Well, after about 6 months, countless hours of reading and 300+ posts, I'm finally getting around to starting my construction thread!
First, I wanted to thank all the folks that have responded to my questions and posts. I really appreciate all the advice here. I'm amazed at the depth of knowledge (and patience) that I've found on this forum. You guys have been extremely helpful and I couldn't have done it without your advice. Thanks again!
Second, I wanted to thank my father-in-law for flying down from Connecticut to spend 6 solid days doing electrical work. Thanks Jack! I also wanted to thank my Dad for helping me with the framing. Thanks Pop!
The HT room will be in the basement. As I'm sure I mentioned before, I'm finishing off the whole basement at one time. At least I've started this way, anyway. I have almost 1400 square feet to work with, but am finishing around 1200, including the HT room, concession area, full bathroom, a good sized bar and a game/pool room. I would love to have it all done by the end of the year, but it depends on time and money (doesn't everything?).
The HT room is roughly 19x11.5x9. I'll have an equipment closet just outside the HT room, with a MA Slim5. I plan on a 7.1 system. The concession area is big enough to put in some cabinets, microwave and maybe a counter popcorn machine. On the other side of the equipment closet I'll have enough room for DVD storage.
The equipment decisions are still being researched. I was planning on going the Panasonic AE700, but am concerned about lamp life. I've also considered the InFocus SP5700. Jury is still out on the projector. I'd like to go with the Yamaha RXV2500. I'll have to get a new DVD player to boot, but have not had time to figure out what yet. As far as speakers as concerned, I'm thinking of going with the Ascends for the front and getting in-walls for the surrounds. I'm thinking Jamos based on a friends recommendation, but have not heard them yet. I feel the room is not big enough for columns and I'd like the speakers completely hidden.
I'm going to go with about a 100 inch screen. I plan on two rows of seating (lounger types), the second on a riser. The number of seats will depend on size of the seats. The first row will be around 11 feet from the screen. The second row will be close to the back wall, unfortunately. I purchased my Aura shakers already and an old Kenwood to power them.
As far as room construction and isolation is concerned, I'll be insulating the walls and ceiling and using solid core doors. I don't have any bedrooms on the first floor, so noise containment is not a huge issue. I do plan on using linacoustic, batting and GOM.
At this point, I finished all the framing of walls, closets, bar and soffits. All the plumbing, HVAC and electrical rough-in work is completed. I have run all the HT speaker wire, RG6 and CAT6 (except for the IR CAT6). I still have some speaker wire to run to the bar/game room for audio there. I've just ordered some cables today to run to the projector. I have conduit installed already. I'll be doing all the drywall, mud and trim myself.
I've got some pictures in the link in my signature. I've done quite a bit since then, but need to put new pictures out there. I'll have that done shortly. Things will slow down next week, I'll be on vacation, but will start up again hot and heavy shortly after that.
BTW, the name of our theater came from the name of our road... Blazing Ridge Way in case you were wondering...
Thanks again!
Bud
EDIT on 1-03-2010 (adding self promoting accolades
Blazing Ridge Cinema and basement featured in Electronic House magazine - DIYer Transforms Entire Basement in both electronic and print versions!
Blazing Ridge Cinema featured on volume VI of Home Theater Revealed DVD series
):Blazing Ridge Cinema and basement featured in Electronic House magazine - DIYer Transforms Entire Basement in both electronic and print versions!
Finished teaser shot added on March 1, 2008
Over the next few weeks I plan on building an index of this thread since it's grown beyond belief. I'll try and hit where specifically I did things of interest and links to products I used. Might take a while. Hopefully it'll help folks find things more easily.
LAST INDEX EDIT on 03/01/08
Takes a second to open a new window or tab and another second or so to move to the post.
INDEX
Installation, techniques and tips:
1. Middle Atlantic thermal management info
2. Drywall Lift from ebay
2a. IR Repeater plan - Buffalo IR
3. Rack construction
4. Speaker selection - Ascend 340SE and Sonance S622TRs. Speaker Layout
5. Drywall corners
6. Carlon Adjustable boxes and More Carlon uninstalled boxes
6a. Outdoor movie screen
7. Drywall tools
8. Initial bar design
9. Slanted soffits and light trey
10. Covering the HT windows
11. Linacoustic
12. Riser started and Bullnose wood lip for riser and profile of bullnose trim
13. Riser step light
14. Stage construction
15. 1st projector hang and Chief mount replacement
16. Carada screen
17. Ascend Acoustic 340SEs
18. Stage design and lip for stage
19. Screen wall framing, furring and linacoustic installed
20. Solid Pine doors installed
21. Trim in the gameroom
22. Scrim installed
23. More Furring and GOM prep
24. Beginnings of the Projector box
25. Panels for screen wall
26. Screen wall panel meets wall
27. Color combos
28. Acoustic cotton T pins
29. Soffit and Screen wall - GOM Part I, Part II, Part III, Part IV, Part IV cont
30. GOM Side and rear wall, and more, and more, and still more
31. GOM beveled edges
32. GOM detailed instructions and GOM Lessons Learned
33. Harmony 880 integration
34. Screenwall panel details and more
35. Home Theater stained crown
36. Unfinshed projector box on slides
37. Buds light automation with the X10 - Poor mans Lutron GE
38. Berkline seat options - Ended up with option A - 090s in this config and more options, includes 088s layout and finally curved row options
39. Carpet selection
40. Projector box is GOMed and front cover almost complete.
41. Stained casing for HT doors, base molding and riser lip and stained crown in HT room and concession area
42. Staining tips, Stained door for equipment closet, entrance door and remaining doors
43. Jamb saw rental from HD
44. Dupont laminate flooring in gameroom
45. Begin carpet install and problems with Home Depot
46. Paint in the gameroom
47. Almost finished Dupont laminate floor installed in gameroom and more flooring
48. Bar floor
49. Finished out rack
50. Carpet finished finally
51. Berkline 090s arrived and installed
52. Updated rack and back of rack and what equipment is in the rack
53. Poly or no Poly?
54. Left and right screen panels and Center Panel/Sub panels
55. Final panels done and screen wall shots
56. Approximate estimated and actual costs - at the time
57. Gameroom and bar lighting
58. Ticket window plan and starting window construction. Stained window and ticket window lettering. Plexiglass and speaker hole cover installed. Finished ticket window!
59. First game room decor
60. Under counter bar fridge
61. Bar cabinets arrive and installed cabinets
62. Front of the bar design, wall frame calculator by VorlonFog , Front of bar begins, building with a Kreg jig, unfinished panels done and corbels arrive
63. New Hsu sub arrives
64. Granite being installed and completed
65. Stained bar and corbels installed. A few finished shots of the bar
66. Studor vent for bar
67. Projector box finally complete
68. Poster light box design and construction concept. Beginning of inner box construction, finished inner boxes.
69. Attaching outer box to poster frame. Hung inner poster boxes and posters installed, but no lights yet. Rope lights installed in poster boxes and how to install the rope light.
70. White plexiglass for diffuser arrived and installed. Finished light boxes. Estimate to build boxes.
71. LG LCD installed behind the bar
72. Now Showing DVD case stand
73. Concession sign from eBay and my Photoshop sign
74. Candy rack
75. Sign printed by Kinko
76. Finished frame, finished concession sign.
77. Marquee Sign done in Photoshop and color variations
78. Building the Mylar light box and finished outer mylar box
79. Panoramic shots of theater and concession area using Autostitch
80. Bar stools
81. Bar lighting using rope light
82. Nutone inline fan for projector box
83. Concession area fridge, finished mylar box, light floor rack, and new shiny trash can. Lighting for mylar box
84. Shed framing
85. Gameroom movie posters (not quite level either)
86. Wireless Wii Sensor bar for screen placement
87. Chad's theater room build (The CG Family Theater) that Jason and I helped design and build out.
Products used and where I got stuff:
1. Blazing Ridge Cinema theater intro
2. Porter Cable 3-1/2" Clipped-Head Framing Nailer
3. Drywall lift from ebay - replace the asterisks in the invalid URL with ebay .com
4. Drywall panel carrier from Amazon
5. 150 ft spool of frosted white rope light from Novelty Lights
6. Buffalo Electronics IR Repeater components from Automated Outlet
7. Step lights from Pro Lighting
8. Speaker wire from PE: 12 AWG 2C Carol Architectural Speaker Cable 500 ft. CL3R, RG6: RG-6/U Coaxial Cable 500 ft.
9. Sonance speakers and Sonance Symphony (622s no longer on the site)
10. Excel movie ticket generator
11. Inner and outer drywall corners from Home Depot
12. Carlon single and double gang adjustable electrical boxes from Home Depot
12.a For the single gang boxes in the riser with carpet, I used ReceptXtender electrical box extenders (they care a variety of depths in single and double gang)
13. Hsu Research VTF-MK2 sub
14. Since the Yamaha link no longer works, here is the replacement model, the RX-V2700.
15. Ascend 340SEs (Left and Right channels) and the Ascend 340SE Center channel
16. Doors for HT room and the rest of basement
17. Panasonic DVD-S97 - Audioholics review, purchased directly through Panasonic with a company discount
18. Stain grade case, base and crown molding in the North Atlanta area. Other moldings from Home Depot and a builder neighbor.
19. Linacoustic purchased from a local NB Handy
20. Middle Atlantic Racks and Shelves from Worthington
21. Middle Atlantic Slim 5-43 from BSWUSA.com
22. Carada 104 Inch Diagonal Criterion 1.78 to 1 in Classic Cinema White
23. Panasonic PT-AE900U from Visual Apex
24. First mount was a Peerless PRS-UNV-B: Universal Ceiling Mount- Black and the second mount was a Chief RPA-225 from Bright and Sleek.
25. Magnetic speaker grill guides from Parts Express
26. Middle Atlantic LBP-1A L Shaped Lacing Bars 10 Pcs.
27. Smarthome: 50ft Emitter and IR Sensor Extension Cable
28. Acoustic cotton, scrim from Bryan Pape (bpape) at Sensible Sound Solutions
29. Temperature switch for equipment closet fan and projector box fan from Home Depot, Internet/Catalog# 100098472, Store SKU# 144967
30. Home Depot 5/4" Corner Board SKU - used this for furring/GOM
31. Guilford of Maine (GOM) FR701 2100 in 408 (black) for screen wall and soffits, Style Code:2858 Style:Lido - 2858 (Formerly 2838) Color Name: Pine Valley for the other walls
32. 1" fabricmate track from Fabricmate.com
33. Rosewood wood based stain on doors and trim in HT room - used Pre-conditioner on pine
34. 27 x 40 inch poster frames from FrameUSA.com in 2" corporate wide style
35. 27 x 40 inch movie posters from movieposter.com
36. Professional plastics white plexiglass - (SACR.1252447E) .125 THICK WHT #2447 EXTRUDED ACRYLIC - 40.125 x 27.125 @+/- 0.062
37. Hollywood Post Frames for 11x17 Classic Horror movies
38. Monoprice tilted LCD/Plasma mount
39. Changed out the mount to a Peerless Flat Wall Mount - Model PF660P purchased from Best Price Mounts.
40. Toshiba HD-A2 HD DVD player from Amazon
41. Concession sign "made by Bud" in Photoshop - printed at a local FedEx Kinkos
42. Barstools from Garden Ridge
43. Sony Cybershot DSC-W55 from Amazon
44. Magic Chef under counter fridge (times two) from Home Depot
45. Nutone 4" inline fan for projector box from Unitron
46. Emerson .9 cu. ft. Microwave - Stainless Steel/ Red
47. Wirelss Wii sensor bar from Amazon.
48. Nextronics AC powered Wii Sensor Bar for home theaters
49. Ticket window speaker thingie - Stainless Steel Louvered vent from Boaters World
Bud
