AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Marantz 7400/7500/8400/8500 thread
"Official" Marantz 7400/7500/8400/8500 thread - Page 9
post #241 of 702
That's good to know but...
As I mentioned in the first post, The cover for the DVD says 5.1 Dolby Digital.
So I am assuming the output woud be that.
The DVD menu only has the 2 audio streams I mentioned.
post #242 of 702
Actually Dolby Surround almost ALWAYS means Dolby 2.0 with surround encoded material.
I think I know the problem. There are two versions of The Abyss Region 1. The widespread one comes with English 5.1 and English 2.0 - no French. Another version, meant for French speaking Canada (AKA Quebec), comes with English 2.0 and French 2.0. There's no 5.1 soundtrack.
The French version normally has "Bonus French Track" written on the front of the packaging, and the Dolby logo on the back switches from "Dolby Digital" to "Dolby Surround". If your case doesn't have that it sounds like you have the French version in English packaging (both packages are in English but you know what I mean). At any rate, the version with English 5.1 does not have French.
post #243 of 702
There are also other indications beside the speaker diagram to work from.
When you play your track, teknoguy, what appears above the speaker diagram on the display?
You will probably in all cases see a red "double-D" DIGITAL icon. This will be displayed for all DVDs with "Dolby Digital" sound, be it mono, 2.0, 4.0 (aka "Dolby Surround"), 5.1 and 6.1.
But is there anything above it? If you see a blue "double-D" SURROUND icon you know the audio stream is definitely in Dolby Surround (4.0) and has been specifically encoded as such. The SURROUND indication will be OFF when you're listening to a 5.1 or 6.1 track.
The fact that you can't select Dolby Digital 5.1 in the DVD menu and only "Dolby Surround" is probably the determining factor. Perhaps the case advertising was in error? You can also cheat on some DVDs as many players can show you what soundtracks are on the DVD and can allow you to switch on-the-fly. The DVD player will often label the tracks appropriately, i.e. "ENG1 [double-D] 5.1", "ENG2 [double-D] 2.0", "FRE1 [double-D] 2.0" and so on. The "2.0" indication often means Dolby Surround, since Dolby Surround is always encoded in a 2-channel format, with the surround channels mixed in.
Regarding the speaker diagram discrepancy, that's kind of weird. It's always been accurate for me. I'll do some tests tonight.
post #244 of 702
Hi I have a question: Should I sell my SR-7000 and get a newer Marntz say 7400 or used 8400??? Also looking at Pioneer Elite 54TX or just keep the 7000. Thanks
post #245 of 702
____________________________________________
teknoguy,
I have approx. 220 movie DVDs but unfortunately not the Abyss. Daniel Tonks has to be correct based on what you said about your DVD menu selections, i.e., the disc must be encoded in 2.0 Dolby Surround only. I have a 7.1 setup but I tried to duplicate your situation by turning off my back surround speakers and playing a standard Dolby Digital encoded DVD movie (The Pacifier; hey I was at home with the kids while the wife was working). I have a digital coax out from my Denon DVD player into my Marantz SR-8400 and set the surround mode to auto detect. Once I started playing the movie, the Marantz display showed the standard 5.1 speaker configuration (FR/FL/C/LFE/SBL/SBR). I have played a standard VHS movie, then set the surround mode to PLIIX and I only see a FR/FL speaker diagram even though sound is coming through 7 speakers in my 7.1 setup. It goes back to what I was referring to (the matrix describing surround modes & speaker diagram displays) in the manual on pg 25.
post #246 of 702
The speaker channel indicator only shows REAL or OFFICIALLY decoded channels as specified by the original data stream - what speakers you have (or don't have) doesn't come into it. So playing a Dolby Digital 2.0 Surround movie in Pro Logic IIx will still only show Left, Right and Surround channels.
This is supplemented on the SR9600, which has a display mode that indicates the level of all decoded activity in the receiver's 8 channels, so you can tell exactly what's going on.
In my experience Marantz's channel indicator is 100% reliable and accurate, so if it says you're getting 2.0 Surround that's exactly what the disc has to offer, there's no malfunction.
post #247 of 702
Man on man talk about "a big honking box"!
I just installed a Marantz SR-9600 and I think it weighed more that the Samsung HL-R 4266 I installed with it!
A really sweet unit though.
My wholesaler told me the RC-9500 would work great with it, and it did, but he also told me the RC-9500 had the codes already built in.
It did not.
That was a pain in the a#$.
I had to break it down to 7 device groups with a total of 26 pages. All built from scratch. Of course, the remote for the SR-9600 also has macro capability, but since I'm using the RC-9500, I didn't even bother to build the macro pages from the 9600's remote. 26 pages in 7 groups was just for the actual receiver operations.
I really like all the asignable inputs as well. The default config seemed like odd choices, but it was super easy to re-assign the ports as needed.
In the auto setup, it reports errors for the rear speakers, but that has me confused because the polarity passed and they make sound. I don't know what else they need to do. The center speaker reported and error as reverse polarity. I checked and it wasn't. I re-checked and it still said reversed. I reversed the leads and it passed, but I don't understand that result because now it is reversed for sure.
If anybody has any words they can share about the speaker checking and possible reasons for the polarity issue on the center and errors for the rear speakers I'd certainly appreciate it.
If anybody knows a source for discrete commands for the SR-9600 I'd sure like to find some.
post #248 of 702
Hmm, you must like big buttons. I managed to get it down to 5 pages for the main receiver + 1 page per tuner + 3 pages per multiroom, for a max of 13 pages. Although to be fair I ignored a few commands that were useless to me, like DC triggers and speaker selection.
I don't currently have center rear speakers. For the regular surrounds, one did show as reverse polarity and after checking I'm pretty sure it was. It's always possible a speaker is wired incorrectly inside. If you have the Avia DVD there's polarity check test in there that should tell you for sure (come to think of it I should run it as well).
What discretes beyond what's included are you looking for? I mean there's already power, inputs, soundfields, mute, speakers, DC triggers... I've have the complete list of commands for the SR9600 and the only things beyond what comes on the RC3200 are toggles for things already provided in discrete.
post #249 of 702
[quote=Daniel Tonks]The speaker channel indicator only shows REAL or OFFICIALLY decoded channels as specified by the original data stream - what speakers you have (or don't have) doesn't come into it. So playing a Dolby Digital 2.0 Surround movie in Pro Logic IIx will still only show Left, Right and Surround channels.
Understood; that's what I'm trying to point out to teknoguy. When using Logic 7 on my previous HK AVR-525, the speaker diagram would show all channels even if the original source was 2-channel. At first, I was suprised that I didn't see the same type of display when I got the Marantz (using DPLIIX on a 2-channel source) but I got used to it. It's the sound that counts and I love my SR-8400.
post #250 of 702
It depends what you want. Looking around the web for the SR-7000, it appears that the SR-7000 is a 5.1 Dolby Digital/DTS/Pro-Logic receiver.
The 7400/8400 adds:
- Dolby Digital EX, DTS-ES (6.1 matrix and discrete)
- Dolby Pro-Logic IIx (7.1 matrix for all input sound formats, including Dolby Digital 5.1)
- a better remote
- one more coaxial digital input
- OSD (I think the 7000 probably doesn't have it)
So if you were thinking of sticking with 5.1 speakers, the only feature that's really added is Dolby Pro-Logic II (not IIx with 5.1 speakers though). This is a considerable upgrade over Pro-Logic if you use this soundfield a lot.
If you were thinking of upgrading to 7.1, then the 7400/8400 would be a great upgrade.
BTW my 7400 will be coming up for sale shortly.
post #251 of 702
The 7400/8400 adds:
- a better remote
When would it be up for sale and how much do you want for it, let me know.
post #252 of 702
Well, I'm in front of my SR7400 and here's what I can tell you about the indicatons on the panel...
I have the red double-d digital indicator on. Above that, a white double-d surround indicator. Below those 2 in the speaker map area I have the front left and front right channels and a rear-center-surround.
I tried the French Dolby Surround track. Does the same thing except for the dialogue in French!
Back of the DVD case says: "AUDIO: English 5.1 Dolby Surround, English Dolby Surround". Nothing about a French track at all. There's even a Dolby DIGITAL trademark next to the PG-13 rating.
I'm going to chock this up to someone messing up at the factory.
Thanks folks for your help!
-T
post #253 of 702
This is 4.0 Dolby Surround delivered via a Dolby Digital 2.0 stream.
I just tried this out on my 8400. This is entirely normal for a Dolby Surround track. Yes, there should be a C channel, but there isn't on the diagram. Doesn't matter, your C channel should be working perfectly.
The "S" channel denotes surround. In a Dolby Surround 4.0 track, you have L, C, R and mono surrounds. Dolby Pro-Logic will decode the surrounds as mono. Dolby Pro-Logic II will decode the surrounds as stereo. Dolby Pro-Logic IIx will steer this sound over the 4 speakers. (SL, SBL, SBR, SR). So a Dolby Surround soundtrack decoded with the "original" decoder for Dolby Surround (Dolby Pro-Logic) would have the surrounds in mono - hence only one surround, "S".
This does not mean those speakers aren't active - this is just the data that's being read off the disc.
They are tricky, no doubt about that. But if they say "5.1 Dolby Surround" it's actually Dolby Surround, which can be decoded as 5.0 with Dolby Pro-Logic II and 7.0 with Pro-Logic IIx. Not discrete though, and there is no ".1" track with Dolby Surround.
Note they did not say "Dolby Digital 5.1". If they don't specifically say Dolby Digital 5.1 it isn't in DD 5.1.
It's considered Dolby Digital 2.0 - and in fact, your DVD player may label the track as such. It should say "ENG1 [double-D] 2.0 CH". That does mean you get to benefit from the increased dynamic range DD has to offer. And with a digital source, channel separation is VERY good.
So your receiver is operating fine, your DVD player is operating fine, but your DVD isn't quite what you expected.
I'll work on getting some digicam shots of my receiver display with different formats.
post #254 of 702
I'm having some minor warranty work done on it so it'll be in top shape when I sell it. The headphone output didn't work and one optical door is missing. Operationally and cosmetically it's flawless.
It's been in for 2 weeks now, it should be almost ready.
I haven't decided on price yet. I have to see what the going rate is. Put it this way, I do want to sell it, I don't want to hold on to it for months while I try to make an extra buck. So the price will be fair.
I'll PM you when I do some more research regarding price and when I get the unit back and test it for you.
post #255 of 702
This is of an 8400 - the 7400's display is identical. I apologize for the tilt. The camera was mounted on a tripod - I think the act of pressing the shutter pressed the tripod into the carpet, tipping it slightly. I also am not practiced enough with GIMP to be able to rotate an image and have a black background appear in the "new" section.
The first photo is of a Dolby Digital 2.0 stream that's NOT encoded with a Dolby Surround flag. This does not mean it's not in Dolby Surround as the matrixed-in tracks can be "snuck" (sneaked?) in there without the receiver being able to tell - and it doesn't matter since it's decoded in Dolby Pro-Logic IIx which will extract any matrixed data present. Note the presence of the red "double-D DIGITAL" icon and that the decoding format is "DOLBY PLIIx MV" (Dolby Pro-Logic IIx Movie).
The second photo is of a Dolby Digital 2.0 stream that's encoded with a Dolby Surround flag. Note the appearance of a blue "double-D SURROUND" icon above the red "double-D DIGITAL" icon and the addition of the "S" speaker, denoting the surround channels matrix-encoded in mono. But this "surround" matrix channel is decoded as stereo in Dolby Pro-Logic II and over 4 speakers with Dolby Pro-Logic IIx. Note that the decoding format is still "DOLBY PLIIx MV" - yours should be too, or "DOLBY PLII MV" if you don't have rear speakers. I incorrectly called this format Dolby Surround 4.0. There's no such thing since with Dolby Surround, the 3rd and 4th channels aren't discrete. Only the L and R channels are truly discrete, all the others are extracted from them. So it's all Dolby Digital 2.0, it's just that there may be additional matrix data there.
I suppose this is inconsistent - if the "C" isn't there, the "S" shouldn't be there either as only the L and R channels are discrete. Oh well.
The third photo is a Dolby Digital 5.1 stream decoded in Dolby Pro-Logic IIx. Again we have the "red double-D" icon but note the "C", "LFE" (in the centre), "SL" and "SR" channels. Also note that the decoding format has now switched to "DD+PLIIx MV" - Dolby Digital decoded with Dolby Pro-Logic IIx to add two rear channels. It could also be set to "DOLBY D" as an option or if you're operating in 5.1. Even though PLIIx is adding rear channels, they don't show up on the speaker diagram as the speaker diagram is attempting to show what's on the disc rather than what the receiver is doing.
post #256 of 702
The last photo is Dolby Digital EX, 6.1 matrix. The only differences between this and Dolby Digital 5.1 is the addition of the blue "EX" text to the right of the red "double-D DIGITAL" icon and the reappearance of the "S" speaker, this time meaning the rear surrounds. Dolby Digital EX is just like Dolby Digital 2.0 with a Dolby Surround flag. Only 5.1 channels are discrete, the 6th one is matrixed in and the receiver can properly decode it whether or not the EX flag is present.
Some discs are encoded in EX but don't have the flag. I'm sure there are some Dolby Digital 2.0 discs that don't have the Dolby Surround flag yet are encoded in Dolby Surround. Again, it doesn't matter if the discs are decoded in Dolby Pro-Logic IIx as it will extract any matrixed data if present.
DTS, DTS-ES discrete (sorry, no matrix), PCM and analog screenshots available on request.
In summary, the speaker diagram indicates the data on the disc, not what the receiver is decoding.
post #257 of 702
The full English only version of Abyss does have a true Dolby Digital 5.1 soundtrack - I listened to it tonight. And the fact that it says "5.1 Dolby Surround" is just the way they worded it, there's nothing underhanded going on.
The fact remains, you have a French Canadian disc in normal English packaging. A few other Canadian releases have also been butchered - I remember a disc (don't recall the title) where the US release had English 5.1 and English 2.0, while the Canadian release had English 2.0 and French 2.0.
Also, an easy way to tell whether your disc has discrete channels or merely decoded channels is to look at the THX mode. If it's "THX 4.0" you're working off a stereo source no matter what. If it's "THX 5.1" then there's more than 2 channels on there, no matter what they are. For instance, some old Disney cartoons have been released in Dolby Digital 4.0, which has discrete left, center, right and mono surround channels. This will show up as being processed in THX 5.1.
post #258 of 702
There's nothing purposefully underhanded, it's a bit confusing and deceptive though.
They can say "Dolby Digital" when they mean Dolby Digital mono or Dolby Digital 2.0. However, it will only be Dolby Digital 5.1 when they specifically say "Dolby Digital 5.1." If they say "Dolby Surround 5.1" then it's Dolby Digital 2.0 with a matrix-encoded 4-channel surround track that can be decoded in 5-channel or 7-channel.
It's confusing.
Good idea but note that the 7400 and 8400 are not THX certified and don't have these modes.
post #259 of 702
In summary, the speaker diagram indicates the data on the disc, not what the receiver is decoding.[/quote]
__________________________________________________________
Fraoch, Daniel Tonks,
Excellent analysis by both of you. Fraoch, your explanation and the pics really help
others understand what's going on with the surround modes and displays. I understand where both of you are coming from--I've read up on all this stuff before but I just don't have the time to research much these days. I also try to keep up with video, power amp, and speaker tech talk but 10hr, alternating 6-day workweeks, kids, and a working spouse don't allow a lot of free time these days. Thanks to both of you for taking the time to explain things.
post #260 of 702
I've never heard of such a thing. Do you have any samples of discs that are so encoded and advertised? I have over 400 DVDs, and every single one that mentioned "5.1" no matter the wording around it had a true 5.1 discrete soundtrack. If a disc says anything like "Dolby 2.0 Surround" or "Dolby Surround" or "Dolby Digital Surround" or just "Dolby Digital", then chances are it's a mere 2.0 track.
Hmm, you're right, just the 7500 and 8500.
post #261 of 702
To be honest, this is the first I've heard of the term "Dolby Surround 5.1" as it's really a misnomer - as soon as you insert the term "Surround" in there it means a stereo track (Dolby Digital 2.0) with matrix-encoded surround information.
Most discs encoded this way properly use just "Dolby Surround". I'm specifically thinking of Blade Runner: The Director's Cut which one of the very few major releases not in Dolby Digital 5.1.
They are still allowed to put the Dolby Digital logo on the package because it is Dolby Digital 2.0 (not sure if they do on Blade Runner), but they are not allowed to say "Dolby Digital 5.1" if it isn't Dolby Digital 5.1.
post #262 of 702
Daniel and Fraoch,
Thanks for the lesson in Dolby Sound! Very interesting !
What I found while playing this disk is that the "Mastered in THX" sound lites up the whole map, just about. Then the movie kicks in and all but 3 channels go away. You'd think that if they go to so much trouble to Master it nicely, they'd put in all the audio tracks! Buyer beware...
post #263 of 702
The THX demo loop is usually in Dolby Digital 5.1. Your display should look like the DD 5.1 display.
I don't know if there are any Dolby Digital EX THX demos. They certainly aren't on the Star Wars Episodes 4-6 DVDs, which are in Dolby Digital EX. You'd think if the movie was in DD EX the demo would be too, so I'm guessing there aren't any DD EX THX demos right now.
post #264 of 702
I have an 8500...and when it is in Auto mode it fails to switch to 5.1 even though the display show that it is recieveing a 5.1 signal.
Its easy to remedy I just push the Dolby D button and its fine but I figured I shouldnt haveto do that.
post #265 of 702
I've found the Autosurround function rather useless on my 8400 (my 7400 was identical).
For example, with TV sources it defaults to STEREO. Kinda silly - why not DOLBY PLIIx MV?
Since it remembers the last setting on each source, I don't have to play much with it anymore. I leave the TV input set to DOLBY PLIIx MV and the DVD to DD+PLIIx MV. The only automatic switching it does is during the transition from the DVD menu (usually in DD 2.0) to the movie in DD 5.1. It will switch from DOLBY PLIIx MV to DD+PLIIx MV when this happens.
I don't have to touch the double-D button anymore.
post #266 of 702
I also have a SR8500 (in a 5.1 configuration) but find the auto-surround to work correctly whenever it set an input to use auto-surround.
post #267 of 702
I think then its my fault for changing the setting. I did not know that it saved the last setting. So if I set it to DOLBY PLIIx and leave then I shouldnt have to push the button then...I will try that.
post #268 of 702
Both my 7400 and 8400 remember the last setting on each input.
cmexec - what does your 8500's auto-surround setting pick for:
- analog 2-channel sources? Is it DOLBY PLII MV (since the unit's in 5.1)?
- DD 2.0? DOLBY PLII MV?
- DD 5.1? DOLBY D?
post #269 of 702
The manual for my SR9600 shows that AUTO basically sticks with the original sound format. So an Analog Stereo input ouputs only as stereo. Dolby Digital or DTS 5.1 stays 5.1. The absolute only surround decoding AUTO seems to do is on a Dolby Digital 2.0 stream that has been properly marked with the Surround flag - it enters PLIIx Movie mode. If the stream has no surround tag (which they often forget to do) it stays stereo.
There are a lot more useful modes than AUTO though. And almost all of them are fully auto anyways...
post #270 of 702
...what daniel said. Although I only use auto-surround for 1 input that I share between 2 separate devices (2nd room Tivo=analog & media player=digital). In this case, the analog input is auto-detected as stereo. For the digital input, it indicates stereo for PCM source or DD for 2.0 or other DD encoded material and DTS for DTS material (the media player is a network media client with DVD player).
