Originally Posted by jszei
I will be putting in some Noctua fans inside my cabinetry.
The Noctua fans are the quietest fans on the market by the way, I've done a bit of research. Here's some info.
http://noctua.at/main.php?show=nf_s1...parison&lng=en
I'll also be using the fan controller from Cooler Guys.
My equipment includes a Marantz AVR, a PS3, Directv box and most likely a Blu-ray player when Oppo releases theirs. I will also have the Panamax M5100-PM in the cabinet.
Based on that load does anyone know how many fans it will take to cool an enclosed cabinet with them? My thought is 1 fan pushing air in at the base and 1 fan pulling air out at the top. Is that enough circulation?
Those Noctua fans look nice. But, fwiw ~ Maybe I'm missing something, but the SilenX Ixtrema Pro Line seems to generate much greater airflow while being quieter and a little less expensive.
Not trying to say mine's quieter than yours, or such. I'm just suggesting that you might get much better circulation with a SilenX Ixtrema Pro without giving up anything.
Noctua NF-P12 @ 1300 RPM 54.32 CFM 19.8 dB(A) Noctua NF-P12 @ 1100 RPM ? 16.9 dB(A) Noctua NF-P12 @ 900 RPM ? 12.6 dB(A) SilenX IXP-76-18 1400 RPM 90 CFM 18 dB(A) SilenX IXP-74-14 1200 RPM 72 CFM 14 dB(A) SilenX IXP-74-11 1100 RPM 46 CFM 11 dB(A) SilenX IXP-74-09 800 RPM 38 CFM 9 dB(A)
