UPDATE of all current info (courtesy of Univited Guest)
Since info on these SXRD models is so spread out in this thread, here's a recap based on everyone's comments so far. Based on my sources, this information should be correct, but you can never be 100% sure until you open the box.
50" KDS-R50XBR1 MSRP: $3999
60" KDS-R60XBR1 MSRP: $4999
Features:
- 3 SXRD image panels (1920 x 1080 pixels each)
- Cinema black Pro with Advanced Iris dynamic iris mode
- Wega Engine HD video processing
- Digital Reality Creation MultiFunction V2 upconversion
- Twin-View Picture-in-Picture (split screen)
- picture settings memory for each video input
- non-detachable side speakers (15 watts x 2)
Connections:
- 3 composite video (2 rear, 1 front)
- 3 S-video (2 rear, 1 front)
- 2 component video
- 2 HDMI (one with audio jacks)
- 3 i.LINK ports (2 rear, 1 front)
- PC input
- 2 RF inputs (1 Antenna, 1 Cable)
- Memory Stick slot
Dimensions & weight
KDS-R50XBR1: 57-1/4"W x 34"H x 18-7/8"D; 94.8 lbs.
KDS-R60XBR1: 66"W x 39-3/4"H x 20-1/4"D; 112.5 lbs.
Notes
i.LINK ports appear to be HD-compatible like those on the Qualia 006. In the "i.LINK Setup" description, the example shows a JVC D-VHS deck as the source.
As you may have gathered from some comments about the A10 Grand Wegas, there are two parts to Cinema Black Pro. First, there's a global iris adjustment with, I think 4 positions, that's designed to compensate for various lighting conditions in your room. The separate Advanced Iris "dynamic iris" option is one of several video adjustments that are only available in the "Pro" picture mode.
Hope this is useful. To those folks who had to scratch the SXRDs off their lists due to the side speakers: my sympathies. I was surprised, too. To everyone else who's still considering the 50" or 60": I'm still convinced the picture quality will be worth waiting for.
Features:
Connections:
- 2 component video
- PC input
- Memory Stick slot
Dimensions & weight
Notes
