Hi Bill,
I just finished reading the two threads, and now I am more confused than ever... :confused:
| You want the "beamer" model. The software that ships with it should give you xyY data, which is all you really need to do a calibration, but I have not tried it (yet). |
I though that Mr. Phelps gave his stamp of DISapproval on that particular unit, or did I misunderstand? And why would I want the beamer model if the only difference is in the software? Or is that software necessary just to get the xyY data that I need?
| The OpticOne is a Progressive Labs product, and it does have a normal model number from them (CA-1? CA-6?). I can't recall it at the moment. If you can find it for cheaper than OneCall has it, please post it (here or in the deals forum). |
The deal at OneCall includes Avia Pro in the package. Is this a standalone solution that can be used by your average monkey (me) without having to take an engineering course before being able to use it effectively? And does it provide repeatable, accurate results? It would be worth the $1700 price tag if filled those criteria.
| Finally, if you want to play Spyder2 games, you can either get the Spyder2Pro for ~$250, or you can get the Spyder2 for $140 and a copy of the (old) OptiCAL software for ~$50. However, I have not yet been able to check its accuracy vs. reference equipment, since I am waiting to have my H77 ISFed after the H78 upgrade is done. It's been a LONG wait on that one. |
Kevin seemed to indicate that that unit would only be useful if I have some reference equipment to compare it with, and then only for one particular projector. As things stand now, I own 3 DLPs, and my friends own a few more, and I do not have access to any reference equipment. I am looking for a software/hardware solution that I can run on a laptop and at least mess up my friends' projectors, as messing up just my own wouldn't be enough fun!
| The SpyderTV is based on the Spyder2 and has ColorFacts at its core, according to Mark Hunter's post in a different thread. However, it is not slated for release until mid-July last I heard (though you can pre-order for $199). Out of the box, Mark indicated that it will not do grayscale calibration. |
Is SpyderTV software or hardware, or both? If I read it right, didn't Mark say that Colorfacts would be necessary to do grayscale? And isn't the Colorfacts software something like $2000 without a colorimeter?
| If either of you guys want to collaborate or beta test my own project, shoot me an e-mail or PM. |
If I end up getting a colorimeter, I'd be happy to beta test. If all that needs to be done is to plug in numbers on a spreadsheet, then I'm your man, but if using it requires more intelligence than your average monkey, then you might not want to let me get my hands on it...:)
I figure it this way - I currently own 3 DLPs, one of which (the H-79) NEEDS professional calibration, and the other two which I would just like to get that little extra to make them look even better. I don't know a good ISF guy around here, and even if I did, I would probably spend a lot of money with repeat calls every time I change a source device (which I do frequently with my HTPC). So if I were to buy either a hardware/software combination, or buy just the hardware and plug the numbers into a spreadsheet, then I wouldn't mind spending a reasonable sum of money. Oh yeah, and did I mention that a monkey should be able to do it? :D
