Where I live in Maryland their are no outlet fees, but a HD box cost $9.95 per month. Since they predict the new HD DTAs to cost Comcast less than $50, hopefully the rental charges will be low and maybe they will supply several free ones when they encrypt all channels which will render TVs with a QAM tuner useless.
Featured Stories
Comcast Technology Topic - Page 25
AVS Top Picks
post #722 of 779
9/20/12 at 9:46am
- slowbiscuit
- Trader Feedback: 0
- FUBAR
- offline
- 3,427 Posts. Joined 9/2004
- Select All Posts By This User
Same here - the outlet (digital mirror) fee is bundled into the ripoff $10 charge. If I can lease a D* DVR for $6/month, there's no way a simple HD STB should cost $10.
But we've had this complaint for years about Comcast, and they try to apply the same BS to cablecards even if you don't rent their boxes.
- PaulGo
- offline
- 3,505 Posts. Joined 4/2003
Digital transport adapters expand their horizons
HD DTAs step up to the plate
From an inauspicious start as a low-cost, one-way, channel-zapping device for analog TVs, DTAs have evolved into more complex devices that are capable of working in various environments.
Comcast is conducting a large-scale trial of HD DTAs and plans on deploying them in subscribers’ homes later this year. Reynolds said that the HD DTAs represent the last piece of its analog-to-digital conversion, which is known internally as “Project Cavalry.” Comcast expects to have the all-digital project wrapped up by the end of next year, which includes the rollout of HD DTAs from vendors such as Pace, Technicolor, Motorola and Evolution Digital.
“We have been in field trials for a number of months, and the technology is working well, and all of the devices are stable, so all systems look good,” Reynolds said.
Evolution Digital's Brent SmithEvolution Digital President Brent Smith said that HD DTAs could be used by smaller cable operators that want to offer an entry-level HD service without using expensive set-top boxes, or to provision second, third and fourth TVs in a home.
Reynolds and Smith both pointed out that analog TVs are largely no longer available in the United States, but HD DTAs allow customers to access HD signals without the frills of VOD, pay-per-view or more expensive equipment in the home. By using an HDMI connection, customers can opt for an analog-type viewing experience on their new HDTVs through the use of HD DTAs.
“It turns out that HDMI is a great way for us to do an install,” Reynolds said. “It’s very simple, it’s one cable, it’s a broadly adopted standard and all of the CE devices support it. It’s an easy way for us to do an install, and, in particular, it’s an easy way for us to enable self-installs by the customer. So that was really why we moved to the HD device, which was to support these newer HD sets and, of course, the move to HD picture quality, which we think is going to be great too.
“We also think our customers will appreciate getting the HD local services that we offer through the basic tier through the DTA devices.”
BendBroadband and Cable One have also signed on to use HD DTAs in their footprints with Evolution Digital and Nagra, respectively.
BendBroadband is using HD universal DTAs (uDTAs) to serve the hospitality market in its Bend, Ore., system. BendBroadband is using wall plate DTAs from Evolution that fit over the cable junction boxes. Evolution’s HD uDTAs were designed to work with both Motorola and Cisco headends, and BendBroadband was the first cable operator to install them.
Evolution Digital's Liberty HD uDTA“Building the box was less of a challenge,” Smith said. “Making sure the box could operate in a standard implementation by Cisco or Moto was the bigger piece because there was more effort required to upgrade the control systems, to support it, and also some additional security levels which needed to be put in place.
“The hardware wasn’t the long pole in the tent; it was more the integration piece. Now we have a viable option for most operators to choose between SD and HD, whether it’s for bandwidth reclamation or offering lower-cost HD tiers.”
While the concept of HD DTAs has been around for a while, the cost needed to get down to a price point that would get cable operators to bite. Thanks to new chipsets, HD DTAs go for roughly $50 each in high volumes.
“When we started, we were looking at much heavier hospitality-specific products that were really designed to provide all of the functions and features that the hospitality industry may want, but when we got down to it, price became very important to those customers, and many of them had other methods to meet the needs of things like check in/check out,” said BendBroadband CTO Wade Holmes. “What really became important was HD for their sets and a low-cost device to connect them. Their preference was that it not be a two-way box because they didn’t want to create processes and procedures. They wanted to eliminate the guide, and they wanted it to be extremely simple to use.Nagra's HD DTA
“The DTA was a perfect fit for us. Keeping it small and low-cost were some of the things we were really battling against when we were trying to find the right solution for the hospitality market. Evolution did a good job of looking at what the customer need was.”
Reynolds said Comcast was also interested in using Evolution’s wall plate HD DTA for hospitality deployments, multi-dwelling units, and bars and restaurants.
“It would be a device that is permanently installed, so there would be no intention of sending those devices out to customers for self-install, for example,” Reynolds said. “The device would be installed in the unit, and it would remain installed on a move in/move out basis, or in a hospitality situation, it would remain in the hotel room or campus environment.
“We do the same things for other commercial accounts. You can go into bars and restaurants, and there are DTAs in there. Health clubs have actually been one of the areas where we’ve deployed a lot of DTAs. They use an IR blaster technology to control the DTAs. If they’re screen-mounted on an elliptical trainer or on a stationary bike, they’ll just use a DTA on a one-per-one basis.”
Breaking up the duopoly
DTAs can also help break up the Motorola and Cisco duopoly by offering an alternative that costs less, according to Tom Wirth, senior vice president of Nagra Americas.
Nagra's Tom Wirth“What we’re pitching is that a lot of operators can move away from the legacy duopoly and go with a new CAS (conditional access system),” Wirth said. “That opens us up to all kinds of things. Not only can you get DTAs from all kinds of manufacturers, including Asian manufacturers, but then you can start to look at more innovative products in the network as a whole, and you don’t have to go through the two legacy vendors’ CASs and kind of wait for them to deploy and come up with a product strategy.
“We were the first to have an HD DTA in the field with some of our partners, and we did all of the software and the CA systems. I think we were at least nine months ahead of the legacy CA in that area.”
Wirth said that in addition to being able to offer HD services, HD DTAs are somewhat future-proof since they support MPEG-4.
“The advantages with the new chipsets and the price point are you not only get to HD, but you get MPEG-4 in the network, which has a huge efficiency factor,” Wirth said. “The DTA is a good sweet spot for an operator to start to move from analog to digital. The problem is that if you looked a couple of years ago at the price point for MPEG-4, it was probably prohibitive, but now it’s not.”
The future is bright for DTAs
Work is currently underway on the next generation of DTAs, which includes the addition of an Ethernet port. E-DTAs could solve the encryption problem for companies such as Boxee, even if the Federal Communications Commission allows cable operators to encrypt their basic tiers. Reynolds said that while E-DTAs are still in the planning stages, they could be available by early next year.
From its humble beginnings, the DTA has transitioned into a more prominent member of cable operators’ CPE family, and it looks to have a long lifespan, as well.
“We will certainly continue to push forward on the technology of the DTA to make them smaller, more powerful and figure out ways to make them more energy-efficient. All of those good initiatives we have in place,” Reynolds said. “The DTA has become an ongoing part of our product line, and we’ll continue to support the DTA for many years to come.”
Evolution, Rovi join forces on adding feature-rich guide to DTAs
While providing a low-cost viewing option for subscribers and businesses is one of the key form factors of a DTA, ease of use is critical to the viewing experience.
On that note, Evolution Digital is working in tandem with Rovi on adding the latter’s electronic programming guide into its SD and HD DTAs.
Rovi guide
Evolution Digital is the first announced customer for the Rovi DTA Guide that was introduced last year at the SCTE Cable-Tec Expo in Atlanta.
As part of its all-digital conversion project, Comcast has championed the use of the low-cost DTAs to reclaim bandwidth that can subsequently be used for additional services, such as DOCSIS 3.0, or more features, such as adding more HD channels.
“We’ve always been major proponents of putting more functionality on the DTA,” said Evolution Digital President Brent Smith. “It’s one thing when you have 40 or 50 channels and you can zap through them, but it’s another thing, especially with HD, with potentially hundreds of channels. People’s expectations are, ‘I want to know what’s on, when it’s on,’ and so forth.
“We discussed this with Rovi and explained what we were doing and why we think it’s a good idea for DTAs. They were enthusiastic about it, and they have plans to have a full Rovi program guide embedded into our DTAs.”
Currently, Evolution has a “now and next” user interface (UI) embedded on its SD DTAs and HD uDTAs. The current UI allows viewers to go through channels to see what’s on now and what’s on next with basic descriptions of the programming.
The Rovi DTA Guide, which will come in HD and SD flavors, brings many more digital-like features to the viewers’ living rooms. It has parental controls and supports both English and Spanish languages, and it also features a “now and next” function.
“It’s a very elegant guide that provides 24 hours of listings data,” said Sharon Metz, Rovi’s vice president of vertical marketing for service providers. “It enables the consumer to see what’s on the full, generally digital lineup, typically about 77 to 80 channels, and provides descriptive information on the programs.
“What’s unique about the guide is that you have the full-feature grid and descriptive information on programming, but you also have a now/next banner that lets you browse while you watch TV and lets you see what’s on. It’s really a great opportunity to extend the interactive program guide experience into homes that wouldn’t normally have that kind of capability.”
In addition to the now and next UI, Evolution also provides an electronic program guide server that operators use to deliver the guide data to the DTAs. When the Rovi DTA Guide becomes available, operators that have a relationship with Rovi can send software updates to the DTAs in customers’ homes to download and launch the new Rovi DTA Guide on Evolution’s DTAs. The Rovi DTA Guide uses components of EBIF technology to deliver the application and data and render the guide onscreen.
Rovi isn’t saying when the guide will be commercially available, but Rovi’s press release from Expo last year said that an SD version of the DTA guide would first be launched in Latin America, which is a good fit due to the larger number of analog TV subscribers in some regions.
As far as other DTA vendors, which include Pace, Motorola, Cisco and Technicolor, Metz said there was some integration work to be done, but the flexibly of the guide would support multiple vendors.
“The expectation that we have is that everyone wants to have a guide on a DTA product, and we’re making that possible for our customers,” Rovi’s Metz said. “As we look at our historical information on how consumers value the guide experience, their passion to be able to quickly find out what’s on the TV and tune quickly from the guide and things like that, we think this is a great way to extend additional value into subscribers’ homes that never had digital service.”
Comcast’s Steve Reynolds, senior vice president of CPE and home networking, said Comcast has worked on a user guide with Rovi, which is known internally as “Atom,” and that is has been demonstrated at several trade show conferences this year by vendors.
SD DTA bandwidth savings
By deploying SD DTAs, cable operators can reclaim between 250 MHz and 300 MHz in each system that goes all-digital. If a typical cable system has 79 analog channels, and the operator decides to move 59 of those channels to digital, while perhaps leaving 20 or so as a lifeline analog service for some select markets, it would reclaim 354 MHz.
Given 354 MHz of reclaimed spectrum in the example above – and the fact that, on average, 10 standard-definition MPEG-2 digital programs can be inserted into one 6 MHz slot – this yields enough bandwidth for nearly 590 channels.
Full article with pictures at:
http://www.cedmagazine.com/articles/2012/09/cpe-digital-transport-adapters-expand-their-horizons
Rovi guide
- PaulGo
- offline
Meet Comcast's IP-Only Set-Top
October 3, 2012 | Jeff Baumgartner
Comcast Corp. (Nasdaq: CMCSA, CMCSK) has picked Pace plc as one of the suppliers for a new IP-only high-definition video client box in development called the XI3, Light Reading Cable has learned.
Because it's IP-only, the XI3 won't contain a QAM tuner. It's anticipated that the XI3 will use Comcast's new cloud-based user interface and obtain linear video from a primary gateway that can transcode QAM video into IP streams that can be shuttled to the client box via the home network.
Light Reading Cable first reported in April that Comcast was developing an IP client box called the X3.
According to a source familiar with the product, the Pace XI3 is based on the Broadcom Corp. (Nasdaq: BRCM) BCM 7428 chipset, supports MoCA 2.0, and features HDMI, Ethernet and USB ports, and an option for a 802.11n Wi-Fi module. Comcast declined to comment on the project.
Comcast's still developing the XI3, but here's what it apparently looks like.
And what's with that SD Card slot? The XI3 doesn't have an internal hard drive, so the slot could be used for memory expansion. But it's also plausible that Comcast could use an SD Card as a local, mini-DVR that could buffer a small amount of live TV programming for trick-play functions (pause, fast-forward, rewind, etc.). Advanced Digital Broadcast (ADB) toyed with the notion of using an SD Card as a "lite" DVR for a tru2way "set-back" box it showed off in 2010.
The XI3 is also an obvious candidate for a network DVR that Comcast is testing in the Boston area.
It's not known when Comcast plans to deploy the XI3, but it's not expected to show up until 2013 at the earliest.
The XI3 appears to be a product based on the Comcast Reference Design Kit (RDK), a bundle of software for hybrid QAM/IP gateways and IP-only clients. Comcast hopes the RDK will help cut product development cycles to a year or less. The X1, a hybrid gateway also made by Pace, is the first product to come out of the RDK project. Following launches in Boston and Atlanta, Comcast expects to deploy the X1 in at least three more major markets this year. (See Comcast's Set-Top Accelerator Gains Traction and Comcast's Cloud TV Service Rolls Into Atlanta.)
Comcast is expected to select multiple suppliers for its X-series boxes. Among chip and set-top vendors, other RDK licensees include Evolution Digital LLC , Motorola Mobility, Arris Group Inc. (Nasdaq: ARRS) and Entropic Communications Inc. (Nasdaq: ENTR). Cisco Systems Inc. (Nasdaq: CSCO) and Technicolor SA (Euronext Paris: TCH; NYSE: TCH) are also rumored to be among the RDK licensees.
http://www.lightreading.com/document.asp?doc_id=225519
post #725 of 779
10/3/12 at 3:24pm
- zaphod7501
- offline
- 1,777 Posts. Joined 3/2005
To meet the "separable security" rule on new set-top-boxes? I haven't heard that rule mentioned for quite a while, so I don't know if it is still in effect or if it would apply to this device.Originally Posted by PaulGo
October 3, 2012 | Jeff Baumgartner....And what's with that SD Card slot? The XI3 doesn't have an internal hard drive, so the slot could be used for memory expansion. But it's also plausible that Comcast could use an SD Card as a local, mini-DVR that could buffer a small amount of live TV programming for trick-play functions (pause, fast-forward, rewind, etc.). Advanced Digital Broadcast (ADB) toyed with the notion of using an SD Card as a "lite" DVR for a tru2way "set-back" box it showed off in 2010.
- PaulGo
- offline
post #727 of 779
10/4/12 at 10:14am
- PaulGo
- offline
I suspect it will take several years for the transition to an all IP Comcast platform to happen. It is possible a tuning device will be made for backward comparability but we will know more as Comcast migrates to an IP platform.
post #729 of 779
10/6/12 at 8:11pm
- slowbiscuit
- FUBAR
- offline
post #730 of 779
10/9/12 at 8:03am
- UGAd13
- Frugal A/V junkie...
- offline
- 286 Posts. Joined 4/2010
watched a football game at my friend's house who has the X1 platform... new house w/ new subscription so he was able to get the new box.
Reading some stuff online it looks like Comcast is only offering it to new Triple Play customers - no longer a triple play b/c we ditched the land line. I'm wondering if my current DVR box starts "freezing up intermittently" I'd be able to swap them out. Anyone know if it's plug and play or is additional set up required?
- PaulGo
- offline
I would first call Comcast to find out about the box and it's availability. It only may be available in certain areas withing your geographic location. If it is available then go to your Comcast office and try to swap it out. You also may want to post your question in the local tread for your location/
- PaulGo
- offline
Cable Cleared to Encrypt Basic TV Tiers
The Federal Communications Commission (FCC) voted unanimously on Friday in favor of lifting a ban that prevented cable operators from encrypting their basic service tiers in all-digital systems.
Many major U.S. cable operators want to encrypt the basic tier because it will help them cut down on service theft, and because it will enable them to more easily activate and deactivate customers remotely and reduce truck rolls. Comcast Corp. (Nasdaq: CMCSA, CMCSK), for example, predicts that encrypting the basic service tier will let it perform nearly half of its activations and 90 percent of its deactivations remotely.
The order comes with several conditions that the cable industry proposed during the vetting period. Among them, it requires cable operators that choose to encrypt the basic tier to provide affected customers with a set-top box or a CableCARD (for TVs that have slots for the security modules) for free for a specific time frame:
Existing customers who take only the basic tier are to receive a set-top or CableCARD for free for two years after encryption begins.
Customers who take a tier above basic but use a secondary TV to receive only the basic tier can get that equipment for free for one year.
Subs who receive Medicaid and only take the basic tier can get that equipment for up to two TVs without charge for five years.
Additionally, the nation's six largest incumbent cable operators must provide the technology necessary to let IP-based retail devices, such as the Boxee box, support basic TV tiers. That class of device has historically obtained those signals in unencrypted form -- something called "clear QAM."
It is expected that most of those operators will support that condition by supplying free Digital Terminal Adapter (DTA) devices with home-networking capability that can decrypt basic TV signals and pass them along to the third-party retail device. Retail device makers will have an option to license the operator's security technology, an alternative that would seem to cover a software-based security system used by Cablevision Systems Corp. (NYSE: CVC).
The operators affected by that condition (Comcast, Time Warner Cable Inc. (NYSE: TWC), Cox Communications Inc. , Charter Communications Inc. , Cablevision, Bright House Networks ) serve about 86 percent of all U.S. cable subs. The retail condition is set to automatically sunset in three years, but the order gives the FCC Media Bureau the power to initiate a review in two years.
Extra retail rule pleases Boxee
Boxee sought such a concession because encrypting basic channels would require its users to pay extra for separate set-top boxes. Boxee has refused to develop a device with a CableCARD slot because it is expensive and because installing a CableCARD in retail devices has historically been a frustrating experience for consumers. To help remedy this, Boxee and Comcast have also completed a separate agreement that involves the use of DTA devices with Ethernet connectors and a licensable approach should Boxee desire to integrate that capability.
Boxee CEO Avner Ronen cheered the ruling on the company blog, noting that the FCC's final order included the recommendations it made jointly with Comcast. "Our main goal was to find a solution that would allow cable companies to move forward with encryption while enabling devices like Boxee to access basic cable channels without requiring users to buy additional hardware of pay additional monthly fees," Ronen wrote.
Why this matters
The order and its concessions let cable operators encrypt their basic tier without having to offer a special justification for it and go through the trouble of obtaining the waiver. In addition to offering cable operators some operational relief, they can now polish off all-digital conversions and reclaim analog spectrum that can be used for other services.
However, a provision in the order puts it under possible threat, because the entire thing could be wiped away if any portion of it is somehow invalidated or overturned by a court -- a concern expressed in comments from FCC Commissioners Robert McDowell and Ajit Pai, but not one serious enough to prevent them from voting in favor of lifting the ban.
http://www.fcc.gov/document/commission-relaxes-cable-encryption-prohibition
http://www.lightreading.com/document.asp?doc_id=225922
Why this matters
post #733 of 779
11/15/12 at 6:48am
- DeltaBill
- offline
- 43 Posts. Joined 1/2004
Would someone kindly point me to a thread about the X1 hardware and its capabilities? I’ve been searching for awhile and can only find basic information about the hardware and more in-depth information about the new UI. Specifically, I am looking to see how many tuners (4 or 6), the hard drive size, is external storage permitted, and if whole home extenders such as the 3400-M can access the gateway. I did read about the XI3 coming out, but wonder if any current extenders will work.
I am in the Atlanta area and currently have triple-play with 2 DVRs (1 is MOCA enabled) and 2 extenders. I’m trying to determine if pushing to get the new hardware will provided additional flexibility and/or reduce my costs.
- PaulGo
- offline
Philly Next for Comcast's X1
November 16, 2012 | Jeff Baumgartner
Comcast Corp. (Nasdaq: CMCSA, CMCSK)'s next-gen video product will soon show up in the company's corporate back yard.
Philadelphia is one of two big Comcast markets on tap to get X1, the company's new hybrid QAM/IP service that integrates Pandora, Facebook and other Web apps and ties it together with a new cloud-based user interface.
Tom Blaxland, the senior director of product management for Xfinity TV, told the Philadelphia Business Journal that the X1 would debut in that market in the coming weeks.
On Comcast's third-quarter call in late October, cable unit President and CEO Neil Smit said X1 was on tap to launch in two "major markets" soon. Comcast has already introduced the product in four markets: Atlanta and Augusta, Ga.; Boston; and Chattanooga, Tenn. Comcast is primarily targeting new triple-play customers with the X1 offering.
Comcast declined to reveal an exact X1 launch date for Philadelphia or the second market Smit had referenced. Philadelphia, though, is part of the MSO's Freedom region, which also includes New Jersey and northern Delaware.
The X1 currently runs on a Pace plc hybrid video gateway outfitted with a Docsis 3.0 cable modem. Future versions are expected to introduce integrated video transcoding and Wi-Fi, making them capable of feeding video to tablets and other devices hanging on the home network. Comcast is also developing the XI3, IP-only HD client that could work in tandem with video gateways.
The X1, the 2012 Leading Lights winner in the Best New Service or Application (Cable) category, is also the first Comcast product to use the company's reference design kit (RDK), a pre-integrated bundle of video software that aims to speed up the product development cycle for hybrid and IP-only video devices.
http://www.lightreading.com/document.asp?doc_id=227179
- PaulGo
- offline
Comcast's new X1 UI integrates real-time and streaming TV with news and social apps
http://www.theverge.com/2012/5/21/3033972/comcast-ui-platforms-video-news-social-apps
- PaulGo
- offline
Comcast's IP-Only Set-Top Unveiled
Comcast Corp. (Nasdaq: CMCSA, CMCSK)'s first IP-only HD set-top box, dubbed the XI3, took a big step toward deployment after a model made by Humax Co. Ltd. was cleared by the Federal Communications Commission (FCC) . The FCC filing, first spotted by Wireless Goodness, shows that the device includes HDMI, Ethernet and USB ports along with an SD card slot that could be used for local storage or, as one industry source suggests, as a small live TV buffer.
Comcast declined to discuss its plans for the IP-HD client device, but it's expected to be paired with a primary video gateway (a future version of the X1 gateway is expected to include QAM-to-IP transcoding capabilities) and to eventually support a network DVR that's under development at the MSO.
Comcast plans to source the XI3 fom multiple suppliers. Pace plc is also developing a version of the XI3 based on a Broadcom Corp. (Nasdaq: BRCM) chipset that's expected to be deployed sometime in 2013. Click on the image below to start a brief slideshow of the Humax-made device. Comcast Corp. (Nasdaq: CMCSA, CMCSK)'s first IP-only HD set-top box, dubbed the XI3, took a big step toward deployment after a model made by Humax Co. Ltd. was cleared by the Federal Communications Commission (FCC) . The FCC filing, first spotted by Wireless Goodness, shows that the device includes HDMI, Ethernet and USB ports along with an SD card slot that could be used for local storage or, as one industry source suggests, as a small live TV buffer.
http://www.lightreading.com/document.asp?doc_id=227466
post #737 of 779
11/30/12 at 4:38am
- slowbiscuit
- FUBAR
- offline
And will it come with a defined open IP access standard, so any company such as Tivo can do the same thing?
Based on the comments and FCC filings in this thread, the answer right now is no. I find it very curious that the FCC enforced CableCard for third party device access but has completely rolled over on AllVid and keeps kicking the IP access standard issue down the road.
- PaulGo
- offline
Comcast's X1 Rolls Into Silicon Valley
Comcast Corp. (Nasdaq: CMCSA, CMCSK)'s X1 platform and its cloud-based navigation system has just rolled into several California markets, marking the first systems west of the Mississippi to get access to Comcast's next-gen video product.
Company SVP and GM of Video Services Marcien Jenckes spread word on the Comcast blog, noting that X1 is now offered in "many of our California markets," including the San Francisco Bay area, Sacramento, Stockton, Fresno and Santa Barbara.
In late October, cable unit President and CEO Neil Smit said X1 would debut in two "major markets" soon. The other is expected to be Philadelphia, Comcast's corporate back yard. Comcast has not announced a launch date, but a company exec told the Philadelphia Business Journal last month that X1 would debut to debut in The City of Brotherly Love in the coming weeks. X1 is still expected to launch in Comcast's Philly region before the end of the year.
In addition to California, Comcast has already launched X1 in four markets: Atlanta and Augusta, Ga.; Boston; and Chattanooga, Tenn.
The X1 service, currently based on a hybrid QAM/IP box made by Pace plc that sports an embedded Docsis 3.0 cable modem, features a new, more visually dynamic cloud-based navigation system, a video recommendation engine, and access to Pandora, Facebook and some news, sports and weather widgets. X1 also supports a remote control app for iOS devices that lets user control the UI using motion and gestures.
Comcast will expand its X1 app lineup as it gets more developers behind the Reference Design Kit (RDK), a pre-integrated software bundle for hybrid and IP-only set-tops, gateways and client boxes. The X1 is the first product to be based on the RDK.
Comcast has not said how many customers are on the X1 product so far, but the MSO is targeting it primarily to new customers who take the company's triple-play bundle. Comcast is still losing video subscribers, but it's been narrowing those losses in recent quarters.
http://www.lightreading.com/document.asp?doc_id=227802
- PaulGo
- offline
Comcast Execs Talk Up X2, Cloud DVR
Comcast Corp. (Nasdaq: CMCSA, CMCSK)'s plans for a new IP-capable video gateway and a cloud DVR service were among the topics MSO execs discussed Monday during an internal video broadcast to introduce employees to the company's new corporate branding.
Comcast cable-unit CEO Neil Smit noted during the talk that a new device called the X2 is in testing, "looks fantastic" and will offer more personalization, according to a Twitter user, who confirmed he was privy to the contents of the broadcast. He said Smit also announced plans to launch a Cloud DVR service, calling it a "game changer" for the MSO.
A Comcast spokeswoman confirmed that the X2 came up during the broadcast, but would only say that the product represents an "evolution" of the X1, a hybrid QAM/IP platform with a cloud-based user interface. The X1 has been deployed in five markets.
Comcast has not said much about new network DVRs, though sources told Light Reading Cable in April that the operator is trialing such a product in the Boston area.
A person familiar with X2 developments said it is indeed a revised version of the X1 HD-DVR made by Pace plc that currently uses Intel Corp. (Nasdaq: INTC) and Entropic Communications Inc. (Nasdaq: ENTR) chips. The X2 will likely use Broadcom Corp. (Nasdaq: BRCM) chips, though it's not clear if Intel and Entropic could also get a piece of that business, or if vendors beyond Pace could supply the box, the source said.
The X1 doesn't offer video transcoding and integrated Wi-Fi to help the gateway distribute to tablets, but those features could make it into the X2. It's also possible that the X2 gateway will work in tandem with the XI3, an IP-only HD client device that's in development.
While a cloud DVR service would reduce set-top capital and possibly give consumers access to their recordings while they're on the go, a person familiar with the project said such a product will also offer Comcast some protection from TiVo Inc. (Nasdaq: TIVO) and its powerful DVR patents.
"TiVo's patents aren't strong on cloud," the source said. TiVo's litigious history is "incenting some MSOs to go to the cloud … where TiVo doesn't have that sort of sway."
http://www.lightreading.com/document.asp?doc_id=227803
- PaulGo
- offline
Comcast Business Services extends fiber network to downtown Houston
Provides access to Ethernet and other telecom services
Comcast Business Services (Nasdaq: CMCSA) on Thursday launched an effort to expand its fiber network in downtown Houston.
When the fiber expansion is completed early next year, it will be able to bring services such as Ethernet and cloud services to over 3,000 small and medium-sized businesses.
This fiber expansion will complement the MSO's earlier effort to bring its cloud-based unified communications (UC) services, including VoiceEdge UC, to the region.
Inside Houston, the service provider's fiber will be routed to various multi-tenant office buildings including Chase Tower, the largest building in the state. Having access to large buildings like Chase means Comcast Business Services will be able to target a large set of potential new customers that are looking for an alternative service provider as they migrate from an existing legacy technology like Frame Relay to Ethernet.
Competition to satisfy the Houston business market for next-gen services has become fierce. Besides incumbent telco AT&T (NYSE: T), Comcast Business will also face Alpheus Communications, a CLEC that has been actively expanding its presence in the Dallas, Austin, San Antonio and Houston (DASH) area.
One thing Comcast Business does have over other competitive carriers is that they own all of their fiber, meaning they can control the speed and experience for their customers versus having to rely on another provider's facilities.
The Houston buildout is part of a broader effort Comcast Business Services, which currently provides Metro Ethernet services in 20 major U.S. markets, is making to expand its fiber footprint and service reach to more potential SMB customers.
Outside of Houston, the MSO has been expanding its fiber network in other major metro markets including Boston and San Mateo, Calif. In Boston, the service provider's fiber build out, including offering 100 Mbps service in the city's Innovation District, helped it win multi-service contracts with both the Boston Red Sox and more recently The Celtics.
http://www.fiercetelecom.com/story/comcast-business-services-extends-fiber-network-downtown-houston/2012-12-14
post #741 of 779
12/20/12 at 9:31am
- slowbiscuit
- FUBAR
- offline
- PaulGo
- offline
Comcast Corp. confirmed that it's begun to deploy a new class of HD Digital Terminal Adapter (DTA) with integrated security that the Federal Communications Commission (FCC) approved for use in the fall of 2010. A version made by Motorola Mobility LLC recently passed through the FCC. Comcast won't reveal where the deployment is starting, but "we're at the beginning of a phased deployment that will ultimately go the entire footprint," a spokeswoman says.
http://www.lightreading.com/document.asp?doc_id=228110
Comcast deploys HD DTAs, ponders TR-069
Comcast has started a phased deployment of HD digital transport adapters (HD DTAs) in subscribers’ homes ahead of ultimately having the devices across its entire footprint.
Back in August, Comcast’s Steve Reynolds, senior vice president of CPE and home networking, said the cable operator was in the process of wrapping up a large-scale trial of HD DTAs prior to deploying them in customers’ homes this year.
Reynolds said then that the HD DTAs represented the last piece of its analog-to-digital conversion, which is known internally as “Project Cavalry.” Comcast expects to have the all-digital project wrapped up by the end of next year, which includes the rollout of HD DTAs from vendors such as Pace, Technicolor, Motorola and Evolution Digital. (Evolution Digital’s wall-mounted HD DTA is also attractive to cable operators because it cuts down on theft.)
HD DTAs allow customers to access HD signals without the frills of VOD, pay-per-view or more expensive equipment in the home. By using an HDMI connection, customers can opt for an analog-type viewing experience on their new HDTVs through the use of HD DTAs. In addition to providing a low-cost HD service for subscribers, HD DTAs are also ideal for hospitality, multi-dwelling units, fitness centers, and bar and restaurant deployments.
Comcast spokeswoman Jenni Moyer confirmed that the HD DTA deployments were underway but didn’t provide any additional details.
Moyer also confirmed that Comcast was looking at the TR-069 standard, which is also known as the CPE WAN Management Protocol. Comcast hasn’t deployed TR-069, but, like a lot of other cable operators, it is moving toward it for remote configuration and management of devices.
TR-069 is a standard built around providing better visibility into a home network environment. In order to build troubleshooting apps, the cable industry and its vendors need to align themselves with standards, such as the emerging TR-069. With home networks becoming more complex, tools need to be developed to provide remote status and diagnostics, as well as provide field forces and customer service reps with the information to efficiently diagnose and repair issues. (For more on TR-069, check out CableLabs senior OSS engineer Eduardo Cardona’s presentation and paper from the SCTE Digital Home Symposium.)
The Broadband Forum has developed a TR-069 certification program, which is handled by the University of New Hampshire InterOperability Laboratory (UNH-IOL). The Broadband Forum provides a list of TR-069-certified products.
http://www.cedmagazine.com/blogs/2012/12/comcast-deploys-hd-dtas-ponders-tr-069
post #743 of 779
12/21/12 at 11:16am
post #744 of 779
12/21/12 at 7:36pm
- George-O
- offline
- 694 Posts. Joined 7/2006
Are you talking about wired or wireless?
No issues here with my older Panny Viera 32" HDTV via an older D-Link D704P hardwire router from my Comcast Arris TM722 HSI and Phone modem ...... BTW, I've rewired the home to eliminate all wireless ......two of my neighbor's homes are alledgedly professional hacker dens (as warned by my friend who knows a guy who knows another gal that works for the Dept of Homeland Security handling the ongoing investigation).
Sometimes newer is not better as many youngsters today playing with the the latest wireless gadgets may eventually discover when they apply for their first car or home loan :-))
Edited by George-O - 12/22/12 at 6:46pm
post #745 of 779
12/22/12 at 7:05am
I have gotten all the issues resolved. It was my fathers new TV and he was working through it with Xfinity(Comcast). I finally took the phone work over and proceeded to overwhelm the worker with questions that he admitted he couldn't answer(IP address to get to router setup page?? how do they not know that). Turns out the Comcast install tech had set the router up as a bridge. We got that fixed and now the TV and BLURAY player are both hooked up to the WiFi. Awesome technology and I will say that there internet speed is impressive, North Coast of Massachusetts.
post #746 of 779
12/23/12 at 4:17am
- PaulGo
- offline
Comcast touts next new upgrade: The TV remote
Sanity, at least as it regards the TV remote control, might be on the way.
Comcast Corp. says that, as part of the X1 upgrade to its interface and channel guide, the company redesigned its TV remote and removed 24 buttons - almost half.
There are now 29 buttons instead of 53. (FiOS has 47.)
X1, being rolled out in individual Comcast markets, among them Philadelphia, Boston, and Atlanta, is the most sweeping change to the Comcast look and functionality since the late 1990s and a seismic shift in how the nation's largest pay-TV operator delivers entertainment.
Most of the action with X1 takes place in the cloud, or on Comcast computer servers, instead of the cable set-top box. Comcast says the cloud-based system allows it to constantly add features and to tinker with X1's Internet functionality without having to swap out set-top boxes - which can take years and many millions of dollars.
Internally, Comcast officials are calling X1 an "entertainment operating system."
The new X1 set-top box, meanwhile, is mostly a souped-up DVR, or digital-video recorder, that can store 300 hours of standard-definition video and 60 hours of high-definition video.
"This is a reinvention of the way we deliver our services to consumers," said Marcien Jenckes, senior vice president and general manager of video services for Comcast Cable, who recently showed off X1 at the Comcast Center.
"This is what nobody else can do," he said. "Our ability to deliver a two-way connection to a television is a major competitive advantage."
Jenckes was referring to the cable industry's advantage over satellite-TV providers, such as DirecTV and Dish, in that cable companies offer television and Internet.
Comcast says that X1 will be easy to use and that it conducted more than 100 tests and focus groups with employees and customers, similar to a consumer-products company developing a new laundry detergent or candy bar.
About 400 employees have been involved in the X1 project since 2009 in Philadelphia, Radnor, Denver, and northern California. One of those employees visited 60 subscriber homes to talk about X1 and how people used it.
Even Comcast chief executive officer Brian Roberts had a part. He said he liked the Rotten Tomatoes website - known as a film-review aggregator - and developers included its ratings in the X1 guide.
With the remote, Comcast removed buttons that weren't regularly used and combined several functions into one Xfinity button. Xfinity is how Comcast brands its TV and Internet services.
In addition to fewer buttons, Comcast's updated remote is slimmer. The company says it did ergonomic studies to come up with the shape.
X1 will be available to new Comcast triple-play subscribers - those who take cable-TV, Internet, and phone services - and customers upgrading to triple-play packages. Comcast plans to make X1 more broadly available over time.
Tom Blaxland, senior director of video products, demonstrated X1 and whizzed through what it could do. Excited, he said, "When we want to launch a new feature, we can change it on the server and do it overnight."
http://articles.philly.com/2013-01-19/business/36417596_1_marcien-jenckes-xfinity-comcast-plans
- PaulGo
- offline
Comcast to Take $150M Stake in Arris With Motorola Home Deal
MSO and Google to Each Hold 7.85% Stake in Arris
By: Todd Spangler Jan 14 2013 - 5:06pm
In a four-way transaction, Arris Group said it will sell Comcast approximately $150 million in stock in connection with Arris’s proposed $2.35 billion deal for Motorola Mobility's Home business with Google -- which will result in the cable company and Google each owning about 7.85% of Arris.
Arris will issue 10.6 million shares of common stock issued to Comcast. That will reduce on a share-for-share basis the number of shares of Arris stock to be issued to Google, while simultaneously increasing the cash to be paid to Google by $150 million, Arris said.
As a result of the sale to Comcast, Comcast and Google will each own approximately 7.85% of the outstanding Arris shares post-closing based on Arris’s current capitalization. Neither Comcast nor Google will have a board seat with Arris; under the original terms, Google wasn't going to have board representation either.
Comcast is Arris's largest single customer -- representing 33%, or $117.7 million, of Arris revenue for the third quarter of 2012 -- and with the addition of the Motorola Home set-top and video assets, the vendor will cover video, broadband and voice software and equipment.
"We are very pleased that Comcast has agreed to make this significant investment in Arris," Arris chairman and CEO Bob Stanzione said in a statement. "We believe this investment by one of our largest customers is a strong indication of customer support for the Motorola Home acquisition and its potential to accelerate innovation to the benefit of the industry and consumers."
If Arris had not opted to sell the stake to Comcast, Google would have held about 15.7% of Arris under the terms of the original agreement.
Neither the total amount of consideration paid by Arris for Motorola Home, nor the total amount of shares to be issued by Arris (now to Google and Comcast) will change as a result of this investment by Comcast.
The issuance of the shares to Comcast is conditioned on the closing of the Motorola Home acquisition and other customary conditions, Arris said. Arris’s acquisition of Motorola Home is expected to close by the second quarter of 2013, pending regulatory review.
Qatalyst Partners LP is acting as the lead financial advisor and Davis Polk & Wardwell LLP is acting as lead legal counsel to Comcast on this transaction. Evercore Partners is acting as lead financial advisor and Troutman Sanders is acting as lead legal counsel to Arris on this transaction; Bank of America Merrill Lynch also is advising the vendor.
On Google’s side, Barclays is acting as financial advisor and Cleary Gottlieb Steen & Hamilton LLP is acting as legal counsel.
http://www.multichannel.com/cable-operators/comcast-take-150m-stake-arris-motorola-home-deal/141214
- PaulGo
- offline
Comcast's 'X2' to Get Personal With the TV]
LAS VEGAS -- NCTC Winter Educational Conference (WEC) -- Comcast Corp. is adding enhancements to its cloud-based guide that will deliver personalized recommendations based on viewing habits and other data.
The product under development, internally referred to as "X2," will offer a "stronger editorial voice throughout the guide," said Rachel Lee, Comcast's senior director of product management, here Monday on a panel dedicated to cable's evolving video gateway strategy. The X2 will also use recommendations to assemble "collections" of video content based on customer interests.
Lee didn't say when Comcast intends to launch these enhancements, but the operator has dedicated a sizeable engineering team to the latest version of the cloud-based guide. "We're pretty far into development," she said. "It's a … significant effort."
It's unlikely that Comcast will use the X2 label to promote the features that will grace the upcoming version of its cloud-based guide. Comcast is already marketing its new IP-capable video product under the X1 banner. Comcast has launched X1 in seven markets: Colorado Springs, Colo.; Atlanta and Augusta, Ga.; Boston; Chattanooga, Tenn.; San Francisco; and the Philadelphia area. Comcast is expected to launch X1 to the majority of its footprint this year. (See Comcast's X1 Comes to Colorado.)
Lee told Light Reading Cable that the enhanced, more personalized X2 guide is made to run on devices that support the first iteration Comcast's cloud-based guide. For now, that includes the Pace plc-made XG1 HD-DVR and the RNG150N client box. Comcast is also developing an all-IP HD client box called the Xi3 and a "headless" gateway called the XG5.
Comcast Cable CEO Neil Smit referenced the X2 in an internal video broadcast late last year, noting that it would offer more personalization. At the time, Comcast would only confirm that the X2 represented an "evolution" of the X1 platform.
Comcast hasn't announced its vendor partners for the X2's recommendation engine, but one candidate is ThinkAnalytics Ltd., a Scotland-based vendor that generates unique preference profiles on set-tops, tablets, smartphones and PCs by mining metadata and tracking usage patterns.
ThinkAnalytics, by the way, is the first recommendation engine vendor to secure a license for the Comcast Reference Design Kit (RDK), an integrated software bundle for the MSO's hybrid QAM/IP and IP-only set-top boxes. Boxes that run the X1 are the first products to incorporate Comcast's RDK.
Some of ThinkAnalytics's announced customers include Liberty Global Inc., Cox Communications Inc., Swisscom AG and Virgin Media Inc. . At last check, the vendor had deals with more than 40 customers and 100 million licensed subscribers.
http://www.lightreading.com/middleware-business-support-systems/comcasts-x2-to-get-personal-with-the-tv/240149445
post #750 of 779
2/28/13 at 4:49pm
Back to Forum: HDTV Technical
- Comcast Technology Topic
AVS Top Picks
Currently, there are 1181 Active Users
(106 Members and 1075 Guests)
Recent Discussions
- › 3D Color Calibration Thread 2 seconds ago
- › New Dune HD Max and HD Smart anticipation thread Q3 2010 2 minutes ago
- › Sony XBR-HX950 Owners' Thread (XBR-55HX950 and XBR-65HX950) 13 minutes ago
- › Best cd/sacd player (new or used) for $100? 14 minutes ago
- › JVC DLA-RS48 / DLA X55 projector with 3D RF glasses and E-shift... 21 minutes ago
- › Streaming From PC - Which is the best device? 23 minutes ago
- › Star Trek: Into Darkness in Dolby Atmos 23 minutes ago
- › Official Ceton Echo Extender Info Thread 26 minutes ago
- › The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread 26 minutes ago
- › G-Box Midnight USB Storage 28 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BRAVIA KDL55HX850 55-Inch LED HDTV by Falgoonit
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
