AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Motorola 6412 Forward Jump
post #1 of 5
Can someone identify the code and how to enter into remote for jumping ahead in 30 second jumps?
post #2 of 5
Here's the thread where I got the info. www*avsforum*com/avs-vb/showthread.php?postid=4565223 you'll have to put periods where the * are. I don't have enough reply's posted yet so I can't use the real url.
Pete
post #3 of 5
This is also a good place for remote codes www*hifi-remote*com/cgi-bin2/ueic.cgi?cbl_0476 (remove the * and replace with periods).
Pete
post #4 of 5
Q: How do I program the 30 second skip?
A:
1. Press the "Cable" button at the top of the remote.
2. Press and hold the "Setup" button until the "Cable" button blinks twice.
3. Type in the code 994. The "Cable" button again blinks twice.
4. Hit (Do Not Hold) the "Setup" button
5. Enter in 00173 (for 30 second Skip)
6. Press whatever button you want “30 Second Skip� to be.
__________________
post #5 of 5
Is it possible to program the remote for more than 30 second skips similar to the Tivo skip to hash?
Colesy
This thread is locked
