AVS › AVS Forum › HDTV › HDTV Recorders › New moto 6412 with HDMI and SATA
New moto 6412 with HDMI and SATA - Page 8
post #211 of 1929
Originally Posted by number2withacoke View Post
Even with it turned off the fan wont stop running. HELP!
The only way to power off the STB, is to unplug it. The on/off button only turns the unit to Standby.
post #212 of 1929
the only way the fan is off is when its unplugged, it cant be normal. i just programmed it and got shows already on it. i dont want to have to change it out.
post #213 of 1929
Why would the box be sold from the Cable Company. Comcast only leases them to me
Originally Posted by shugazer9 View Post
My local CC was offering this box for $299 with a 2 year commitment to Cox cable. I had to return my 2nd gen 6412 because the firewire output had the copy protection turned on in the latest firmware update. I was then unable to archive to D-VHS. Can anyone confirm that the firewire is working in this box?
post #214 of 1929
Originally Posted by QZ1 View Post
My opinion is that even the silver remote is not so good. I used it for a while, it is not intuitive. Better to get a Harmony, which ever model you choose, it will be a much better layout. If you think you will be good at detailed programming, (I learned on the fly), then I recommend a Home Theater Master.
For those looking for a great remote I just got the Harmony 520 at Walmart and it is amazing!!! It controls everything you could possibly need. There is a great thread running in the accessory area discussing different remotes, but this one is fantastic.
post #215 of 1929
I had a noisy fan, and took the box back and got a new one. The new one is almost completely silent (fan & drive). Don't settle for less.
post #216 of 1929
I just read this whole thread and didn't see if anyone has ever tested the SATA port.
Has nobody actually tried hooking up an external SATA drive using the 6412's rear SATA port???
post #217 of 1929
The port is not currently enabled, nor does the current firmware 09.12, 09.15, 09.17, 09.19, or beta 09.21 have support for it.
post #218 of 1929
In order to increase the recordable hard drive space available, i set up two 6412's on the two component inputs on my TV. I assigned each 6412 several program series to record. The set up went fine as I turned off one 6412 while scheduling programs on the other 6412 to compensate for the fact that both had the same remote access number and both responded to the same commands. The problem occurred when I deleted the program from one 6412. Because the same signal went to both 6412's, a program was deleted from both. When I turned off one 6412 and pushed menu on the other, the diagnostic menu would come up on the turned off 6412, change the settings, and that would have to be corrected. In other words, it was a constant problem and required daily monitoring. Finally, I went back to D* and Tivo to provide more backup and SD space, and retained one 6412 in order to record the superior HD picture. Comcast has a good product, but need to activate the SATA outlet to provide sufficient hard drive space.
post #219 of 1929
I got a 2nd one in the same room here recently to add more space, and it works fine if you place a piece of cardboard in front of the one you aren't controlling
But I agree this is not as elegant as the code-settable UHF remotes I had with Dish Network.
post #220 of 1929
I will be changing my older 6412 for a Phase 3 unit. I have an ongoing issue with my cable company regarding the poor analog picture quality and the Phase 3 seems to address that.
In preparation, can anyone tell me what type of HDMI to DVI cable I will need?
More specificially, is the HDMI connector on the 6412 a female or male?
post #221 of 1929
LD500,
All connections on source devices are male and the cable is female when HDMI is concerned. It is the oppposite when DVI is used.
I can get you the required cables, contact me for details.
post #222 of 1929
Are the phase III's more sensitive to low signal conditions?
I had a tech over today who finally got my phase III working. This is the 3rd 6412 I have, the other two have been fine. The P3 didn't want to receive "hits" from Comcast to update it, and wouldn't let me watch most of the digital channels.
I swapped it out for a 2nd P3, but that didn't help - same problem. I swapped it to use the cable outlet my original 6412 is on, and that didn't either (similar signal levels on both outlets).
The tech today boosted the signal and the P3 finally took a hit.
post #223 of 1929
When you turn this box off and access the menu is there a "passthrough" option or just the same 480, 720, 1080 options?
post #224 of 1929
What do you mean by a passthrough?
Comcast sends all HD in 1080i format from the headend to the STB as stated on there website and commercials. (Networks are sent in native xxx or xxxx format)
post #225 of 1929
Yes, but you have to select what format the 6412 will output, either 480i/p, 720p or 1080i. If it had a "native" or "passthru" mode it would allow the box to change it's output to whatever it's receiving.
Are you saying that Comcrap is sending ESPN-HD to the box in 1080i mode, even though it is natively 720P??? I don't think that's right because I have the Sony HD DVR and when it receives ABC-HD and ESPN-HD it says it's coming in at 720P.
post #226 of 1929
What I mean by "passthrough" is unscaled. I have Brighthouse cable and I'm not sure how they send their HD. I had assumed they sent it how ever it came from the network. I'd like the cable box to pass the signal through to the output without scaling at all.
post #227 of 1929
Dave,
We all have asked this question, but there are several answers out there. The info I have is from some of my former Comcrap Employees. But thats what they tell me.
Does anyone have access to a HDTV signal tester that can test the HDTV Ch on a comcast feed line?
post #228 of 1929
The STB must be set to whatever your TV/Monitor/projector is set to.
The 64xx STB does not pass through any native signal, it must be selected in the setup menu.
post #229 of 1929
That's exactly what he's asking for though, a native passthru mode so it can be used with external scalers and monitors that can handle all resolutions and can also scale better than the Motorola units can.
I am confirming that the Comcast signal is native in nature coming into the Motorola. It is the Motorola boxes that change the resolution if need be. Like I said, I have the new Sony HD DVR that decodes cable and OTA SD and HD signals and when I tune to ABC, FOX and ESPN HD channels it comes out as 720P and also says that it is being input at 720P. WHen I go to the NBC, CBS, etc. channels it is at 1080i. This is all when I set the Sony into it's native mode.
post #230 of 1929
Yes, it is correct; fan stays on, unless unplugged.
post #231 of 1929
the firewire passes through native... I know that doesnt help the scaler issue though
post #232 of 1929
I wonder what would happen with firmware 12.13. Do RCN boxes have different firmware for the Phase III compared to other providers?
post #233 of 1929
That's true. I have done that in the past also by passing the firewire stream out to a DVHS unit, then out it's component output to the display so it would be in native mode. The only thing that sucks w/ that is you lose the menus and OSD.
Hey flyersfan, noticed your handle here at AVS...VERY COOL!!! I am foaming at the mouth waiting for Hockey to return, especially the Flyers. Time to bring the cup back home to Philly and make Bobby Clarke proud!!!
post #234 of 1929
LD500,
First of all, thanks Dave for answering.
Strange, all the computer stores locally only seem to sell Male HDMI to Male DVI cables. When I look at the photos at the start of this thread it looks like a female connector to me, but I'm not that familiar with HDMI.
Can anyone else confirm that the Motorola 6412 indeed has a female HDMI port on the back of the unit? And therefore I would need a Male HDMI to Female DVI cable to hookup my TV.
Hoping to buy the cable this weekend and swap to a Phase 3 ASAP.
Thank You
post #235 of 1929
LD500,
That is a standard HDMI port on the Ph III 6412 according to the pix. Just get whatever they are selling locally, it will be alright. That is the standard HDMI hookup config. Look at the cable's HDMI end, if it has a thin narrow opening in the center, that's the one you want. For the DVI end, it should have the pins protruding out, not small holes to accept the pins. That's the male end of the cable for DVI.
Go to www.extron.com and it'll explain just about every cable and connector out there.
post #236 of 1929
post #237 of 1929
When I got my phase III I needed a HDMI cable. The best price I found (didn't search too long) was at svideo dot com - under $10 for a 6 foot one. Works perfect!
post #238 of 1929
This is where I got my cable, under $10 for a 15 footer, works like a champ.
http://www.monoprice.com/products/su...d=10231&style=
post #239 of 1929
Does anyone know if the HDMI port on the phase 3 box is version 1.1 or version 1.0?
Steve
post #240 of 1929
Good to hear as I ordered a 6 ft one yesterday for $7.30 shipped.
  Back to Forum: HDTV Recorders
