Originally Posted by
iLuveKetchup
My input signal's resolution (via components) will be 720p (from xbox360). Since the Slimfit's native resolution is 480p (please correct me if I'm wrong), does that mean the 720p signal will be scaled down to 480p?
I'm not sure where you got the idea that the signal would be scaled to 480p (hope it wasn't anything I wrote), but that's not true. 480p is a vertical resolution spec (precisely, it's the number and mechanism of displaying scan lines), and the Slimfit can do true 720p and 1080i vertical. The issue with this set is that the horizontal resolution does not match the vertical, being only on the order of 500 lines (or "dots") across the entire width of the screen. But your game console signal will not be scaled as far as the vertical resolution is concerned.
iLuveKetchup
Will a HDTV with a native resolution of 1366x768 (i.e. Samsung's LCD) be that much better in picture quality (since the 720p signal will be a 1to1 pixel match)?
The 1366x768 display will have far better horizontal resolution than the Slimfit, and this will be visible on some material, but remember that gaming involves a lot of high-speed action, and, subjectively, the human eye will be much less sensitive to resolution under these conditions. My best guess is that you'd be able to see the difference if you're looking, but that it wouldn't bother you in the least during actual play.
x
