| I thought I read somewhere that initial hd-dvd movies would only be single layer...? Can anyone confirm this? |
never read that anywhere, I guess there is a chance of it SL is cheaper then DL but who knows. Don't forget that a 15GB compared to 25GB is a real big difference and if HD-DVD wants a good impression it better go out with DL
| Because like other people said.. expect LOTR extended to suck ROYALLY, compared to blue-ray, on hd-dvd if only a single layer disc is used. |
I don't think a DL disk would be enough for a "good" version
| Otherwise there will be two discs like the dvd version. |
I think you would need two even with DL, which is why I think it was not on the original list
| Since mpeg4 codecs look to be the standard for new formats, |
no, it does not look that way, also you missed the PR from TW that said they will use MSs VC1 and not MPEG4 and MS is helping them with the transferring.
| this will save considerable space, but still not be enough for single layer hd-dvds. |
it is not only a matter of codec but more so a matter of bitrate. the only difference is that whatever bit rate you pick the MPEG2 version will look worst
| Why buy LOTR in 720p when Blue-ray will eventually be able to release it in 1080p? |
I don't think anyone has talked about 720p. I think all HD movies on BR or HD-DVD will be 1080p, the only difference, if there, that affect quality is the compressed bitrate or if it will be on more disks.
| I like blue-ray because it offers plenty of storage to allow for optimal PQ/sound. HD-DVD is a small step in the HD direction where as Blue-ray looks to be the standard for many years to come. |
agree
| 1080p sets will be fairly common in 5 years, and people will be stuck w/ 1080i/720p if HD-dvd wins... |
I think you are mistaking the announcement that Toshiba said that they won't support 1080p output on their first player to it being a limit of HD-DVD. Most here think all movies will be in 1080p24 on disks, while most players will allow for lesser outputs
