Hello all, I am trying to revive this as someone might have come up with new things, I actually found this at walmart, it's a power adapter that has molex adapters so you just need the fan(newegg has good prices)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Case+Fans-_-N82E16835103052&gclid=CNSer6jTibcCFcXe4Aod9j8Ang
http://www.walmart.com/ip/16318477?wmlspartner=wlpa&adid=22222222227000000000&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem#Item+Description
this is my new project and it's just on the planning, I am trying to cool off an Onkyo HT-S5000 which I heard gets pretty hot.
I am trying to use some stuff that I have lying in the house, I have several old desktops with their power supply but I think that might be overkill to power two 120mm computer fans, also the power supplies are the size of a brick. I also have several power adapters from an IBM laptop thinkpad T41(I think these are 9v) not sure if these will work.
Any advice on either using the desktop powersupply or the laptop power adapter?
This is the technical info for the laptop power adapter, 16V might be too much?
AC adapter: This ac-to-dc converter supplies the necessary power to the computer. The ac adapter also charges the battery pack when it is installed in the computer.
Universal AC adapter (72 W):
Input is 100/240V AC, 1.4/0.7A, 50/60Hz
Output is 16 V dc, 4.5 A
