I have had my Panasonic PX50PXU for a little over a week now, and not long after it arrived I started seeing the dreaded Rainbow Effect on the set. Yes, it IS RBE. I know this is supposed to be an issue that only affects DLPs, but apparently I can see it on this plasma as well. I had a DLP for about a week and a half, and I returned it due to RBE, so I know exactly what it looks like. I also had an RP LCD which had NO rainbows. The effect on the plasma is exactly like the DLP rainbow effect, quick flashes that show up during high contrast scenes with sharp edges; it's an obvious optical effect, not an effect on the screen. There is one difference though, on the DLP I saw the usual three color rainbow. On this plasma I only see yellow flashes. Nevertheless, they are just as distracting and annoying.
I've tried to figure out how a plasma could produce RBE, since I'm sure if this was a normal plasma problem someone else would have seen it by now. The one thing that's different about the new Panasonics are the sub-pixel controller, so I am suspecting SPC may be the culprit. I don't know exactly how SPC works, but I found the following blurb on Panasonic's UK site:
Panasonic UK Viera link
Seamless lines for a superior picture
The new TH-37PE50 and the TH-42PE50 offer seamless lines that allow pictures to look more refined than ever before. The VIERA's Sub-Pixel controller eliminates jagged or blurred diagonal lines to produce smoother, more defined contours to shapes, resulting in a picture that is second to none. Conventional systems process the RGB signal together, but the Sub-Pixel controller processes each colour separately, thus generating crisper, more natural looking images that are sure to impress.
Though it doesn't go into detail, the bolded section above mentions processing each color separately, which could certainly introduce time delays that might affect each color differently, thereby causing them to separate the same way the DLP color wheel does. The flashes I see are yellow, which suggests that red and green are synced (combining to produce yellow) but blue is not.
Does this sound plausible? Is there anything else that could cause rainbow-like flashes like I've described? Has anyone else seen this, or am I lucky number one? And most importantly, does anyone know if SPC can be turned off in the service menu? Obviously, if it can't my only other option is to exchange for a model without SPC and hope that's where the rainbows/flashes are coming from.
