it is beginning to sound like a local PBS analogue issue.....you DFW guys should email them.......to see if they are sending out the clock?
Here is a little test I just did on our equipment:
1. Samsung HLS DLP set
2. Old Sony VHS tape
3. Sony DHG-HDD500
The tape machine sits on top of the HDD500
99% of the time those two clocks are sync (very rare they are not - but I have seen them off a min or two........but always self correct themselves quickly)
The Samsung TV pulls it clock from wherever? This Samsung shows the time that the station is sending out "at" that point in time. The quick test through several channels show it can be up to 3 minutes off from the PBS 8-0; that is each station is a little different.
Our PBS ananlogue is 8-0
When I hit the "info" button on the Samsung for channel 8-0 its time is about 45 seconds ahead of the VHS and the HDD500.............But I guess??? The most important part about this is, I am receiving a clock time from the PBS ananlogue.
I think most Samsungs, Sony's, and Mit's TV's do this? I do not know about Panasonics?
That is not to say with 100% certainty that the PBS TV analogue time is the exact same as the HDD500 and VHS time........but I kind of think it is? Even tho there is a 45 second difference?
3. Sony DHG-HDD500
