AVS › AVS Forum › HDTV › HDTV Recorders › Sony DHG-HDD250/500: Official Thread
Sony DHG-HDD250/500: Official Thread - Page 917
post #27481 of 29213
Originally Posted by WS65711 View Post
DST goes into effect on March 10th. Your DHG thinks it is February 28th? Then it won't sail forward an hour until IT thinks it's March 10th. smile.gif
"Sail forward". That's good.
post #27482 of 29213
Originally Posted by izzy900 View Post
I kinda like to see the channel I'm watching, getting up there in age..wink.gif I will stick with .21, use 00000 as the zip and auto off set to off. This should address the buggy issues reported after the loss of TVGOS data and I like to at least have the channel name showing that I am watching...rolleyes.gif
Well, to each their own, right?... I hated that "not in lineup" error more than any other DHG quirk, so I installed .13 last week. Oh, and I still have the channel number and call letters on the FP when watching live TV. Maybe that comes from the cableCard.
- Kerry
post #27483 of 29213
Those of us with resets back to '04 also have a Feb 29th, since 2004 was a leap year, so I believe March 10th will fall on a different weekday. If the DST routine is based on numerical day, rather than DOW, you might not spring ahead for another day. Of course, I lost the patch, and my DHG date is still in January, so I'm not even going to calculate when/if the machine will automatically make a DST change.
- Kerry
post #27484 of 29213
- Kerry
No more pink screens?
post #27485 of 29213
So far it seems that if I have been successful in recording programs using the manual recording method (NO GRID). rolleyes.gif Even though I have to tinker sometimes for the DHG to accept the recording schedule, (Channel not in lineup!) by changing channels, turning off, turning on! Ya know foreplay before acceptance...rolleyes.gif I have recorded 3 scheduled programs as long as they are scheduled, and regardless that the unit says Channel is not in Lineup! wink.gif
If you don't mind me asking - exactly HOW do you get the Sony to do this? I've tried, even when TVGOS was working; but my 500 would randomly tel me Channel not in lineup.
How does changing channels and turning off and on help?
Thanks - it would be nice if my doorstop would at least do SOMETHING. smile.gif
post #27486 of 29213
Originally Posted by myoda View Post
Windows Media Center in 7 uses rovi for their guide data provider.
In WMC, if you look at the "About Guide Listings" section, you will see that the guide data is actually provided by Zap2It, not Rovi. (Though I'm looking in Vista right now, not 7).
Edited by cxgy - 3/6/13 at 11:31am
post #27487 of 29213
- Kerry
post #27488 of 29213
Zap2It gets its listing data from Tribune Media Services. Wiki lists others, but I don't know how current that data is since it also lists TV Guide and TiVo.
post #27489 of 29213
You can slow it down with a capacitor across the crystal. Check the forum. And my 515H is on a UPS too.
cool.gif Has anyone come up with a circuit to increase the frequency of the crystal to bring the clock up to the right time? Something that could be switched in/out?
post #27490 of 29213
Tribune Company is Zap2It's parent as they say on their About Us page and where they show these contact addresses:
Postal Addresses
  • Tribune Media Services, 435 Michigan Ave. -- Suite 1300, Chicago, IL 60611
  • Zap2it, 5800 Sunset Boulevard, Hollywood, CA 90028
post #27491 of 29213
On what?
post #27492 of 29213
On what?
For the Sony DHG...
post #27493 of 29213
For the Sony DHG...
I've never seen a crystal in the DHG. I'm sure there is a circuit somewhere. Maybe next to the battery? [joke]
post #27494 of 29213
Zap2It gets its listing data from Tribune Media Services...
Indeed.  I use it all the time.  I have Win7, Media Center, and the Hauppauge WinTV-HVR-2250 (Dual Hybrid TV Tuners).
The HD is awesome with my 24" monitor.  I need another hard drive.  Disk space is low. rolleyes.gif
post #27495 of 29213
Zap2It is a 13 day guide. TitanTV is 14 days. TVGuide.com is 15 days. Each has its attributes.
post #27496 of 29213
How big is your UPS? If small, please come back and tell us how you feel about no clock fix after a power failure or spontaneous reset.
Originally Posted by teleskier View Post
I don't have a UPS. I probably should, but since most of the power outages (out here in our rural setting) last several days... I'm not sure the cost buys me anything. Sure, it'd save me against short glitches, but not the typical multi-day affairs.
Has anyone tested the DHG on a UPS for a day or two?   Could a decent size UPS hold out that long?
post #27497 of 29213
Anyone without power for over a day probably had more to worry about. However, I have gone 12 hours with two DHG 250 units running and a few items using just vampire power. That was my longest outage and I should have pulled the power, but I wanted to record some shows. I had (at that time) an older APC 1500VA BackUPS with a battery pack. I have since replaced it with a newer model - same rating. I also used an inverter on a 1000AH marine battery to run my fridge and oil burner. That was in 2011. Last year I only had 6 power failures. This year I have had two, both under 5 seconds. A different 1500VA UPS runs this desktop and my router, modem and other stuff. I have two small UPS units that run my bedroom TV & DVR and one runs the attic FM amplifier.
post #27498 of 29213
I do not think I would go that long (from Jan 1 to Mar 10) between resets.  Clock drift would be pretty big anyway. So, other than this-n-that and the other...  it is SLICK SLIDING!     biggrin.gif
post #27499 of 29213
Slip slidin' away
Slip slidin' away
You know the nearer your destination
The more you're slip slidin' away . . .
post #27500 of 29213
I knew I could count on you.
post #27501 of 29213
The night cometh for reset testing.
Final Reset Target Time:  11pm.
post #27502 of 29213
Originally Posted by mossie View Post
In the setup I changed the tune to channel from the HD channel to the SD station, then tuned to the SD station, then manually set the recording and changed the channel there in the edit recording box over to the HD channel I wanted, and it takes it. Hopefully it will record it.
Tonight tried manual recording and kept getting the pink screen not in your lineup nothing I tried was working like before. I was getting nervous because after 10 mins of trying my program was on and I couldn't get it to take the HD channel. Finally after 15 mins it worked and I tried so many different things I don't even know what I did to make it stick. This is crazy stuff.
post #27503 of 29213
post #27504 of 29213
That sounds just like what I went through before I loaded the .13 firmware. There was no way to pin-down a sequence of inputs that could produce consistent success. In fact, I wonder if simply waiting 15 minutes would have done just as well.
I am interested to see how long people put up with that struggle before "going 13".
- Kerry
post #27505 of 29213
And that my friend is why I say to get the schedule to take way before the show starts, or you may get one of those that just won't take. Or you will lose part of the program till it takes...rolleyes.gif
post #27506 of 29213
Since I have gone for a record six days without a crash or auto-reset, I am going to wait until next week for my DST warm reset. The machine hasn't been so stable since 2008 (before I had a cableCard), so I'll adjust recording times for a few days instead. I'm curious to see if I can go two weeks without a problem.
- Kerry
post #27507 of 29213
So can I go down in firmware from 1.2.21 to 1.02.13
post #27508 of 29213
Of course you can. What are you fearing might happen wrong?
post #27509 of 29213
Here is WS65711's link for you...
http://av-pix.com/DHG_Firmware/sony_dhg_fw_1.02.13.zip
- Kerry
Edited by KerryNY - 3/6/13 at 6:21pm
post #27510 of 29213
I had to be very sure before trying it myself, but I am very glad I did!
- Kerry
  Back to Forum: HDTV Recorders
