AVS › AVS Forum › Audio › Speakers › Paradigm Owners Thread
Paradigm Owners Thread - Page 345
post #10321 of 28086
Originally Posted by AbMagFab View Post
If you want to rip your BD's as well, and new HD home video, you need to build a HTPC (which is about 50-60% as effective as XBMC, but the only way to play HD right now, unfortunately).
How is an XBMC twice as effective as an HTPC? I don't see what it can do that an HTPC can't, besides play Xbox games (and the PC can play most of those, with better graphics). I'd actually argue the opposite; that the HTPC is far more effective than an XBMC setup. Plays any audio or video format I've came across, upscales to 1080p and sharpens video (ffdshow filter), plays new games, can emulate all the old game systems, plus you have all the obvious PC features (web browsing, e-mail, office stuff) which are all great on an HDTV as well. Only downside is it could cost more, depending on how crazy you get with the hardware. What am I missing?
I will agree with the point you seem to be making about HD support on the PC; from what I've heard it still isn't very well supported, and it bugs me that you need to buy expensive software after you bought an expensive Bluray drive just to play the movies; for what you pay between the drive and software ($200-ish) you could buy a standalone Bluray player and not have to worry about HD DRM stuff (HDCP, right?).
post #10322 of 28086
I think everything has it's place. I use Knoppmyth. The nice thing there is you have a Server and a Front end. I can do much more then just use it for media it can also have numerous utilities along with it. But XBMC works great as a simple front end for a media center. But again it has it's limitations. PC will always have the ability to surpass it but a PC will cost more in hardware. I recommend a solid Server backend and having lightweight front ends all over the house, and I've heard many people use Playstations or XBox's to do so.
post #10323 of 28086
The Millenia 30 center is adequate. It does a nice job with dialog...but I would have loved to go with a matching center like the cc590 or cc690. I will eventually upgrade. I have been trying movies with the center on and off and am not sure what I prefer. Sometimes I feel 1 way - sometimes opposite. It is a nice looking and smaller center - fits nicely in my setup. However the shiny gloss coating is super reflective and I am looking for a piece of black velvet to cover it with. Also - it CAN NOT accept banana plugs! Grrrr.... 3/5
corpfan1 That must be one kicka** & loud setup.
I just ordered my LCR Studio 20 v.5 & the new Studio CC-490 center, that small setup shut down a Marantz SR6003 at med. vol.. If you have the room to put the CC-590 or 690 go for it. I got to demo the CC-490 and it was sharp & full sounding size is 8 3/8" tall x 19 1/4" wide and the feet can be removed if the hight is a problem just need felt stick on pads. Also I went with a Velodyne MiniVee 10" sub (under $800) to fill in the lows the 20s can't get. it matched up better with the 20s than the cheep Paradigm sub they had there. It seamed faster and sharper than the Para. sub
post #10324 of 28086
Cost and interface..... I have never experienced a HTPC that is as smooth and intuitive like the XBMC. Not trying to start an argument. Just my opinion....
post #10325 of 28086
I'm looking into doing a 5.1 system using the in ceiling speakers from Paradigm. The salesman today pitched the PV,CS and AMS series. I've never owned this brand before and wondered if anyone here could clue me in to their experience (hopefully) with an all in ceiling installation. I'm not really sold on the idea that it will sound the way HT should. My wife is making me get rid of my trusty box speakers.
Thanks for any info./advice.
B.
post #10326 of 28086
B.
I also had to get my big box speakers off the floor, every day I kept finding stuff in front of them. 1991 Went to Polk Satellites Front/rear that was good for then. Now ordered bookshelf front Studio 20 v.5 on stands, cc490 under TV, subwoofer in corner, moving the Polk sats. to the ceiling rear (for now). That compromise sounded best to me. Big box sound little foot print. If you can go that route. Only good in wall/ceiling speaker I heard was Triad Bornze LCR my distant second choice after listening to Paradigm.
post #10327 of 28086
Originally Posted by osofast240sx View Post
funny but seriously we can race for the 100's http://i436.photobucket.com/albums/q...g?t=1235105298
I want in. I'll put up my 60s. Just give me 10, the jump, and squeeze.
post #10328 of 28086
A HTPC is far more *flexible*, definitely.
But XBMC is practically a CE device. It works, it works 100% of the time, and it's usable by you, your wife, your kids, your nanny, your babysitter, etc. That makes XBMC far more *effective* as a media player.
It's simple, it works, and it's stable.
A HTPC can do a lot more, at that's sort of my point (e.g. HD BD's). But at the cost of much lower usability, and far worse stability. Also, you have to hobble together a bunch of piece-parts that don't seamlessly work together.
Use XBMC for a while, and you'll understand. Sadly, since it only plays SD, it's getting lost to time. Hopefully the new XBMC will get stable soon, and perhaps open their minds a little to support more platform-specific stuff (since the cross-platform stuff is still so lowest-common-denominator).
post #10329 of 28086
XBMC is a front-end to a media server. That's the point. Once media server, lots of XBMC's all over your house. Works perfectly, is incredibly usable, and completely stable.
PS3's and XB's as front-ends are horrible. The media format support is laughable, and the UI's are awful and designed to be used by technical people, not by real users.
post #10330 of 28086
I think were on the same page, I was referring to XBox's and PS for their hardware, not their actual software. I'd agree completely that there is no front end on the market that competes with hacked system.
But doesn't XBMC have the ability to do both (Frontend and Backend)? Or do you have to have a main server for storage?
post #10331 of 28086
Thanks for clearing that up; I thought you meant you were using the Xbox as a media server. I do see how using it as a front-end makes a lot of sense. Even a slimmed-down barebones PC will cost you somewhere in that range, and won't have the nice GUI interface. (Some of the various Linux media center editions look pretty nice though; too bad Linux is such a pain to get working properly IMO...actually saw a quote yesterday related to this: "Linux is only free if your time has no value")
This thread isn't getting off-topic at all...
post #10332 of 28086
Folks - Today I auditioned studio 100s at the HiFi House in Wilmington, DE. The sales guy really pushed the new 100s. They were great but a bit beyond my budget. Does anyone know the list price for the 60s?
Jim
post #10333 of 28086
Jim
http://www.avsforum.com/avs-vb/showt...1061034&page=4
post #10334 of 28086
Hey everyone:
Just have a quick question as I narrow down my search (finally) for a multi-channel amp to power my Signature 8's and C5, etc.
Since these speakers are relatively effecient, would I notice a difference between a good amp that is 5 x 200 wpc versus an amp that is 5 x 300 wpc? I know that the consensus is to have more power than you need, but if you have 200 clean solid wattage on these speakers, would that be enough "headroom" for dynamics, bass, etc?
I've looked at amps from 200 wpc to 500 wpc, single-ended and balanced, multi-channel and monoblocks. I just want to get the best sound out of my speakers (who doesn't?) and I don't want to get a 200 wpc amp and then wish I had gotten a 300 - 500 wpc amp. Certainly there is a price difference but I don't want that to be the determining factor in my decision. I want an amp that will mate synergisticly with the Signatures and that I will not question and keep for a while.
I have my mind set on 2 different amps and I know I can't go wrong with either one, but there is a price difference and if 200 wpc is enough, then why pay more for 300-500 wpc?
Thanks for all of the advice you've given me so far (especially Patrick)!
post #10335 of 28086
Originally Posted by JimmyDaves View Post
Hey everyone:
An Anthem P5 would make a nice combination and probably the last amp
you would ever need.
post #10336 of 28086
Originally Posted by oztech View Post
an anthem p5 would make a nice combination and probably the last amp
+1000
post #10337 of 28086
Hey everyone:
Based on what I've bolded, you want the P5. Agree with previous posters that it's probably the last amp you'll ever need.
Remember, it's not really about power, it's about clean stable power across the resistance spectrum. First, that tends to drive towards mono-blocks. Second, you need something that is proven and has been measured to be stable and clean and consistent down to low resistances.
So, you can go with something easy like a P5, or try out the IcePower amps (I know Warp has been going through them, he might have has some initial hum issues but I think they are resolved, so he can chime in).
post #10338 of 28086
What are you guys powering your P5's with - does it really need 2 dedicated 20 amp circuits? And does it run hot?
post #10339 of 28086
I have 2 dedicated 20A circuits available to me, but I'm powering my P5, P2, and D2v off one 20A circuit (along with my other stuff, like a Tivo S3, HTPC, PS3, and XB360).
I haven't had any issues at all, even at very high volumes. But I'm also using Sigs, not Studios, which apparently are more efficient (I know you have Studios, so you might have a slightly higher power draw).
The *only* time I've tripped the circuit is when I'm listening at very high volume levels, and my whole-house generator kicks in (I have it take full load during it's weekly self-test). And even then it only trips about 20% of the time.
And no, it doesn't run hot. The D2v and HTPC are the hottest things in my rack.
post #10340 of 28086
Thanks, glad to hear it..if I ever splurge enough to get the p5. I saw your post last year and you mentioned you were getting the d2v2 to go along with your p5 - how do you like it, combined with the p5 and compared to your old Onkyo?
post #10341 of 28086
any pics of your setup?
post #10342 of 28086
feeling the peer pressure yet. look at it this way, when we race for your studio's and i win. you can just get some sigs to match your new P5/P2. remember your whole system will only be as good as its weakest link.
post #10343 of 28086
In the best of worlds all components should be driven off the same powerline to limit ground and neutral variations between them as that would limit the problem of ground loops. However, powering everything from one line would limit you to 15A or 20A (120VAC) and also tie you to one location, something not really possible when you take into account the sub. And, even at 20A the total power available to you is limited to 2400W and when you subtract all the loads for such things as HDTV's, cable/sat boxes, etc the total available for audio is typically about 400W-500W less or, say, 2000W. Now take into account power factor and we're getting down towards 1600W as a max assuming a 20A circuit.
What would be nice is a battery based system with a good 'true sign wave inverter' with enough capacity to handle, say, 2500W continous with short term needs of 4000W and then power all your components from that. The 20A circuit would be there to keep the battery charged and 1600W should be more than enough to handle even the most intense power needs of all but the biggest HT system as an average. The other nice thing is a system like this would provide nearly total isolation from the mains so that any noise or harmfull spikes/surges/dips/etc would be invisible to the system as it is 100% powered by the inverter. Having a good surge suppressor going into the charger would still be a good idea and would almost completly protect you from all but a direct lightning strike on the powerlines going into your house.
Brian
post #10344 of 28086
yes
I know, I'm considering it
post #10345 of 28086
It's *substantially* better than the Onkyo, in so many ways, even better than I was expecting. Here are some highlights:
- The ARC (Room EQ) is light-years better than the Audyssey in the 905. Perhaps the Audyssey Pro would be closer, but you have to pay someone to come in and do it with the Onkyo, where I can do ARC as much as I want myself, for free (I've already run it about 5 times this week, tweaking my room). And I'm currently adding more acoustic panels and moving speakers/subs around to further improve my room response, as a result of seeing ARC results and trying some things out. It's an invaluable tool in the drive to get perfect audio and room response, and the built-in Audyssey in the Onkyo is a joke by comparison (you simply run it and hope it did a good job).
- The Video Processor is unbelievable. I have always poo-poo'd VP's, especially for HD material. The VP in the 905 is a disaster (at least the Onkyo implementation of it), IMO (e.g. breaks under unusual cadences, can't do anything of value to HD content, the OSD breaks HD content, etc.). The D2v VP is what I've imagined, but never believed, a VP can do. 1080i->1080p conversion is visually stunning, and even 24p->60p works flawlessly. The additional features and tweaking (like custom crops and further image tweaking) make it even more valuable. I'm continually amazed each time I sit down and watch TV and movies since I got the D2v - the picture is noticably and significantly improved. (SD quality is also much better than the 905 VP, but I don't watch much SD, and the 905 supposedly does an okay job at SD VPing).
- The overall sound, even without ARC, is truly amazing. I keep reading people using words like "wide soundstage" and "emmersive sound", and now I know what they mean. Some good test BD tracks for me are Immortal Beloved's Ode to Joy scene - which has some nice dark and contrasty scenes as well as a great range-y classical piece, and the D2v not only reproduces the sound flawlessly, but also makes my HT seem like it's about twice as wide as it actually is. I know this sounds silly, and I've never heard it before now, but I guess this is what people mean by wide soundstage, and the Onkyo isn't even close.
- The control and configuration on the D2v, beyond the above, is also far beyond the Onkyo. You can pretty much do anything you want - whatever you can imaging, and whatever you need to do, you can do. And the RS232 control is complete and extremely reliable, so you can integrate however you want and trust it.
- The OSD works. Silly, but it's so nice to finally have this feature when every other Onkyo and Denon in my house causes such damage to the picture, or simply won't do it for certain combinations. The D2v has perfect OSD (and you can even have it display your own messages if you want - mine says "Mark's Perfect Theater" and "Enjoy the Show" at desired times). Not a huge deal for most, but such a relief for me.
- And then you couple all of this with Anthem's solid reputation for support, firmware and software upgrades, and even hardware upgrades. For a fraction of the original or replacement cost, they have always allowed you to send your unit in for a hardware upgrade to the current model (example - D2 owners can pay ~$2500 for a D2v upgrade, versus $7500 for a new D2v, list prices).
Anyway, I've only had my unit for a couple weeks, but I've been patiently waiting for about a year, and I couldn't be happier. It's more than I had expected, and I was expecting a lot.
It finally brings my Signature speakers to full life!
post #10346 of 28086
Here's the Anthem portion of my rack:
And these are posted earlier in this thread, but here are just a couple pics of my nominal HT setup - Front 110" 16x9 Steward FHG3 screen with Sig 6's/C5 and acoustic panels:
Side wall acoustic panels and ADP3:
Rear wall S2's and Sony VW60/Black Pearl, and more acoustic panels (SVS Ultra 13 sub is hidden behind the left chaise):
I'm adding rear-wall corner traps this week (just finished making them yesterday), and likely a ceiling panel for the center speaker reflection point. This is due to ARC, of course - I tossed a couple of 3-foot throw pillows in the rear-wall corners, and it really improved a 100-hz issue I was having (that I only saw thanks to ARC), so I figured it was time to put them in for real.
post #10347 of 28086
Got my Atom's and CC-190 set up to my Onkyo 606 ans all I can say is "WOW" These little speakers sound great!!! Obviously they are what they are.... small bookshelf speakers but let me tell you they sound great. The CC-190 produces great dialogue; once again for it's size. I listened to the 290 as well ans you could tell it was leaps and bounds better but for what I need the 190 is great.
I set it up and listened to them for 1 night with everything as their defaults and I thought it sounded good. As you can probably tell I am going from nothing to this set up. The next morning I went through and ran Audessy; it took all of 5 minutes. Now I am hearing things I didn't even know existed in movies!!! I am now getting great bass response from the Atoms and great clarity from the CC-190. I can now; for the time being, put my sub search on the back burner!
For me this small set up is all 10's.
post #10348 of 28086
Thank you very much!! This is exactly the type of review I was looking for - a direct comparison to normal AV Receiver to the D2. It sounds like the D2 is worth the price. Do the new D2's automatically come with the ARC or is that extra? What is a fair price to pay for a new D2?
post #10349 of 28086
I picked up a NHT Power 5 (IcePower 500ASP modules 200W x 5), to go with my Studio line (60s, 20s and cc570). It was much, much nicer than the Anthem Statement A2 it replaced. The resolution is just super clear, and very true to life. Dark Side of the Moon has never sounded better to me.
I'm totally happy with my IcePower amp, and would not pay the extra for the P5 as great as it maybe. I'd definitely try to demo one in house. If you're open to used gear, you maybe surprised how little one of these go for.
post #10350 of 28086
Thanks AbMagFab, don't know your real name after all this time..
Appreciate your reveiw, and being that Anthem is Paradigm anyways, its a suited place here in teh Paradigm thread... I have really been contemplating going with a 2 channel theater bypass, and getting away from spending all the money on the D2v. I want an all in 1 unit, but need to get to the next step of SQ, with that wide and deep sound stage you are talking about... Hmmmm
Warp ---> Spins wheel and yells out "Come on big money !!!!!"
Macming, Jimmy is going to want to read that, he's looking for a amp to power his Sigs... I just got my second Ice amp, Wyred4Sound 3x500 (1000ASP's 4x250 500ASP's) and I have a D-Sonic 5 channel same config... great amps..
  Back to Forum: Speakers
