Originally Posted by speedlaw
So, after wiping one unit, and not wiping the other,
The wiped unit has not acquired time in about a week. The untouched unit has incorrect time, which has not corrected itself. I only unplugged the untouched HDD because I had to move some furniture.
At this point, I'd say if you have clock, don't unplug under pain of Bricking-the unit was fine as a "VCR". Since the fully G Tested and reset unit and the untouched unit (has grids, all of which say "no listing") are acting the same, I'm going with there is no "information" out there to catch.
I've managed to migrate the family over to the Dish DVR's but am leaving the HDD's hooked up, figuring based upon posters from elsewhere that things will "come back".
I know here in NY where everything is expensive that the aborted analog shutoff caused mayhem for broadcasters, most of whom are very carefully set up atop the Empire State Building.
I am from Long Island ny and am experiencing the same problem my box stopped recievin information 03/30 I did a factory reset and ever since have had blank time and no listings bricked out the unit. I believe you are right there is no more info. out there to catch. Hopefully signals will come back I have been reading other posts as well and people are starting to catch signals again but there units had been blank for weeks. Hpefuly this problem resolves itself since my unit is pretty much useless now. Will start setting up manual recordings for now and adjust for wrong time.
