Originally Posted by
WS65711
Mine look like the M-Card in your top photo. I had to go pull one out to look at it, since I didn't really get to look closely at them before the installer did his thing.
So is this "bad news"?
WhatHappend
The SONY was developed before the M Card was designed. I would see if you can get a Single stream card. The TIVO HD guys need the M CARDS to save them money per month, so the Cable company shouldn't mind doing the swap.
In this case it doesn't matter which card you have. The S card can only support one QAM 256 stream and the M card can support 5 QAM 256 streams or 6 QAM 64 streams at one time. The M card was developed to support dual QAM tuner dvrs by using a single card instead of using two S cards. They no longer make any S cards. By the way both the S card and the M card can be used in single Qam tuner devices that are one way and tru2way capable. The M card is used in single and multi QAM tuner devices that are one way and tru2way capable.
The problem you have maybe related to the wiring configuration that you mentioned in this post:
http://www.avsforum.com/avs-vb/showp...ostcount=18799
If you still have this setup or something simular you maybe having problems with your return path signal dropping out, which causes the card to deactivate which inturns TVGOS see as a cable card removal and sends the guide back to start to aquire a in the clear cable channel list. If the signal improves then the card reactivates which TVGOS sees as a cable card insertion then sets the guide back to start to reaquire a cable card lineup.
In the clear QAM cable and OTA signals do not have a return path signal so you can get away with your wiring configuration but when you subscribed to digital cable services, (Cablecard, cable boxes, and cable modems), then the return path signal becomes critical for proper digital cable operations.
If this is your problem then my advice that I gave you would solve the problem:
http://www.avsforum.com/avs-vb/showp...ostcount=18809
It must be mentioned that older devices with QAM tuners with Cablecard slots have less tolerence to weakend return path signals than do newer Cablecard equipped devices. Cable modems also have a better operational range.
WS65711
Not as far as I know. The HostChan that was set is "0:36-0" which is my CBS digital OTA station.
If this was an OTA host channel it will be "1:36-0". "0:36-0: is the physical location in your cable lineup. If the host and the clock set channel are the same then you are locked onto an in the clear analog host channel or the virtual analog channel assignment of your host station in a cable card lineup.
If you have 0:36-0 as a host and a number like 702 as a clock set channel then you are locked onto a digital host and 36 is the physical location of your host station and 702 will be its virtual channel assignment.
You can check this in the diagnostics part of your sony menu which is mentioned on page 38 of your sony's manual.
http://www.docs.sony.com/release/DHGHDD250-500rev2.pdfQuote:
WS65711
We were watching the LSU/OleMiss game using the family room DVR (which currently has no Grid). I was tuned to CableCard ch-704 (local CBS) and since the ending to the game showed absolute stupidity on the part of coach Les Miles, I attempted to save the last half-hour segment so that my son (who was not home) could see it later. I made the discovery that with CableCard channels, if you do not have a Channel Lineup, it is apparently
impossible to set a manual recording? It repeatedly told me that I could not record
that channel because it was not in my Lineup. I changed to an OTA channel, and found that I could then set a manual recording even though the OTA channels aren't currently in my Lineup either (since have no Lineup or Grid). Can anyone confirm this, or does anyone know a workaround for CableCard channels?
The message you got is not refering to the channel list in TVGOS but the channel list that is stored in your dvr. It is mentioned on page 41 of your owners manual:
It states: The channel +/- list contains all of the channels to which your HD DVR will tune as you use the channel +/- buttons.
Note that the channels that your HD DVR can tune may not be the same channels which maybe listed in the TVGOS program guide.
