Well in truth it's like eveything else, it depends on a whole lot of factors like room size, listening distance and volume you listen to etc...
But in general that's reasonable advice.
Ground loops aren't all that common, so it wouldn't hurt to try a different circuit if it's convenient.
I wouldn't go out of my way to go to 240v though. When their literature states "maximum continuous volume" it's not really indicative of real world application. No one would listen to 9hz at 125db for any prolonged amount of time... you'd puke... then you'd go deaf...
My room is 14' x 24' with a large opening on one side and I've got everything on the same circuit, my amps total 2250w (3750w if I include the sub) with no issue.
I'm jealous... Always wanted S4's...ended up
