie/etc).
The Section of the SM CVSB(and UPIC~UTMP for that matter) is in is the "QM" section, which is an undocumented section at least it's not shown in the servicecode listing from Service manual. There is also a CVSB "entry" in the undocumenteed "QT" section of the service menu, it's also at "0" everywhere I checked.
Which reminds me --- On another note -- an update on the "HDPT" PM I sent you and Ken the other day. Among other things, if you missed it, In the PM, it explains how I followed the info on this for older sets on other threads, and read all the approrpiate info in the "vertical bar" thread/etc.
Anyway -- I played around with HDPT=0 a little more in one pic mode last night. HDPT has Pic mode specific setting on my set - for instance, you can have it at "0" for vivid and "1" for Standard. With 1080i sources(which is all HDPT effects I believe), The screen going "scrambled" on my set(like you've lost V Sync or H Sync, and somewhat similar, in a sense to what you may get in some occasions if the 2171CXA "FIXS" paramenter isn't correctly set)occurs ONLY if you bring up the user "display" function, and only does that when your in SM - although, even outside SM, the user menus, channel banners/etc, are still "garbled" and not correctly displayed. Otherwise, it seemed to "work" to "by-pass MID".
I didn't find any "good" use for HDPT=0 it however. Except involving "differences" involved with values for the "PT"(passthrough) columns for some controls which differ -- (such as YOSW value, the 1080i PT specific CROP/CBOP(interestingly enough, CROP/CBOP AND YOF~CROF all are offsets that effect the "1080i PT" signal, as well as PT column CBGN~YGN/etc) from the "component" or 'ATSC" specific columns, I couldn't find any differences using HDPT=0 concerning the picture quality of 1080i sources as compared to using HDPT=1 and using all Zeroes in the MID5 Column.
Or, If there were any differences in "image quality"/etc, I couldn't "see" them. I also noticed, with "HDPT" at "0" there was often a "quick moving", rather wide Vertical bar moving across the screen at times(only on 1080i sources of course). Also note that MID1/"DPSW" "blank screen" on my KD34XBR960 if set to "1", and on this set "0" is the "normal" setting for it. If I recall my reading about older sets correctly, it's the other way around.
**disclaimer** At this point, I do not endorse, or recommend that anyone, at least with one of these newer Sony sets "check out" MID-by pass and the "HDPT" setting! As, (just based on my short experiments), #1). I don't think we know "enough" about what it does on these newer sets, it might not be 100% "safe", #2) I don't see that its "MID by pass" does anything "useful", and you can use all Zeros in a MID5 column+accomplish the same thing, at least that seems to be the case given my short experience with it, and from what I can tell. I could be wrong, of course. #3). Also, when you're in SM at least, you might find the screen becoming "all garbled" if you set it to "0" making the Service Menu info "unreadable", therefore you'll be in a real fix if you don't know a way "out" of it. #4). At least on my set, when using HDPT=0, the User menus and channel displays/banners/etc. do not display properly.
