AVS › AVS Forum › Display Devices › Rear Projection Units › Just what's inside a Panasonic DLP?
post #1 of 14
Courtesy of Mike up in British Columbia here is the 'poop' on the PT-50DL54 DLP sets. They will be posted how they are in order in the Service Manual as much as possible. The photos are not that great.
chassis removed from the set;
closeup of the "L" board;
post #2 of 14
There are 3 attachments here (now that I know you can post more than one per post)
optical block assembly;
color wheel;
color wheel closeup
post #3 of 14
As always, if you aren't sure, DON'T do it!
service mode warning;
service mode part one;
service mode part two;
post #4 of 14
self check function;
default values;
exiting from service mode;
post #5 of 14
screen sections diagram;
Two pieces and no shortage of screws to remove
post #6 of 14
video block diagram (no DAD conversion?);
voltage table (other than the 330v for the lamp circuit NO high voltage );
LED flashing reference table;
post #7 of 14
BEFORE you tweak, write the orginal numbers down!
white balance;
color adjustments;
post #8 of 14
You need to to be VERY sure you know exactly what you are doing here!
focus adjustment;
tilt adjustment (one of the easier tilt adjustmnents I have seen);
post #9 of 14
DAD chip;
HDMI receiver;
post #10 of 14
lamp protection;
major parts list;
post #11 of 14
Thanks great information!
Anything on the fan, be nice if it could be quieted or replaced with a quieter one?
post #12 of 14
[quote=videobruce]QUOTE]
If you find a pink and white sock I will know where it finally friking wound up!
:D
post #13 of 14
[quote=Tecumseh]
Originally Posted by videobruce
QUOTE]
:D
:confused: :confused:
post #14 of 14
Look at the bottom of the major parts list for the two fan numbers.
Fan noise varies with the set, the location and the room enviroment (hard or soft).
You can try putting sound damping material behind the set where it wouldn't be seen.
  Back to Forum: Rear Projection Units
This thread is locked
