AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Denon DVD-1920
Denon DVD-1920 - Page 27
post #781 of 787
I finally removed the 1920 from my system because it locked up so
frequently. IMHO, junk the Denon and go buy a cheap HDMI toshiba or the like
from Costco. That's what I did and it's light-years better than the Denon.
One man's opinion,
Larry
post #782 of 787
@Ender1962: It seems, your player has a damage. I used the 1920 over three years, but never had that problem. The 1920 is a good player. Please try to reset the player by using the factory settings.
post #783 of 787
I'd be delighted to give it a try, but I don't know how. Could you point me in the right direction?
Even when the Denon was functioning properly, I didn't see any difference in picture quality on my Sharp 1080i LCD between the Denon and the $70 Toshiba. The Toshiba does a great job of upresing from DVD to 1080i HDMI. A genuinely superior feature of the Toshiba is its recovery action when it hits a bad patch on a disk. It just keeps moving ahead a sector at a time until it finds one it can read. The Denon just stops.
post #784 of 787
Also, the Denon often couldn't read DVD movies that I recorded on my computer in standard DVD format using Nero. It would just lock up and I had to go behind my equipment rack to unplug it and plug it back in to reset it. Very frustrating! The Toshiba plays them all without a hitch.
post #785 of 787
How do I reset this to factory settings?
post #786 of 787
Page 32 of the English manual states:
Reset to the Default Settings (except for Ratings Control and VIDEO OUT)
This allows you to return all selections of SETUP (except for Ratings Control and VIDEO OUT) to their default settings.
1. Press the SETUP button in stop mode.
2. Press the Cursor buttons (< or >) to select INITIALIZE, then press the ENTER button.
3. Press the Cursor buttons (∆ or ∇) to select YES, then press the ENTER button.
4. Press the SETUP button to exit.
post #787 of 787
Thanks konoyaro. I bought this second hand with no remote or manual. I'll give it a try.
  Back to Forum: DVD Players (Standard Def)
