Originally Posted by KenTech
Yes. This is an easy one.
These settings do not adjust the individual colors. Thay set up a complex decoding martix for extracting color, and it really can't be eyeballed. For any one input, there really is only one correct setting. If you use the DVE or AVIA DVDs for setting up your DVD player's input, you have done it right. Period. If you still aren't happy with the greens, you can't blame the player/TV combination!
The good news is that most inputs share the same color-matrix settings just fine, and using DVE to set these parameters will also set it for all other similar inputs. If you wish to go through the process on your own set (DVE works well), I recommend you use 2170P-2/RGBS to turn on only the individual color guns instead of using the color filters.
More good news: Many folks have reported roughtly the same settings after they go through this process. For me it was 14-14-5-3 for RYR thru GYB, respectively. There is a little sloppiness in the proces, and at other times I have set it to 13-15-5-3, and so have others. Not a big deal, since you have gotten away from the huge red push that comes from the factory. I assigned these settings to the "Standard (Normal?)" choice in the user menus.
Viewing those color bars with the green-only gun really explicitly identifies green push; so it does with red, too. Get that right, and your TV is now okay. Or you can just punch in the above numbers (14-14-5-3), and you will be *very* close. For you, the 5-3 pair is all-inportant.
You might be seeing a green push in the original video material for some reason. Food commercials use a red or red-orange "push" all the time. The demo videos on DVE are fairly neutral, and you might start there to see what you've accomplished.
Update on my settings:
Ken what a coincidence!! i ended up with similar results: RYR-14, RYB-14, GYR-6, GYB-4.
But i learned something Ken, that even though at my first go around i got RYR-11,RYB-14, GYR-4, GYB-3 for progressive scan it was ok, then as soon as i went to interlaced mode and watched tv cable the color was off. Seems theres a difference in interlaced and progressive mode huh?
So i recalibrated and did it it interlaced mode instead and now all is swell and it's a good compromise of interlaced and progressive using RYR-14, RYB-14, GYR-6, GYB-4.
Thanks for your help! It seems we all have pretty much the same exact settings which lead me to beleive that is the sweet spot for these settings
it's funny is'nt it!!
