If I have calibrated with Avia on my dvd player with component cables, then what is the best way to calibrate the HD signal that I am receiving via a set top antenna? Can I just transfer the settings that I have acheived thru component over to the HD side and it will suffice?
Also, what is the setting in the service menu that people are using to eliminate the red push? I would like to see some other peoples settings with the Slimfit. Anyone care to share?
