Originally Posted by wjchan
I believe someone posted that Mosquito specifically looks for the 8x8 blocks and, therefore, works best with unscaled input. As far as MPEG4 vs MPEG2, I read that MPEG4 is also block-based. I could be wrong.
It's not just the compression scheme being being block based that matters, its the encoding scheme that counts more so.
According to Algolith, the Mosquito is designed to specifically process MPEG2 material (see page 4 of the manual). How well it will perform on MPEG4 is to be seen -
mainly because MPEG2 is DCT based and MPEG4 is wavelet based.
If the Mosquito is expecting MPEG2 decompressed data, flagging suspect blocks, then is doing its funky processing then great. However if MPEG4 was the source, then the nature of the artifacts have changed. There might be enough differences in the artifacts (Gibbs, quantization, et. al.) that the processor may perform sub-par.
Without knowing what type of filtering they are doing - the effects, improvement or DE-provement, are not known until wavelet like data is used. I imagine a dedicated AVS enthusiast could do some experimentation if they had some high quality input data, a Mosquito, a HTPC, and some decent compression software.
I suspect processing MP4 will help only minimally and HOPE that it does not additively add to any degredations.
