Originally Posted by
Serus
Just so I've got this right, your using a cable card to get the HD signal from Comcast right? There are only 3 ways to get an HD signal. One is using an over-the-air antenna (like rabbit ears or a HD antenna), the second is using a cable card to get the HD signals through comcast cable (the cablecard decodes the HD signal), and the third is having a comcast (or other cable provider) set top box that decodes the cable signal, then outputs it to the TV via component input (can't do it through the cable)
If your doing over the air, then it shouldn't have anything to do with comcast and everything to do with the network your trying to watch since comcast doesn't broadcast over the air, the network does. I tried watching CSI last night in HD, but for some reason I can't get the HD signal for that channel. I'm only using standard rabbit ears as an antenna though, I'm sure I could get it if I used a better antenna. I do get a couple of HD stations with the rabbit ears, surprisingly. I haven't checked the audio quality yet though.
Actually, None of the above...
I'm using the QAM tuner in the philips to pick up the unencrypted HD channels through my cable provider (comcast). By FCC law they're supposed to feed through the local channels through untouched on every service tier.
However, last night there was some horrible noise on the local WB HD feed (not on SD) and so I called comcast to report the problem. Unfortunately they deny it's even possible for me to get my local Channels in HD without a set top box (i didn't want to confuse them by mentioning Cable Cards!)...
I explained I have a Digital Cable Ready HDTV with a QAM tuner that lets me pick up HD over cable without a set top box. Comcast said that was impossible.. They asked what channel I was watching on and got VERY confused when I said 81.7. They were like.. but HD is on Channel 650 and up.. I tried to explain about how they set arbitrary channel numbers but my TV picks it up on a frequency based number and I lost them completely..
The Supervisor said there is NO WAY whatsoever I could be getting HDTV without the Set top box... sigh...
looks like I'll have to get the STB eventually just to get DD and ESPN HD... grr
Oh and they charge more for the STB if you're on analog than if you're on digital.. and you don't get ESPN HD or Discovery HD either... I Smell a Scam.
Oh Well, looks like i'll need to add ANOTHER remote to the collection...
