I just picked up my Slingbox last Friday at the Paramus, NJ (South) CompUSA. They had 6 in stock when I reserved my unit from CompUSA's site. They are probably sold out by now (unless they received another shipment since then.)
First, I thought the setup was incredibly simple. I was truly impressed (though I would NEVER, EVER give one to my parents!!). As simple as the setup was, I could not get the Replay to change channels during the Slingplayer setup. No matter what I did, it wouldn't work. After 1/2 hour on the phone with a Sling tech, he decided that I had a faulty flasher cable and he is sending me a replacement. That was a bummer - 'cause I really wanted to play with it. I was really pissed that Sling decided to use a 3/32 jack, instead of a standard one, as I had other flashers I could have tried, but I they had 1/8 jacks. It was late at night so I had to wait a day to pick up an adaper at Rat Shack. I must say that the small jack did not seem to have a very tight fit (it didn't really "snap" when I plugged it in).
Truth is, I was really trying to NOT use Sling's flasher. My problem was that the IR window in my 4516 is really small. My Replay sits in a converted cabinet behind a swing-out drawer front. It is hidden, along with the rest of my equipment and works with a main IR Receiver that blasts the IR signals to each of my components through a Xantech connecting block. There is literally NO room for any additional flasher in front of the window. The dual flasher that came with the Slingbox is really big, and is made to extend an inch or so in front of the window. I don't have that space available in my setup, so I decided to use a 3/32 > 1/8 adapter and a 6' m-m audio extender cable to connect the IR out from the Slingbox directly into my "IR Receiver IN" jack in my connecting block. This way, I would only have my original flasher over the IR window and the Sling signals would be transmitted through my connecting block. To others out there... 'DON'T DO THAT!". I burned out 2 transformers (one for each of my 2 connecting blocks). So, I now have the solution: I am using the 3/32 > 1/8 adapter with a standard Xantech flasher placed ALONGSIDE my original flasher. The two flasher "lenses" are side-by-side over the IR window and they both work well (even though the window is a 1/4" circle). Fortunately, I had 2 replacement transformers and an extra flasher. I did have to buy the adapter, but it was pretty cheap. And YES, the Sling flasher was defective as the Xantach one works just fine.
Otherwise, I have the beta player installed. I am pretty impressed, but so far, I have only viewed through my local network. Seems much better when I am wired vs. wireless (b) My LAN bitrate has been as high as about 850 kbps on my desktop, but it seems like it averages between 500 and 700. My laptop on wireless sometimes goes below 200 and then it ocassionally stutters. And I sometimes get a severe humm (which is now starting to bother me). I just moved the transformer and I think the hum went away. Will have to wait and see... All and all, I think this is way cool. Now I have 3 networked Replays, a Slingbox, a Proliphix IP Thermostat, a Pan/Tilt/Zoom Netcam, Vonage. Soon, I won't even have to get out of my chair!! Anyone know of an IP device that will feed me??
Also the Slingbox and the transformer seem to get very hot. Any one else notice this? Any reason to worry? Mine is in an enclosed cabinet, but there is ventilation space on all sides.
