Originally Posted by
HoustonHoyaFan
Sony's new SXRD chips at 5,000:1 PCR have already bettered that CR mark.
I'm not sure if that other number was system on/off CR or chip, but we should be careful not to confuse the two. Of course, if Sony uses a dynamic iris they can get higher than their chip CR, but otherwise it will definitely be lower.
Lew Black
You can't take these C/R figures seriously.
If you don't understand how they relate to real world video then you can't, but if you do understand then you can.
Lew Black
They are based on full on, full off.
For systems they are based on 100 IRE and 0 (or 7.5) IRE. Off does not mean the projector is turned off, or there wouldn't even be any reason for the spec since it would basically be infinite:1 in all cases.
Lew Black
Any technology that is transmissive, like LCD, lets light through when it is on, but gives great black when it is off
. DLP suffers from internal light reflections. LCOS must reflect some light where we are supposed to have perfect black when it is on. Turn it off and you have a much darker screen.
And no matter what technology it is, if you know the white level then the on/off CR gives you the absolute black level exactly (simple math). Talking about why it is at that level is a different matter, since you already have the number at that point.
Lew Black
At Runco's website they list an 1800/1 C/R for full on-off on one of their DLP projectors. They also use a home theater spec that is honest and depends on the projector being calibrated to 6500 degrees K. The projector has to be on for the test. Contrast ratio measured this way:156/1. Refreshing (pun intended) to have such honesty in a spec.
People seem to get pretty confused about contrast ratio. Think of it like speed (MPH). You can have top speed through cones and top speed in a straight line. They are both speed, but neither one is fake. Just like 0-60 and 0-100 times are both times, but it doesn't mean that one is fake. And just like neither on/off CR or ANSI CR is fake. They both help you determine what instantaneous CRs you will get across the range of images (along with the blackout level) and either one can be the weak link in any one image.
Here is a tool for seeing the instantaneous CRs that result from different on/off and ANSI CRs (along with room reflections) for different checkerboard levels (the dark always being video 16). I discussed this
here. If people want to see how different on/offs effect the instantaneous CRs with checkerboards like 10/0 IRE and 5/0 IRE (relating to dark scenes), then they can just plug in different on/off CRs and see.
Lew Black
So, if anyone takes these specs seriously I have this dandy, 4,000 watt receiver I will sell you for just $199
Lew
If you mean because they exaggerate their numbers (just like exaggerating lumens) then I understand, but if you mean that on/off CR is not real and doesn't relate to real world video, then you might want to read up some more.
--Darin
