Attached is a picture of the 5067 on the new TR46x3 stand
Setup: Comcast HD PVR via component. DVD via component
Tivi via composite...(just temp until I watch all taped shows, then will be removed)
Stand comments: The stand is wll made and matches great. However, the Tv is in no way attached to the stand and I get the feeling my 4 year olds could easily knowk it over. I have decided to put wire from the back crewes of the TV to the stand to form a tether/anchor. No issue with the TV going back as the stand has extra room
MY motorola DVR comes right to the edge of the stand with room in the back for the turn required by the stiff component wires
The HD pictures are great. I have seen very little if any differerence between the Cable box signal and the direct signal.
Qestions that i need ansered and will seach this forum for later: best way to hook up the cable box as it has numerous possible connections. based on the given connection, I need the best setup to the cablebox setup menu
TV comments:
TV Guide is still blank and will probably be useless for me. Sound is good
