Found a front panel service menu this evening. This is dangerous stuff, so don't try this unless you are having a problem and your unit is already out of warranty.
When the unit boots up, the instant
Welcome appears, press and hold
Menu and
Format simultaneously. Keep holding until the display says
Repair?. Release both keys.
Then press and hold one of the following keys:
- Format to get Clear NVM? (NVM = non-volatile memory)
- Select to get Zero HDD? (resets CPRM code? does not appear to modify the disk itself)
- Exit to get Wipe Unit? (performs both a Clear NVM and Zero HDD in one operation)
Release the key.
Once one of the above questions is displayed, there is a lengthy confirmation step to actually execute the operation. You'll notice there's a
1 displayed above the operation name.
- Press and hold Guide until the number changes to a 2 (takes about 5 seconds).
- Release Guide and press Exit until the number changes to a 3.
- Release Exit and press Format until the number changes to a 4 - the operation will then begin.
