AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Boone/Hickory, NC - Charter
Boone/Hickory, NC - Charter - Page 14
post #391 of 518
Originally Posted by tomluck View Post
Any update yet Umatter2Charter?
Here you go.
FamilyNet SD
Ovation SD
World Fishing Network SD
TV One
Bravo HD
Smithsonian HD
Science Channel HD
USA HD
Fox News Channel HD
Versus HD
Speed HD
Sci FI HD
The Movie Channel HD
We'll also be moving some analog channels to digital.
George
post #392 of 518
Hi,
Any chance of getting MLB Xtra Innings in Asheville? Ever?
post #393 of 518
Channel lineup changes have taken place on all Charter systems in North Carolina, South Carolina, and Virginia on August 25, 2009. Info is still rather spotty right now, as my Moxi is showing the right activated channels, but not the correct listings, and I still have no idea where a number of the channels are. When full info becomes available, I'll post it here.
The Moxi box listing issue is systemwide and will not be fully cleared up until at least tomorrow morning, if not a little longer.
post #394 of 518
Good afternoon everyone. I definitely understand your frustration with the changing channel line-ups in SC and NC. We have received PDFs of the new channel line-ups from marketing, and would be more than happy to email the correct channel lineup to anyone who needs it. You can also see this at the Charter.net link listed above. http://www.charter.net/tv/?sc_cid=directory_tv
George
post #395 of 518
There are some issues that need to be brought up here pertaining to Moxi customers in the Lincolnton area.
1. Channel listings for GSN (77), Univision (200), and the Extra Innings/Center Ice channels (360-374) are missing
UPDATE: GSN's listings are still missing, and the XI/CI channels are showing up as PPV channels
2. Channels 830-835 are still in the channel map, but should no longer be there.
3. The listings for the UNC-TV digital channels (120, 122, 712) are messed up again. This is an issue that has been continuing since September 2008, when UNC-TV rearranged its OTA broadcast services.
4. Channel 708 (QVC HD) is not in HD, but tuning instead to analog channel 14. Also, Univision channel 203 tunes to analog channel 23.
5. It should be made clear in the lineups that WSPA is not available to Lincolnton-area customers (outside WSPA's viewing area and also WBTV's transmitter is in this area)
post #396 of 518
George-
I would love to have a .pdf of the new lineup, as I did not receive one by mail. If you could, please send it to tomluck at aol dot com.
post #397 of 518
The nerve of them! what do they expect people to do, go shop at walmart instead??
post #398 of 518
George-
Here you go. I forgot this site allowed attachments..
Channel Migration Lineup Aug 2009 -Asheville.pdf 296.009765625k . file
Channel Migration Lineup Aug 2009 -Boone.pdf 292.7919921875k . file
Channel Migration Lineup Aug 2009 -Hickory.pdf 295.5791015625k . file
post #399 of 518
Does anyone have an updated QAM HD channel listing for Hickory, NC area? I thought i was able to get WBTV-DT a few months ago, but i cannot seem to find it anymore. All i have are the following (interested in HD only):
101.4 WSOC-DT (ABC)
103.1 WCCB-DT (FOX)
103.2 WCNC-DT (NBC)
106.1 WMFY-DT (CBS)
106.2 WXII-DT (NBC)
106.4 WXII-DT2 (NBC)
107.3 WUNG-DT (PBS - Greensboro)
Does anyone pickup anything i've missed? Also what do others in the HKY area pickup with a OTA antenna?
post #400 of 518
I pick up WBTV, WSOC, WCCB, WCNC, WHKY, WAXN, WJZY, WMYT and a couple of different UNC-TV's.
I have a small Terk antenna in my attic and get all of these.
post #401 of 518
any reason why AMC on demand offers mad men HD but we don't actually get the AMDHD channel? I found this strange. in Hickory btw.
post #402 of 518
WBTV is now at channel 73-2.
post #403 of 518
Is this active now? I'm not getting this channel on my QAM tuner. I have an HDHomerun and don't pickup this channel. However i did notice yesterday when installing my new OTA tuner that 106.1 over QAM seemed to show a WBTV news advert. So i thought maybe 106.1 went from WMYF to WBTV. I'll be soon picking up a second HDHomerun so i can have dual tuners for both OTA and QAM. Giving my 4 tuners total. This should ease some issues i'm having with recording conflicts and TV channel watching conflicts.
post #404 of 518
I'm still getting WBTV on 73-2 and WFMY on 106-1, and I'm also fed from the Hickory headend. WBTV was moved from channel 72 to 73 in the big line up reshuffle in August.
You may try rescanning your HDHomerun or by tuning to channel 73 directly.
post #405 of 518
Fox Soprts South HD and SportSouth HD have now been split into their own channels. Fox Sports South HD now airs the same programming as the analog channel, either in upconverted, pillarboxed SD or in HD. I assume this is the same for SportsSouth HD, but I can't be sure as Charter doesn't carry this channel
post #406 of 518
It didn't help. I didn't get anything at all in the entire 70's channel range. I get WFMY however windows 7 doesn't show that channel up in the media center listings so it's almost worthless to me, but i haven't deleted i yet.
Maybe my HDHomerun just doesn't tune in that signal. Would it be 64 or 256 QAM encoding? Would changing that help? HDHomerun won't even tune the channel at either.
post #407 of 518
Maybe my HDHomerun just doesn't tune in that signal..
QAM 73 is 519 mhz..which is same as OTA channel 22 which is WCNC-DT
I'd say you have an ingress problem with your cable drop.
256QAM is what cable uses now, 64 QAM just doesn't have the capacity.
post #408 of 518
Did 101.4 get dropped on charter QAM recently? It's no longer showing up on my channel scan.
post #409 of 518
WSOC is now on 103-3, due to several digital channels changing RF frequencies.
post #410 of 518
Some minor housekeeping of my posts in this thread have beern done, and there isn't much to report on the HD channel front right now, with no HD channels being added to Charter's lineups in recent months.
post #411 of 518
Am I correct that UNC TV is now at 769.25 Mhz? My tuner, an EyeTV hybrid, isn't able to decrypt this. It sees a signal, but there isn't an image.
post #412 of 518
ThisTV Charlotte (WBTV-DT2) is now available in the Hickory area on channel 174 (on Motorola and Moxi boxes) and on channel 73-3 (QAM tuning devices).
post #413 of 518
Hickory-area viewers with QAM tuners can now tune to digital local channels as follows:
3-1 WBTV-DT1 (1080i)
3-2 WBTV-DT2 (This! Charlotte) (SD)
9-1 WSOC-DT1 (720p)
17-1 WUNE-DT1 (UNC-KD) (SD)
17-2 WUNE-DT2 (UNC-TV) (1080i)
17-3 WUNE-DT3 (UNC-EX) (SD)
18-1 WCCB-DT1 (720p)
36-1 WCNC-DT1 (1080i)
post #414 of 518
Hey Umatter2Charter,
It's been over a year since I last asked this and I'm still wondering if the Newland, NC (Avery County) area is going to get HD any time soon? Thanks!
Johnny
post #415 of 518
Johnny
Unfortunately it does not look like there are any plans in place to add HD for the area in the near future. Sorry.
post #416 of 518
Our Tivo popped up with a message today saying that a new channel had been detected, DisneyHD on 756. It's on the Tivo guide as well. However, no picture as yet. What's the status? Any other upgrades coming? We're in Hickory.
post #417 of 518
Yes, Disney Channel HD is on channel 756, and there should be a signal now, as long as you subscribe to the proper package.
Also, PBS Sprout (a channel aimed at preschool kids and their parents and caregivers) will be available on channel 112 beginning October 26.
post #418 of 518
Comedy Central HD will be available to Hickory-area customers beginning November 16 on channel 767.
post #419 of 518
I'm located about eight miles west of Hickory and have Charter Cable HDTV. Does anyone have any knowledge of changes in the Channel lineup adding ESPNU and CNBC for HD?
Formerly from Gastonia.
Hugh
post #420 of 518
I've got a so called Moxi Box from Charter Cable. Do they have plans in upgrading this piece of equipment?
