AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung HLRxx67W Owners Thread --- 720p DLP HDTV
Samsung HLRxx67W Owners Thread --- 720p DLP HDTV - Page 14
post #391 of 4003
With all of the talk about audio sync, makes you wonder why no one has made a box that can adjust the delay on audio. Optical and RCA in and out with a digital display controlled by remote.
Do a google search for audio delay device.
post #392 of 4003
post #393 of 4003
OK, I have a question - in the 4:3 mode the vertical borderline between a picture and black side bars is not perfectly straight (slightly curved inside). Is it normal. Any ways to fight it?
Dmitry.
post #394 of 4003
Band aids, band aids....The season finale of LOST had the video ahead of the audio. Audio delay boxen, eat your heart out.
post #395 of 4003
Dmitry.
It is normal and there is no way to fix it.
post #396 of 4003
Short and informative as a gunshot . Thanks!
post #397 of 4003
shanec
I think it depends on what source you have showing. I know if i have it on component 1 (Cable box) it shows what rez is coming in and if i have it on cable 3(RF Cable) it shows the program name.
Yes I have the cable box hooked up to both component 1 and to the RF input.
post #398 of 4003
Originally Posted by shanec View Post
It doesn't give the input format. It distinguishes which port is currently being viewed, but nothing about resolution, interlace, or progressive.
it does for some things.
from my yamaha5790 routed component video, it tells me that my dishnetwork 811 feeds it 1080i/60hz, while my DVD player feeds it 480p/60hz.
I don't remember if it tells me what my PS2 is feeding it only because I don't think I've checked.
For OTA, unfortunately, it doesn't give any indication of 1080i vs 720p.
post #399 of 4003
Dmitry.
FWIW, my HLR5067 seems to provide ruler-straight borders when I'm PS2'ing on Component2. I get a black border, IIRC.
OTA, SD material show a gray border that's also ruler-straight.
DishNetwork811, SD material show a black border that I believe is created by the sat-receiver.
now, I just checked my eyesight, so it's not that.
I'm very sensitive to hourglassing (as I call it in the computer monitor side of things) so I would definitely notice.
What's your SD source and via which input?
post #400 of 4003
It's some Motorola box connected via coax - I'm getting a CableCard next week.
post #401 of 4003
Anyone know anyway to adjust the size, input and position of the picture in picture without going through the video menus?
~Lance
post #402 of 4003
Originally Posted by bhchan View Post
(Before we totally hijack the thread)
FWIW, I was somewhat disappointed with Cox cable in California. But that was before I got the TV, so the disappointment was mainly on price and SD content.
I switched to Dishnetwork for their cheaper DVR offerings, free HD for 6 months, and free equipment. (I didn't pony up the $250-odd for their HD-DVR though, which may or maynot be a problem in the near future)
dishnetwork Pros: if you have good off air reception, I'd stick with Dish network and, since you're in Florida, you might be able to get 61.5 reception and subscribe to Voom content.
dishnetwork Cons: if you don't have good off air reception like me, you may not get all the big broadcasters in HD (I'm missing NBC and UPN, for instance) until Dish gets their act together.
I'm going to stick with dishnetwork for now because I'm hoping they'll get the HD rights to NBC etc. soon...
Move the Dish vs DirecTV HD discussion off this thread, PLEEEAASSE.
post #403 of 4003
Dmitry.
That's normal. Its tough to project light in such a small enclosure without some distortion. Its actually less curved than it looks. Hold a straightedge up to your set. You'll be surprised at how slight the curve is. Mine is off less than 1/8 inch at the center.
- Collin
post #404 of 4003
Thanks a lot guys!
post #405 of 4003
So far I've only tried DVD, OTA SD, and OTA HD. Here are the results:
DVD: no lip sync issues (audio fed straight from DVD player to AV receiver)
OTA SD: no lip sync issues (TV speaker audio only)
OTA HD: lip sync varies by channel - some channels are are pefect, some have light lip sync, and some have majory lip sync issues (TV speaker audio only). BTW, I have not checked to compare 480i/p HD content to 720p content.
Actually, I've got no idea how to tell what kind of signal is on an HD channel. Isn't there a button somewhere on the TV that should tell me if its receiving 480p, 720p, etc.?
Well, crap. I played O' Brother Where Art Thou today and had lip sync issues. Fairly signifigant too. The audio was off by about half of a word - whatever that amounts too.
My S97 DVD player has a delay setting, but its in the video menu. I'm not sure how delaying the video would help any when the video is already behind the audio. Maybe its a misnomer? So I turned that setting up as far as it would go to 100ms. This helped, but didn't completely fix, the problem. I'd say it made the problem tolerable.
Are there any really smart delay boxes out there? Something that merely keeps audio and video in sync regardless of which one needs to be delayed?
post #406 of 4003
response removed... I decided a response was unnecessary.
doublecheck your DNR settings and make sure it's off, at least that'll save you one potential process. The manual (or something somewhere) stated that it's only really useful for cleaning up messy input (snow from OTA analog, I believe) which probably doesn't apply anymore.
then, check that disk on another TV and see if the transfer is especially dirty... if it is, then maybe the stupid DNIe is working too hard to clean it up. *sigh*
post #407 of 4003
I should also mention there are complaints in the S97 brain dump thread about lip sync. So it could be my player. And my player has the latest firmware upgrade.
I'll check the DNR.
post #408 of 4003
Update: DNR on my HLR-5667 was already off. BUT I noticed somehow my DVD player had been set for 480p, leaving the upconverting job to the TV. I switched the DVD player back to 720p and the problem was slightly improved - enough so that setting the delay parm to 100ms completely fixed the problem.
But I've still got OTA HD lip sync issues. Grrr...
post #409 of 4003
In case there's any remaining doubt that the 'Info' button does show the resolution - at least for some formats, here are a couple examples.
post #410 of 4003
Thanks for the Info :-) I confirmed I could get resolution by pushing Info with the HDMI feed running. But on my OTA input, there's no so much Info :-)
post #411 of 4003
Using info button for OTA feeds (or DVD) does not show resolution....
post #412 of 4003
Well, so much for breakfast!
post #413 of 4003
I am the proud owner of a HLR5067W. Just wondering how you all clean your screen? I don't want to wreck mine when I have to clean it.
post #414 of 4003
I use a micro fiber cloth. I use it dry if possible or damp not wet for more serious cleaning.
Micro fiber is the cloth that comes with new glasses and it won't scratch. You can wash it but be sure to stay away from anything that would leave a residue in the fabric.
I did a slow search of the RPTV forum and got 58 hits on microfiber so you can probably find some testimonials in that group.
It's available in auto supply stores in sizes more appropriate for wide screen TVs, but be sure to get only the cloth. Some of them come with cleaning or polishing compounds imbedded in the cloth.
Here are some links.
http://www.neatitems.com/micro.htm
http://www.microfiber.org/
post #415 of 4003
They had microfiber cloth at Walmart a couple of weeks ago. Eight pack (14"x14") for ~$5. They work great for lots of stuff where you want to get the dust and leave no lint (car dash, glasses etc.).
post #416 of 4003
Well, I didn't see a first impressions thread, so.....
Its day 3 for my HLR-5667. This is my 1st HDTV. I'm still stunned. Let me just say you have not seen Finding Nemo until you have seen it upscaled on a good big HDTV. If somebody had told me I was watching Finding Nemo on HD DVD, I would have believed it. There is a ton of detail there that I had never seen before - not detail only noticeable by a videosnob/phile, but stuff that would be obvious to anybody. It is simply stunning.
And that's the bad news too. Other DVDs - Fight Club, Monster, The Matrix all have moments where artifacts and film grain/dirt/etc are visible. These are all things that are mentioned on most online DVD reviews. I'd seldom ever seen them before. But now the stuff appears regularly. I suppose the artifacts (maybe its macroblocking...but my 97S player is upgraded to the latest firmware which should have fixed that...) are typically worst on dark, but not black, solid background colors (ie: the shadowy green background in The Oracle's kitchen in Matrix Revolutions). But the rest of the image is so stunning, I'm still very pleased with it and I'd never look back for a second.
post #417 of 4003
DOes the TV guide feature only work when using coax? It says not supported when I have only HDMI connected
post #418 of 4003
I've been using the thx opitmizer (that comes on some dvds) to fine tune the picture since I don't have the DVE or AVIA dvds.
I noticed on one of the video tests that the picture if offset in the vertical by around 10 mm ! Is this due to the DVD or the TV ? Anybody else notice this ?
post #419 of 4003
Can anyone tell me the depth form the front of the TV to the point where it starts to narrow towards the back on the HLR 50?
Thx in advance...
post #420 of 4003
Originally Posted by Breddy View Post
I finally recieved my Bush Edgewood stand and got the HLR5067W perched on it. Still some tweaking required, as well as some wire cleanup, but here's the room:
http://gallery.avsforum.com/showphot...14855/size/big
I left off the 3" pedestal/baseboard from the Bush stand so that it wouldn't be too high. It is very close to perfect; about 1-2" higher than optimal, but no noticeable drop in brightness when seated at my couch.
With a little playing around, I think I can get a couple good shots of HD content, preserving the quality. If anyone is interested, I'll post em up. If not, I won't waste the time
Enjoy,
Breddy
Looks like you got some real estate on that stand for a 56"
Overall, looks great.
  Back to Forum: Rear Projection Units
