Originally Posted by EL
Dennis,
I'm just curious,
what is the nature of your problem? and what is the equipement (DVD & proj)?
Emmanuel
I received tech support response back from Algolith. Since the Dragonfly does not have a front display, you can get lost in a unsupported resolution. Algolith advised me that to reset the resolution back to 720x480p60 with the remote press "format" then "1" (for PAL users it is "format" then "2" for 720x576p50). Algolith also advised that a resolution change can take up to 20 seconds, so one should not go and press remote button repetitively.
I have a SONY "Ruby" 1080p projector. Last night I spent a lot of time trying out different resolutions and inputs into projector. I will post a recap later of my progress including successes and failures. Let's just say for right now at the end of the night I was pleased. :)
