Carl - I was hoping that you could help me out.
I have my CAV6.6 hooked up to my computer, and I can run your plugin. Unfortunately, it appears that the plug in can't talk to the CAV6.6. I thought that the problem was my COM port, but I've been able to successfully control the unit through commands sent directly by Docklight (a terminal app).
I initially had trouble with Docklight as well, until I got the Baud rates set properly.
Do you have any suggestions? I'd just love to use this thing!
Cheers
Cheers
