Originally Posted by Dean Roddey
But I am against those aspects of either side that prevent balance, and the attitude that is prevalent on the right, and very much so on the far right, that speaking out against the govt when you think it is wrong is tantamount to conspiracy or anti-Americanism, that is a very dangerous mechanism that prevents balancing.
As long as the attitude is limited to opinion rather than being codified, I think we're still OK. After all, trying supress it would be equally bad, or even worse.
In the case of X being equal to the U.S.A. (or more generally, the establishment), you are likely correct that the right is more vocal in their denouncements. But then, that specific value for X targets the innate philosophy of the right. Using other values for X will get similar results with the left, or with any other "sides".
Actually, it's not even balance I think we need, it's Darwinian genetic variation that we need. You never know what's coming down the pike and in any time, one or another set of skills and outlooks will work best. Many answers will not remain the right answers over time, and since people almost never change fundamentally and therefore cannot react well to significant environmental change, we need that diversity of views and ideas so that the outcasts can take over when the current answer for whatever ceases to be the right answer.
Good point about human nature tending to be resistant to change. It would be interesting to see what happened if human nature readily embraced change. Would it indeed be better, or might we find that chaos would ensue.
Even with Darwinian genetics there is a natural built-in resistance to change. Maybe everything is actually in pretty good balance after all. Unlike the force. Although I still haven't heard a satisfactory explanation of why it was out of balance to begin with.
Originally Posted by archiguy
Like Mr. Roddy, I believe in balance (and the system is way out of balance right now)
I'd like to think that most reasonable people believe that balance is a good thing. But it also seems that most people can't agree on what needs to be done to achieve balance, or even what constitutes a good balance.
Depending on exactly how you mean that the system is way out of balance, I'd either strongly agree or strongly disagree.
I'd agree that our political process in general is out of balance. This being due to the people not being represented well by any of the political parties. Individual politicians vary in their desire and ability to be good representatives.
I'd disagree that the system is way out of balance along conservative/liberal lines. This is a pendulum that continually swings back and forth and, while it is currently swinging towards more conservatism, it is nowhere close to where it once was conservatively in the middle of the last century, and it is nowhere nearly as extreme conservatively as it once was liberally.
The fact that the extremes of both liberalism and conservatism continue to cry that the sky is falling is good evidence that we are more balanced than we might think by listening to either side alone.
