Originally Posted by Birds Nest
What exactly *did* happen with the changes to UNC-TV? I guess my real question should be what happened to UNC-ED? On my system (Avery County) it appears they've replaced UNC-ED with UNC-HD. Of course, the HD channel is having a *lot* of problems here. Did they move UNC-ED to another channel?
CharterJames, do you know if UNC-ED will be coming back on the Avery system? I really enjoyed that channel. It had a lot of the really good "How to" shows on it.
-Johnny
-Johnny
Read the following: http://www.avsforum.com/avs-vb/showt...9#post14737849
Also, from Wayne Estabrooks at UNC-TV via e-mail inquiry I made earlier in the month:
Starting Sept 25, 2008 UNC-TV will be changing its configuration of digital services. It will provided UNC-TV in high definition, UNC-KD and UNC-NC in standard definition all the time. The switching back and forth between 8 and 11pm will stop.
Also UNC-TV's DTV Blog about this change: http://unc-tv-dtv.blogspot.com/2008/...t-regular.html
I noticed this afternoon that sure enough, the extra Kids station was *GONE* from our QAM channels. You must have put out the word James. Thanks. Now, the only problem is that it IS *gone*. What happened to having WUNC-HD on this system?
