Okay, still struggling with TVGOS. Is there ANYONE in the LA area (using Comcast) receiving the data over cable? For a couple of days, a couple of weeks ago, I got the data via channel 3, cable. Since then, nothing. I can get the channel line-up and time over-the-air, but no program listings and I thought it might be a weak antenna signal. So, I wanted to get the info over cable, but nothing is showing up after three-four days, not even the time. I've tried changing zip-code, re-setting via front pannel, factory re-set via 9012 menu, choosing both "Cable and ANT" and unplugging the ANT, but it still won't find the host channel. Every night, no change. This thing hasn't been on for more than a minute a day for the last week. I've done the VBI test on channel 3-cable, and it passes, 125 or so packets a minute.
I need to know if it's just me, or if it's a futile quest to get the damn guide over the cable. Is it working for anyone else at all? (and no, I'm not using a cable card, just a direct feed from the wall.)
