AVS › AVS Forum › HDTV › HDTV Recorders › Sony DHG-HDD250/500: Official Thread
Sony DHG-HDD250/500: Official Thread - Page 886
post #26551 of 28401
Originally Posted by lastplace View Post
Yanked the HDD-250 out of ration last night. It's over.
Mail it postpaid to Sony's president !
post #26552 of 28401
Duplicate post (thought it didn't make it 1st time).
Edited by cxgy - 1/24/13 at 7:11pm
post #26553 of 28401
Originally Posted by JoeKustra View Post
I think the screen being referenced is shown by the Sony link in post #26539. No lineup means no channels to edit with the guide setup. Menu-Preferences lets you select/deselect channels found during a scan. I wonder when I called the DHG a two-headed monster. Years ago.
I too had "There is no data for this screen" in the Guide - however this may mean that the grid is just hidden (all Channels turned OFF) ... and needs to be activated by turning at least one channel on. I don' think you read my post clearly enough. I am not talking about Menu - Preferences - I am talking about TV Guide - Setup - Change Channel Display - Hit Menu on REMOTE. Also see my earlier post below... The only caveat is you may need to have at least been asked to choose a lineup first (though I'm sure this is required).
Originally Posted by cxgy View Post
Edit: SUCCESS !!!
Once you choose the Cable Lineup and still have "There is no data for this screen" - it means that all of the Channels are turned off. In setup, I selected "Edit Channels" and the list appeared...with every channel turned OFF. I turned the 1st channel on ... and voila ... a grid !!!! So, I'm guessing this would have worked on attempt #3 as soon as it asked me to select a Lineup.
post #26554 of 28401
Once you choose the Cable Lineup . . .
That sentence is key. If you don't get that far, then there will be no channels to "turn on" in "Edit Channels".
Unfortunately, most of us won't ever get that far again . . . redface.giffrown.gifeek.gifmad.gif
post #26555 of 28401
Yeah, I was going to mention that. It's ok, we have bigger problems.
post #26556 of 28401
I know I'll never get that far, since being OTA only I never see that message. biggrin.gif
post #26557 of 28401
Another advantage to being OTA only is that I have never seen the message about not being "allowed" to record channels not on the grid. This seems to be a cable / cablecard bug. Even without a grid, a person who is OTA only, should be able to use izzy900's method to keep the guide time correct, so you can make manual recordings without having a Master's degree in math. Of course without a grid the front panel clock would be dashed out for the rest of the DHG's life.
Mark
post #26558 of 28401
I think I had that "not in Lineup" issue once for an OTA channel. And it was before I ever had the CableCards. I posted about it here at the time.. I wish I could find it.
Edit:
Oh well... Brain Fart. I found it way back here, and it wasn't OTA, it was CableCard channels . . .
And there's more info about the issue here . . .
"Investigating further, I discovered that in simply turning on the DVR and attempting to record (using the "Right" button on the directional ring) a CableCard channel that the DVR is tuned to (WITHOUT changing channels) the behaviour that I described in the paragraph above applies. However, if I change to the channel first, then I can in fact record it. I don't know if this is documented anywhere, I don't recall ever seeing it. But then I really never have tried recording this way before, since in the past I've always been lucky enough to have a Grid and Lineup. Obviously on Saturday the DVR was tuned to the proper CableCard channel for the game when I turned it on. So that's why I couldn't record the ending segment of the game. Then afterward when I changed to an OTA channel, it was the "channel change" that allowed the "record" function to work . . . not the fact that it was an OTA channel. I've found that if I turn the DVR on with it tuned to an OTA channel, I can in fact set a recording on that channel without having to do the "channel change" first."
Edited by WS65711 - 1/24/13 at 5:39pm
post #26559 of 28401
I know it may not be a good time. And that a lot of people on this thread are moving on to TIVO! But at least let's not just pack it in without voicing our displeasure at the ROVI site for their abandonment of the TVGOS service! I now have a DVR that I totally relied upon for recording weekly shows and viewing them at a later time, and a Sony TV that I bought for the same usefulness of having a TV Guide! If you take into account all the devices that have been rendered useless, not just Sony products by ROVI's decision to pull out of supporting OTA/Cable devices. We should at least Voice our opinion at the ROVI site on how we feel about their moving on to other markets (internet devices)!......biggrin.gif
Below is the link to the Rovi Facebook page in which I have voiced my displeasure with their decision of non support!
https://www.facebook.com/RoviCorp
post #26560 of 28401
Edit:
I remembered that you had found a work around for that message, but wasn't sure it was the same message that others have reported getting recently. Maybe that will help some of these guys with cablecards when / if they lose their grids.
Mark
post #26561 of 28401
... TV Guide - Setup - Change Channel Display - Hit Menu on REMOTE...
Just tried this awhile ago.  Same result.  Doesn't do anything.  Must have a Grid with Channels to be able to edit.  No go.  Can't 'turn-on' a channel when it's not there, whether it be under LISTINGS or SETUP. frown.gif
post #26562 of 28401
Another advantage to being OTA only is that I have never seen the message about not being "allowed" to record channels not on the grid. This seems to be a cable / cablecard bug...
I ran into this problem awhile back.  This happened after I split and added the Cable signal to my 250 (I have no CC).  I was doing my manual scheduling when the 'not allowed' message came for a channel that I know is OK.
If I remember correctly, I tried another channel which took, then edited the event back to the channel I wanted.  Another time I was entering a channel and the 250 didn't wanna take it.  What I did then and now always do, is SKIP over the channel entry and FIRST select CABLE or AIR, then back up and enter a channel.  Haven't had a problem since.
Oh, this reminds me when I had yet another strange event...  ALL MY DIGITAL (not my analog) CHANNELS went missing!   Did a FPR and scanned channels from scratch.  What an adventure with these units.  rolleyes.gif
post #26563 of 28401
You really need to understand and accept that your "beef" is with Sony and not Rovi. You were never a customer of Rovi any more than you were a customer of any of the component suppliers that went into the building of the DHG. Sony was the customer of Rovi; you were a customer of Sony. You never paid Rovi any money for their service directly -- you paid Sony. Sony contracted with Rovi to guarantee guide service for some period of time and then let that contract lapse.
You bought a device from Sony that depended on a third party guide service -- Sony never guaranteed that guide service would be available for any length of time in their warranty -- Sony did not provide a manual method to set the clock -- the device utility was obviously compromised if the guide service disappeared. All this was known yet people elected to purchase the device anyway -- because they trusted who? Rovi? No, Sony.
post #26564 of 28401
9012 G* Test
OK, I tuned to WKBN 27.1 (RF 41) Youngstown, OH.  It's breaking up and steady for some seconds at a time.
Ran test and here's what I now have:
 Failing Clock Chan      0:41-0
     Clock Set Chan      fffffffd (What does this mean?)
     Last Clock Set      1/25/13 2:30:45 (This is 9:30pm EST)
I'm going to try to put my spare rabbit-ears antenna on the 250 and get a steady signal from WKBN, then run the G* Test again.
If the rabbit antenna is not enough, I'll have to dig out my ClearStream out of the closet and try again.
(The ClearStream is positioned in the closet to pickup all my locals which feeds into my converter box which is hooked into my Philips DVDR-3576H.)
post #26565 of 28401
Originally Posted by CleCakYngMfd View Post
9012 G* Test
Code:
Looks like 27.1 is still sending out TVGOS data. The fffffffd happened when you ran the G* Test. When you run the G* Test it shows the channel which looked like this 1023-65533, that correlates to the fffffffd. Ideally when you run the G* Test it should show the digital channel number 27-1, but it rarely ever does this.
Mark
post #26566 of 28401
I setup my rabbit ears and got a better signal - - - just a brief breakup here-n-there.
Question: When doing the G* Test, this time with Ch 27, the Test ended itself after about 3-to-4 minutes.  Before, with lots of breakup, it ran about 13 minutes.
                  I assume the Test finishes itself when it gets what it wants, yes?
Anyway, I got the same results, except the time stamp was more recent for the Clock Set Chan.
So now, I ran Guide setup again, this time answering NO to "Do you Have Cable" and yes to "Air".
I left the rabbit ears intact to see if by chance I get Guide data.   How long should I wait before turning the 250 back on and check for any Listings?
post #26567 of 28401
I get the message a lot. You DO need to have a grid, but NOT channel listings. Just pick the channel on the blank grid and then edit the time. Assuming the clock is set to whithin 2 hours of desired time.
post #26568 of 28401
Originally Posted by linkstur View Post
...Just pick the channel on the blank grid and then edit the time. Assuming the clock is set to whithin 2 hours of desired time.
Pick a channel?  I have no channel to pick from.  Am I missing something here? confused.gif
post #26569 of 28401
Yes you are right, I should have my beef with Sony for building such a well made device with a 2 flaws. I have a device with no time signal in which I seemed to be one of the fortunate ones that has a grid and found a workaround to get the correct time but not date. And on the Sony side of the problem I can still record up to 2 1/2 hours even weekly cause I got a grid! I just don't have listings and or data for my recording so I have to hunt them down from a group called Unknown! So instead of me having a unit that can record, give me the title of the recording and letting me know what is on through the TV Guide Listings. I have a basically a dumb recorder. And the fact that it is a dumb recorder without titles is Sony's fault.rolleyes.gif
post #26570 of 28401
No. Well maybe experience but that's not your fault. It will come after a while unless you give up.
You have no lineup which means no channels when you hit the guide button. To make a normal recording from the listings is impossible. A manual recording done by tuning a channel then holding down the red button may also be impossible since no guide data is being received. You can still record that channel if you use the guide button, then select schedule, then menu, then manual recording. If you get a pink error, you are using .21 firmware that you now must have since you are in the process of getting TVGOS from OTA. You will need to wait a few days for it to work.
Could you change the "channel 41" to WKBN? Might help somebody near you looking for guide data. For now.
Edited by JoeKustra - 1/25/13 at 4:31am
post #26571 of 28401
The G* Test doesn't look for anything. In the old days (1.2.13) it allowed the user to tell when there was TVGOS data on a channel, but for OTA that functionality was disabled for ATSC channels in 1.2.21. The G* Test never finishes, because it isn't doing anything that it needs to finish.
The best thing to do is run the setup (like you already did), and set the zip code (you may have to set it to a youngstown zip code). Then turn off the DVR, and let it do its thing (the G* Test does not help the DHG find data, it must do that on its own. Since you have a grid you should already have listings by now.
Mark
post #26572 of 28401
The G* Test doesn't look for anything. In the old days . . .
Wait! Stop right there!!! Make the "In the good old days . . . " biggrin.gif
post #26573 of 28401
Well, at least I have a high quality tuner with RGB outputs for my remaining two SD TV sets, both trinitrons....
post #26574 of 28401
Argh!
I give up trying to explain this. In the rare case like mine - I had a HIDDEN grid even though the listings (where the grid normally shows up) said "There is no data for this screen". I'm not saying that this is always the case....in fact it's rare. I was just pointing out that sometimes this is a possibility. This has happened to me 3 times over the time I've owned the Sony.
You DO NOT always need to have a grid in order to get a grid. No grid DOES NOT MEAN that a hidden grid with ALL CHANNELS TURNED OFF might not be not lurking underneath waiting for YOU to manually turn at least one channel on. This is likely an "in-between" state - where the guide channels have been loaded into TVGOS, but for some reason none of the channels have been turned on yet. Normally when TVGOS asks you to choose a lineup THEN it compares the lineup with the channels you have scanned in via the tuner - and turns only those channels ON.
So for SOME people, this may help them recover a grid - it might be their last chance. TV Guide - Setup - Change Channel Display (push select to show empty screen with msg) - Menu on REMOTE - Edit Channels.
post #26575 of 28401
Roll your eyes if you feel you must, but the fault does not lie with Rovi Corp. Sony designed the DHG to be dependent upon 3rd parties for the clock and grid/guide.
We can piss and moan on Rovi's facebook page till the cows come home, but it isn't going to change anything. The decision was made, and they're not going to revert it.
post #26576 of 28401
Argh!
Argh!
The GRID is the X-Y spreadsheet-like formation that appears on your Guide screen, having the program time blocks listed on the X-axis, and the channel numbers listed on the Y-axis.
The LISTINGS are the spreadsheet-like CELLS that appear on your Guide screen, having the program names inside them.
You can have a GRID but not LISTINGS and still try what cxgy suggests, however if you have NO GRID you cannot try cxgy's suggestion.
Would someone please post a picture of a Guide screen having a GRID but no LISTINGS so that it is clear for everyone?
post #26577 of 28401
How long should I wait before turning the 250 back on and check for any Listings?[/SIZE]
Things are simpler with an analog host (like the one I have on cable). A grid normally shows up after an overnight (10:30pm-5:30am) shutoff.
With a DTV host, I found it sometimes takes 2 or 3 days for the grid to come back (although I recently tested CKCO-DT and it only took overnight). I think others on this forum have waited even longer. I have no explanation for this.
post #26578 of 28401
Argh!
Sorry bud, you're wrong. You've just never seen it happen yourself. I had no grid but recovered it - I'm not some newbee.
http://www.dxinfocentre.com
Next time it happens, I'll post pictures.
post #26579 of 28401
[1] A manual recording done by tuning a channel then holding down the red button may also be impossible since no guide data is being received.
[2] If you get a pink error, you are using .21 firmware that you now must have since you are in the process of getting TVGOS from OTA. You will need to wait a few days for it to work.
[3] Could you change the "channel 41" to WKBN?
[1] Red Button recording works OK, even without Guide Data.
99% of my recording setups are done via the "New Manual Recording" option.  I have a clock and the correct day of the week.  I have  2-and-a-half pages of programs setup this way.  While the year and date are 'wrong', the clock is accurate:  When I play, The Rifleman, right-off McCain is blasting away 12 shots right at the start of the recording [MeTV - WOIO 19.2].  smile.gif
[2] No Pink error with 1.2.21, unless I have 'conflicting' scheduled recording setups.  I had the 250 off for over 6 hours.  No data yet.  I'm trying again with a YNG zip.  If no data by later this afternoon, I'll try again next week with multiple nights of at least 8-to-12 hours of being off.
[3] Done.
post #26580 of 28401
OK sorry, there was an error in my recovery description. If you see "There is no data for this screen" in the Setup - CHANGE CHANNEL DISPLAY - the place to find the "edit channels" command is under TV Guide - LISTINGS - Menu on REMOTE - edit channels. This is how you can unlock your hidden grid.
PS - If you want to force a "There is no data for this screen" message on your Listings, just go to the Channel Editor and turn all the channels OFF. However if you do this, you still get a functioning Channel Editor. It's only when trying out a new host when both the Listings AND the Channel Editor might have the "There is no data for this screen" (and thus no channels to turn ON). For some reason the Listings-edit channels command can bring up the Turned-Off channel list even though the normal Channel Editor shows nothing.
Edited by cxgy - 1/25/13 at 7:29am
  Back to Forum: HDTV Recorders
