Originally Posted by
teekaybee
Anybody who actually likes and is keeping this TV (as I do and am)............what modifications worked out the best when calibrating in the service menu? Any suggestions?
This was posted earlier in this thread by "bocmir:"
Well, if you don't know already, to get into the service menu: with the set turned off, on the remote press MUTE, 1, 8, 2, POWER. That'll take you to the service menu. The menus you should be concerned with are DEFLECTION, VIDEO ADJUST 1 and VIDEO ADJUST 2.
Deflection handles geometry. To minimize overscan, you want to focus on the first four settings: V-AMP and H-AMP control how tall and wide the screen is (stretching, literally), V-SHIFT and H-SHIFT control the centering of the screen, vertically and horizontally. It works best to shrink the screen down quite a bit, on both planes, so that you have black borders all the way around. Then use V and H-SHIFT to center the screen. Once you're centered, use V and H-AMP to get your picture back to full screen. Be sure to go a few clicks over. Some feeds aren't quite as "big" resolution-wise as others. Make sure you test your settings with HD channels, standard channels, and any inputs you have like DVD, video games, etc. My settings are:
V-AMP: 26
V-SHIFT: 24
H-AMP: 20
H-SHIFT: 24
Once you have overscan eliminated, the other entries on this menu you might want to tweak are H-PAR, UP-COR, LOW-COR, H-TRA, BOW and ANGLE. Don't bother with the rest. I haven't seen them make any difference. I can't really explain to you what each of these does specifically, because honestly, I don't know. Just make sure to WRITE DOWN YOUR DEFAULT VALUES before messing with these, or anything. Set aside a couple of hours for tweaking and I'm sure you'll get good results. A copy of DVE and Avia running a geometry test pattern in the background helps. Just so you know, when in the service menu, your TV will still display the picture of whatever's connected to your selected input in the background, which definitely helps.
Video Adjust 1 deals with a few important settings. Only modify CTI_LEVEL, COL_AXIS, LTI_LEVEL and MELODY VOLUME in here. I haven't touched anything else. If you want to get rid of the annoying chimes that play when you turn your TV on or off, changed MELODY VOLUME all the way down to 0. COL_AXIS handles "red push". A setting of 1 (not 0 for some reason) turns it off. This is definitely recommended. CTI_LEVEL and LTI_LEVEL handle enhancement of chrominance and luminance; I turned them both down to 0 for a more natural picture.
Video Adjust 2 deals with the other very important stuff. Only modify GAMMA, DPIC_LEVEL, DC-TRANS, VM_LEVEL and SHP_CD. GAMMA, DPIC and DC-TRANS are all somewhat similar. Lower them. Turning them higher will make the picture darker and eliminate shadow detail. I recommended setting all three to zero and then using the basic "brightness" control in the regular menu to control everything else. SHP should also be set to 0 to prevent more artificial sharpening of bright colors. And of course, we come to VSM. Set VM_LEVEL to 0 to do away with the evil velocity scan modulation. You can even set it to 1, but I don't recommend any artificial effects.
When you're done tweaking, just hit power. When you turn your set back on, your settings will be reset, so be sure to take the TV off Dynamic picture mode and set it to custom or even movie. I suggest calibrating with DVE or Avia to get the best picture. Remember, though, ALWAYS record your original settings as there's no way to get them back. And a lot of this is trial and error. You'll probably be turning your TV on and off quite a few times to get to a picture you like best!
A properly calibrated set will probably look much different than factory settings. Let your eyes get used to it and they'll thank you. It will be more like looking through a window than watching TV.
