Featured Stories
Related Forum Threads
- Updated list of consumer available DVR's in the US Last post on 4/22/13 at 2:47pm in HDTV Recorders
- No Tivo Subscription....works ok? -- TiVo Premiere Series 4 DVR TCD746320 Last post on 1/27/13 at 8:47am in HDTV Recorders
- TiVo Premiere TCD746320 DVR w/2TB drive upgrade & Lifetime Last post on 12/17/12 at 11:58pm in Video Source Items
- Three Mac Mini/EyeTV technical issues Last post on 7/13/12 at 11:28am in HTPC - Mac Chat
- OTA Spectrum Uncertainty & Your Plans Last post on 10/17/11 at 9:58am in HDTV Technical
Related Reviews
Sony DHG-HDD250/500: Official Thread - Page 884
Gear mentioned in this thread:
- izzy900
- Trader Feedback: 0
- Cable with CableCard
- offline
- 197 Posts. Joined 1/2013
- Select All Posts By This User
- izzy900
- offline
Please redirect me if there's another thread about this already.
Has anyone talked about flashing a new OS to the HDD250/500? I'm thinking OpenElec or any older variant of XBMC, or better yet a tweak on the existing firmware to use Schedule Direct. It's over my head, as I'm not a hardware (driver) guy, but it strikes me that the Open Source community could probably figure this out in a weekend. The barrier to entry is of course that modifying aging firmware for aging hardware with limited availability may not be as appealing as more sustainable efforts. BUT! It's a huge opportunity to fight back against corporate greed.
The hardware is well understood:
http://www.avsforum.com/t/1225369/just-whats-inside-a-sony-dhg-hddxx0
And the firmware is publicly available (but for how long?):
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4542&mdl=DHGHDD250
There seems to be a wealth of knowledge on this post about our DVR's, maybe somebody will figure a way to get the listing to the unit!
So far, for me the nicest thing has been the ability to transfer recordings to my Mac via my wireless network using kmttg, decrypt them, and burn them to disc if I want.
<snip>
I don't think I'll be using my EyeTV USB tuner dongle much any more, or my Hauppauge HD PVR which I was using to dub recordings from the Sony's component video outputs.
I use my old Panasonic DVD recorder for dubbing from the DHG's component video outputs. But when the day comes, I'd like to keep it all digital with a TiVo. What software do you use to decrypt the TiVo files? (assuming they are not just MPEG...)
- Kerry
- JoeKustra
- Cable only
- online
- 5,599 Posts. Joined 9/2007
- WaltA
- offline
- 1,129 Posts. Joined 7/2003
Sorry, but that's like claiming that if someone can find the cigarette lighter in a car, that they automatically/always know how to replace the piston rings.
- Kelson
- offline
- 7,964 Posts. Joined 7/2004
Edited by Kelson - 1/23/13 at 10:02am
- Kelson
- offline
- dp70
- Restricted Member
- offline
- 1,226 Posts. Joined 10/1999
- JoeKustra
- Cable only
- online
Same goes for the firmware. Just because you can download a binary firmware update file doesn't mean you know squat about the underlying source code. Comments like "the Open Source community could probably figure this out in a weekend" just make me laugh -- especially when they are preceded by "It's over my head, as I'm not a hardware (driver) guy, but . . . "
- Rammitinski
- offline
- 17,437 Posts. Joined 9/2005
Gary Burgoyne I think I see our problem YOU don't realize that we(owners of certain equipment) NEED a TVGOS SIGNAL, not just the data) to use our equipment. Without that signal our equipment is useless and can't be used for any thing except playback of already recorded programs. By discontinuing the TVGOS signal you've ruined thousands of dvrs and apparently don't know and/or don't care. In the future will you do the same to equipment that now depends on your TotalGuide system ruining their equipment too? People should be made aware of ROVI's history of callous disregard for Sony and now Panasonic customers.
7 minutes ago · Edited · Like
Wow, you really do exaggerate a lot. Every recorder out there with TVGOS except for this one has a way to set the clock manually, and manual timers can be set in the absence of a TVGOS signal.
Rovi's not responsible for that design fault in the Sony. They've hardly "ruined" all the TVGOS recorders.
Edited by Rammitinski - 1/23/13 at 12:25pm
I'll tell you how I'm going to do it. As soon as the guide stops I'm pulling out all the boards and putting in a DH61AG thin mini, 4 tuners, new drives, and maybe a VFD supported by windows. Then run media center.
- JoeKustra
- Cable only
- online
Exactly. We've identified the chips and made some inferences, but the platform is hardly "well understood", particularly at the software level. It's possible in theory to get something like MythTV running on this hardware, but this would require a lot of reverse-engineering work by skilled engineers, and even after doing all that, you'd still have a single-tuner DVR that uses IDE hard drives and consumes over twice as much power as a TiVo Premiere or Mac Mini with USB tuner(s)--either of which you could have up and running in a matter of hours--which is why I decided not to pursue the project. Using the existing Linux-based firmware as a starting point might be possible, but I'm not aware of anyone even doing the preliminary work on that, such as dumping the contents of the flash (which contains the bootloader and main firmware). If you wanted to distribute a DHG-to-MythTV update to others without requiring them to have specialized equipment to install it, you'd have to also figure out Sony's private key to digitally sign your new update so that unmodified units would accept it. There are some serious hurdles.
My perspective is that I have the hardware now, it's worked admirably, and I don't see any particular need to invest in another piece of hardware to support the < 5 hours per week I spend watching OTA/cable TV anyway. Netflix gets much of my time so were I to invest, it'd be all on that end, and I'm happy with my current setup.
BUT, if somebody had done the legwork already, I'd be interested in flashing to a new firmware, or even putting in the work coding if project reached a stage that it entered my area of expertise. The irony is, of all the devices I've acquired in the past 10 years, the HDD500 is one of the very few that has worked well enough out of the box that, evidently, nobody's cracked the thing and posted alternatives on the net. I speak as one who spends most of his non-Netflix media time either watching videos on my WDTV, iPad, or Nook. These are all devices that I could flash to a custom OS had I the inkling (again). Like dp70 said, it's a question of time, and as the device has worked up until now, barring the nightmarish months some years ago with the DTV switch, nobody's invested the time. *Sigh*.
Though, I thought that as a GNU-licensed device, the source was available somewhere? Oh well, I'm off to continue my investigation of HTPC.
- JoeKustra
- Cable only
- online
- joecass
- offline
- 141 Posts. Joined 5/2005
stations like CBS or PBS do not provide some sort of clock signal either through OTA or the cable line. Very disappointing.
- JoeKustra
- Cable only
- online
Yep, my TV Guide disappeared about 10 days ago in NYC. I was able to manually record on the DHG until Monday, when it spontaneously rebooted, and changed the time to an hour earlier than real time. When I'm home, I hear the tuner click on and off repeatedly, as though it's searching for a host channel or attempting to acquire data. I'm surprised that at this point in time,
- izzy900
- offline
I haven't ignored your request. I went to my test unit and removed power about 8am. At 8:30 I applied power. 90 seconds later I turned it on and found that it was almost as if I did a TVGOS reset. Time was 12:00. Reset log said 1/1/90. This has never happened before. I'm rebuilding now and will try again later. My other Sony has been without power for over a month. I gave it power and it still has a lineup which I expected. I will check that one tomorrow too.
Speaking of differences, have you ever run the 1234 diagnostic? Lots of data there, even a signal level for analog. My one unit has 52k hours on its HDD.
I was thinking about your reply, and it seems to me that your date and time after the power was removed reverted back to day one, out of the box! Like a format.slash total TVGOS reset. Hve you done a total reset after the loss of the TVGOS signal?
- JoeKustra
- Cable only
- online
Errr, no. My other DHG that was unplugged for over a month came up with a full grid. I'm letting my test unit run overnight. I already answered the lineup question about two hours ago and have full setup bits. If it does this again I will pull it and try a different unit. This is the first time I had a power removal do a complete wipe. I guess anything is possible. Cosmic rays.
I haven't loss my TVGOS. I just remove the rf for testing.
- izzy900
- offline
I was just thinking, a total format/reset of the unit brings it back to out of the box factory/12:00AM 1990 waiting for the time signal to correct date and time. In my case my unit was stuck on 4:24 AM cause I must have had a power failure and the clock kept that time as its starting off point till it would get the time signal to correct it's time!. So if I pulled the plug dollars to donuts that the time would still be 4:24AM and I could get the time on time if I turned the unit back on at 4:24 AM!..
- JoeKustra
- Cable only
- online
- izzy900
- offline
If you have no time offset and no clock set channel the time could be 1/1/90 or 1/1/04 under various circumstances. Having all the bits set and fully working unit, a power interruption will usually produce a semi-random time. I have seen 4:24am also. If I had the source code I could tell you why. I pulled power at 8:10am, tomorrow I will pick a different time and hope it doesn't lose everything again.
I'll check back later! But if I lose power I will get the 4 dashes this I know! So I will then do a front panel reset and see what happens, and I power up again after the 4 dashes show up! I'll check back later!
- WS65711
- Trader Feedback: +1
- Thread Ender
- offline
- 3,363 Posts. Joined 3/2003
- JoeKustra
- Cable only
- online
- mabuttra
- offline
- 1,866 Posts. Joined 1/2009
- Location: Wichita, KS OTA (w/optional cable connection)
For the record, I've lost the grid a few times just by pulling the plug. The last time was a couple of weeks ago.
Mark
- CleCakYngMfd
- DHG: 653 214 741 Clock & Day Reset at 12am Thur
- offline
- 137 Posts. Joined 2/2009
So, time for another reset, at midnight on a Thursday. And so I did, last Thursday at 12:00am.
And there it is... The date and Guide Clock was set to 1/1/04 12:00am. Now I have the clock and days of
the week in sync. So now, I am doing manual, scheduled recordings.
However, if there is a power glitch/outage or lockup... I will have to do another 12AM Thursday
reset, I suppose. I captured my Scheduled Recordings with my cellphone camera for future reentry.
Maybe one day I will hookup a UPS. However, some sort of lockup will eventually take place.
To help reduce lockups, I try not to be in any menu or be playing any program while a recording
is either about to start or end. (This is where most of the lockups have happened, though it has
happened a few times when I was not near the unit... but it hasn't done that for months now.)
Strange, but when I do the “753 159 852” thing, it eventually shows the correct date/time, but not when
scheduling a manual recording (It still shows '2004'). Different clock? (Edit: Yes.)
I notice that the Clock/Fail Clock channels listed is 0:41-0. Is that a 41 or 41.1 OTA channel?
No Host Channel listed.
Edited by CleCakYngMfd - 2/1/13 at 8:16pm
- izzy900
- offline
- JoeKustra
- Cable only
- online
I believe 1/1/90 at 00:00:00 will always happen doing a Sony full reset. A TVGOS full reset usually gets you the 1/1/04 date. Check the dates in your reset log. BTW, that log is usually wiped when doing a Sony reset or HDD format but not with a TVGOS reset. A power failure (when you have data) is shown as 0x7000. An update to TVGOS is 0x102 and there will always be two if you have the data. Other numbers are unknown but it's a good place to look after something unusual happens, like a spontaneous reset.
The lack of "absolutes" is intentional and all times are UTC.
- JoeKustra
- Cable only
- online
PBS stations were the first to lose TVGOS on Nov. 1. If your host was WVIZ it probably no longer has a TVGOS inserter.
Edited by JoeKustra - 1/24/13 at 5:26am
- Sony DHG-HDD250/500: Official Thread
Recent Discussions
- › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576,... 6 seconds ago
- › New JVC DLA-X75R/DLA-RS56 $7,999 projector with 3D RF glasses and... 1 minute ago
- › BenQ W1070 : DLP Full HD, 3D Ready with lens-shift for 1000$ 1 minute ago
- › Question about connecting the Roku 3 1 minute ago
- › Newbie In need of help deciding between the Sony VW95-ES and JVC... 2 minutes ago
- › The "Official" Yamaha AVENTAGE RX-A1020, RX-A2020 and RX-A3020 Thread 3 minutes ago
- › Star Trek 2 3 minutes ago
- › What are your most recent Hi-Res purchases? 4 minutes ago
- › Power Sound Audio Discussion Thread! 5 minutes ago
- › We moved! The Thompsons' new living room setup and theater! 6 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
