Originally Posted by
Possumgirl
How did you succeed in getting the one unit to be digital host only since you obviously have an analog host still available? We have similar setups since I also have 2 units, both OTA only, and I cannot make them stop seeing the analog host.
This was done as part of my recovery from a full TVGOS reset testing. In my area I have multiple analog channels with TVGOS data and one digital channel (9.1). I ran into a problem with getting the clock set (we exchanged posts related to this) and decided to complete the procedure and come back to the clock issue at a later time. Here's the sequence of events:
turned recorder off
performed soft (front panel) reset
turned recorder on
performed TVGOS factory reset
performed 2nd TVGOS factory reset
tuned to 9.1
ran G* Test
received 08.05.40 software
ran G* Test
received 08.06.44 software
entered setup information (zip code, etc.)
forced clock set channel to 9.1
waited for clock to get correct time
(here's where the problem occurred - no time zone packets for two days - ran parallel test and discovered I only receive time zone packets from the digital channel with recorder turned off - decided to continue test and address clock later)
forced clock set channel to 13-0 (analog) [I should have left it set to digital]
tuned back to 9.1 (now VBI channel)
entered 963214785 command and waited for info box to clear
turned recorder off and left off overnight
next morning:
1 time zone packet received (presumably from analog channel)
clock had correct time
host channel was 9.1
clock set channel was 9.1
channel lineup downloaded
partial listings for the full 8 days downloaded
later:
full listing for 8 days
last download time matches download from digital schedule
I need to rerun the test using a digital clock channel to confirm that the process works completely digitally, but I wanted to see how long the digital host would stick before I do this. Previously, I have only been able to keep a digital host channel for a few days before the recorder switches to an analog host channel on its own.
Possumgirl
Last week I once again put my 500 through test. No problem getting clock and both SW updates. After restarting VBI (and reinputting my setup info for good measure) I left it on for 24 hours hoping for a channel lineup. No luck of course.
You can't get a channel lineup without a host channel and you can't get a channel lineup with the recorder on. The channel lineup comes from the host channel. The recorder downloads from the host channel when it is turned off and from the VBI channel when it is turned on. I have never seen it receive data on the host channel when it is turned on. Others do not agree with this, but this has been my experience.
