Technically this is not an ISF review - rather a ColorFacts analysis. As you will see - I did not have to ISF the projector! Guess I will just have to go watch a DVD instead.
I got the luck of the draw with a very nice spectrally balanced lamp - not so much yellow-greens, and a bit of red push.
CIE1939
But lets look at it more subjectively with a more modern chart, which accounts for the eye seeing red/blue color difference more than green color difference.
CIE1976
Nothing really to complain about with colors!
Time for some brightness and contrast measures. First we perfectly align the sensor, and use a small image size for high black level accuracy.
1) 2' wide image verified with poster board at sensor - OK
2) Image center aligned exactly with sensor diffusor - OK
3) Sensor tilted back to return reflection dot back to projector lens - OK
MEASUREMENTS!
TEMP/LAMP/ND2? white_ftL/black_ftL = contrast ratio @ Lumens (to tens place)
6500K/LO 406.1/.234ftL =1730:1 @ 910 L
7500K/LO 535.9/.234ftL =2290:1 @ 1210 L
9300K/LO 396.1/.236ftL =1679:1 @ 890 L
7500k/HI 647.1/.283ftl =2285:1 @ 1460 L
OK I was a bit sloppy with those numbers - now that I am light adapted. I see the room is not pitch black - light sources are on - so let me fix that.
Cover rack with dark towel, close laptop, shut attic door, turn off microwave nightlite , mask projector LED. Security lights still on in yard leaks thru blinds/drapes - room is not pitch black - but at least I am 0.005ftL blacker.
6500K/LO 396.1/.229ftL =1746:1
7500K/LO 527.0/.229ftL =2303:1
ND2 increases contrast as it is slightly green of neutral
6500K/LO/ND2 210.5/.114ftL =1849:1
7500K/LO/ND2 278.6/.114ftL =2454:1
ANSI is 343:1 w.o ND2, 298:1 w/ ND2
ISF RESULTS
NONE!
This projector lamp was spectrally balanced out of the box - it achieved D65dE=3.4 without calibration (though ND2 degrades to D65dE=11) - thus there are no contrast losing RGB gain/offset adjustments. Gamma was perfectly tracked at 2.24. White peaking control is absent and good riddance - as indicated with perfect tracking gamma/greyscale results at full white.
So I got lucky on the demo stock - normally Infocus is significantly brighter than spec with a bit more yellow greens, and a redder greyscale out of the box to account for lamp burn-in. But the downside to only a bit brighter than spec - is some really nice contrast!. This is not unique to this box - as I have tracked all my SP4805 stock and observed similar brightness vs. contrast tradeoff and accuracy variations with lamps.
I will update this post in a few months after 10% lamp burn-in - which is when I recommend that ISF be done for that last 10% of hidden perfection!
CIE1939
CIE1976
MEASUREMENTS!
ISF RESULTS
NONE!
