Originally Posted by
bandit4
... One attached to the PS3, another to the PC and the third to the DVR?? The PC and the PS3 fans would only come on when they are turned on and the DVR fan would always be on.
I would not hook two fans up in the same "air compartment" such that only one or the other may be on at a time. If one of the fans is not running, the open space around the non moving fan is a prime opening for the air from the other fan to short curcuit through. in the most severe case of this, all the air will just circulate in the one fan opening and back out the other. If you then had them mounted close together, you would get little to no benefit from the one fan being on.
At the very least, if you set them up so one comes on per component, at least set one high as an exhaust fan and set the other low as a supply fan. that way you still maintain flow through even with only one fan running.
bandit4
I would use a filter on each fan.
I wouldn't, you just kill all the airflow these thing can provide. Seriously, those two fans will likely not have enough to keep a PC and a PS3 ventilated if it is even remotely hot in your room, adding a filter on will cut at least 50 to 75% of the air they can move, making it that much harder. I suggest you go filterless and just vacuum your carpet more often.
Further, if your setup allows (fans are located out of the way, no kids with inquisitive little fingers, etc.) run those fans with no shielding too. You would be amazed at how much airflow gets reduced when you put those little round bar fan shields on. Take them off and you will get a lot more airflow (and the fan will most likely run quiter too.)
Lastly, running fans as supply instead of exhaust can have advantages, but their advantages become significantly reduced if your cabinet has a lot of leakage points. (IE: If the supply air leaks out along the bottom of the door right by where it was blown in, it's not doing much to force the hot air out the top.) Whereas if you run fans as exhaust and you have leakage, its not really as big of a deal, as even if you are pulling air in around the top of the door, you are still going to be pulling cooler air in and most likely evacuating the hotter air out the back. Long story short, if you run those fans as supply fans, weatherstrip those door openings and make a dedicated exhaust opening up top.
-Suntan
