I was wondering what wall mounts everyone is using with the 42PF9630A?
I am going to use a Digicom DC-A650 that can be seen here
http://www.digitalmegastore.com/product/?02005&
and
http://www.centraldigital.com/product/?2005&
can't seem to find a list of compatible tvs but I gues its supposed to work with everything and is universal. The online merchant I bought it from was also who I got the tv from and though their site first said they were selling me a Peerless wall mount I then got this one though they did tell me ahead of time and I think they said this was what everyone got with the 42PF9630A so its not a matter of them switching product on me necessarily and they have been accomdating and i can return it but want to make sure it will work and is a good choice for this PDP
As can be seen @
http://common.csnstores.com/common/s...et/pe_pswt.asp
by scrolling down or searching to Philips 42PF9630A the PSWT PH50 is the peerless model wall mount that works with it while thier site originally just said PSWT and i wanted to make sure it was the PH50 but now that I got this Digicom DC-A650 I dont know for sure if it will work and is best.
Also a note of importance is that I am mounting this on a tv stand wall unit with back panel meant for mounting plasmas up to 60". I am worried about the heavy weight of the 42PF630A but figure even being heavy for a 42" it can't be more then even a light 60" so it should hold it but it is just wood with laminate over it which is why i'm thinking of getting a professional install so that they can be responsible if they break it instead of me so i can get a replacement back panel because when i ordered the piece of furniture the back panel came broken and i had to wait for a replacment so i know its breakable.
Regardless it fits perfectly in my bedroom and is a great wall unit with nice component shelves and storage cabinets as well as the great idea of the back panel to mount plasma so you dont have to go into your wall and it easily hides the cords without having to fish those through the wall though i'm worried about drilling the extra hole for cords in the right place and without splitting the wood etc.
Also the wall unit has a cool glass shelf above where you mount the plasma
here is a link to it
http://store.ardinfurniture.com/Deta...ma%20Furniture
I got it in white to match other stuff in room and best reflect the ambilights. I can recommend it so far but will have to see how the mounting goes.
Please let me know what mounts everyone is using and if anyone has used this DigiCom DC-A650 and if you think it will work on the 42PF9630A
